xhci-hcd xhci-hcd.6.auto: ERROR Transfer event for disabled endpoint
I am using 4.4.132-1075-rockchip-ayufan kernel on Rockpro64 4GB board.
I boot from PCIe  SSD as roofs  and USB3 connecting a Seagate 2TB hard drive.
I recently notice this error:
xhci-hcd xhci-hcd.6.auto: ERROR Transfer event for disabled endpoint or incorrect stream ring
How to solve the error?
Thanks in advance.
I was so annoyed by the mistake that I switched to Armbian. Since the error does not appear anymore.
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
(12-22-2018, 01:17 AM)Bullet64 Wrote: I was so annoyed by the mistake that I switched to Armbian. Since the error does not appear anymore.
For Rock64,  I switched to Armbian,  it seems pretty good to me,  the 4 cores are all using the maximum frequency of RK3328: 1.5 Ghz
Pine64 stocked image for Rock64 is limited to 1.2Ghz
For Rockpro64,  I assume,  in Armbian, it will use 2.0 Ghz to 2 big cores,  1.5Ghz for 4 LITTLE cores.
Could you confirm with me from your board?  Thank you in advance.
I have NanoPC T4 using the same RK3399 CPU as Rockpro64.   With Armbian,  I can achieve:  2.0 Ghz of 2 big cores,  1.5Ghz for 4 LITTLE cores, boot from NVMe as rootfs.
I don't know why  board manufactures are so conservative to use 1.8 Ghz for 2 big cores and 1.3Ghz for 4 LITTLE cores.
I think this screenshot will answer your questions.  Wink
https://nextcloud.frank-mankel.org/s/JqeaCiTxDHagqeC
3. RockPro64 v2.1
(12-23-2018, 01:15 PM)Bullet64 Wrote: I think this screenshot will answer your questions.  Wink
Looks really good to me.   I should start it with Armbian at beginning!
Now I need to reinstall all those software again:
Apache2, Tomcat, MySQL, Guacamole, Seafile, Nextcloud, PLEX etc... Huh
  USB3 xhci-hcd in SuperSpeed mode swan 0 3,415 05-11-2023, 05:35 AM
Last Post: swan
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 6,950 10-14-2022, 06:24 AM
Last Post: rwk-
  Using the PCIe slot of ROCKPro64 as EndPoint mode nonoriri 1 3,934 11-20-2021, 10:53 AM
Last Post: fire219
Question My Rockpro64 stopped booting with these error messages please help seaurchin 4 9,157 02-18-2021, 04:27 PM
Last Post: TRS-80
  cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2 kuerious 10 39,781 01-18-2019, 04:13 PM
Last Post: nuumio
