How to Write an Image to the eMMC Module Tutorial
#51
Hello one question
It's possible this script
curl -L https://github.com/ayufan-rock64/linux-build/releases/download/0.4.16/xenial-mate-rock64-0.4.16-83-arm64.img.xz | unxz -c > /dev/mmcblk0
with a SMB direction ?
how can i do ?
And how do this script with an image with only extension .img
#52
well I have already found how to ask my question
this is the script with smb direction
curl -L -u Domain\user:passwd smb://192.168.1.9/descarga/xenialokrock64.img.xz | unxz -c > /dev/mmcblk0
thanks
And another question if is a xxxx.img how can i write the script ? Because unxz gives a error
#53
I've tried several times but I can't seem to interupt the boot process.  I don't see a countdown timer and the serial console just gives
Hit any key to stop autoboot:  0
#54
(01-23-2019, 07:38 PM)wesleykonrad Wrote: I've tried several times but I can't seem to interupt the boot process.  I don't see a countdown timer and the serial console just gives
Well, I got it to work by just counting to 3 in the boot and pulling the jumper
#55
Hmm...is it possible to use Arduino as serial console connection? It has been been mentioned, in the beginning of this thread, that chipsets cp2102, pl2303hx, ch340g works. What about Arduino? I have used Arduino to get serial console connection working with Nanopi Neo Air's
#56
(02-02-2019, 01:35 AM)miha Wrote: Hmm...is it possible to use Arduino as serial console connection? It has been been mentioned, in the beginning of this thread, that chipsets cp2102, pl2303hx, ch340g works. What about Arduino? I have used Arduino to get serial console connection working with Nanopi Neo Air's
ROCK64 serial console UART speed set at 1,500,500, may be too high for Arduino to handle.
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,087 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 6,192 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 6,500 08-19-2021, 06:46 PM
Last Post: bcnaz
  Download IDB fail when trying to flash Android image cherkasoff 0 7,900 04-05-2020, 07:41 AM
Last Post: cherkasoff
  Receiving errors about eMMC (?) acasta 11 25,170 09-24-2019, 10:26 PM
Last Post: ridgarou
  USB -> eMMC is now available. Luke 15 45,266 07-27-2019, 04:27 PM
  Rock 64 network error as soon as I try to write or read. georgegohl888 1 4,754 03-12-2019, 09:35 AM
Last Post: georgegohl888
  Rock64 scipy, numpy, scikit-image, matplotlib issue with pip3 ictele 0 3,247 02-05-2019, 05:41 PM
Last Post: ictele
  flash image to sd/emmc through ethernet LMM 0 3,508 02-04-2019, 07:36 AM
Last Post: LMM
  HW image transitions in Python gaggleoxfoggy 7 12,382 11-24-2018, 10:41 AM
Last Post: gaggleoxfoggy
