Problem with setting up SD Card Win10
Problem I have is every time I start the burn possess if formats the card then disconnects it and the install fails, then the card is re recognised by the computer. By then I get install failed error message. Using Win10
Using Phoenix Card software
32 Gig card
I ran Phoenix Card as administrator and went straight to burn (didn't format it) - Using Windows 10 64 Pro (latest Faster ring build)
OK I'll give it another go but I'm not formating it that program is so I can't stop that.
OK got that sorted now. Does it take long after booting up to install the software ?
On first powering on, it can take up to 10-15 minutes to fully boot up to the operating system that you chose. All startups after that will be much quicker.
If I've helped you with something, please leave a rating for my responses.
well i think over an hour was long enough. All I saw the the Pine screen.
(03-30-2016, 11:10 AM)montyflange Wrote: well i think over an hour was long enough. All I saw the the Pine screen.
Yeah, it shouldn't take that long. Not sure how to help in this point because i don't have my board yet to test Sad
Put XFce4 on. Can't adjust screen size or resolution so thats useless .
Couldn't get Pinea64_android_lollipop to start.
And stuck on the Pine A64 boot screen again . I can see this thing going in the draw to be forgotten about.
(03-30-2016, 05:34 PM)I see from another thread that you got it to finally get past the boot screen? What did you do to get it to fully boot?Thanks! montyflange Wrote: Put XFce4 on. Can't adjust screen size or resolution so thats useless .
  New RockPro64 Power Up Problem enorbet2 7 13,705 10-28-2023, 12:08 PM
Last Post: dkebler
  When setting locale what is the code for the United states? Nobot 2 5,292 04-24-2023, 05:59 AM
  dependency problem cerno 4 9,047 05-07-2021, 08:18 AM
Last Post: cerno
  How to boot from SD card on pinebook pro linux123 3 10,336 12-02-2020, 10:29 AM
Last Post: linux123
  Pinebook Pro- configuration aborts setting keyboard layout scroall 10 20,992 10-30-2020, 11:58 AM
Last Post: scroall
  Setting up QT for compiling on my desktop vincer 0 3,603 09-19-2020, 03:31 PM
Last Post: vincer
  micro sd card won't insert Samuel Venable 2 7,084 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 7,158 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 10,283 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 301,220 03-03-2020, 11:34 PM
Last Post: siyatalerja
