PCIe port specifications
I read that a lot of people have problems getting PCIe cards to work with the rockpro64.
However I'm starting to wonder if the board respects the PCIe standards in the correct way.
I can understand some drivers are not ready yet to support every card out there.
However what I noticed in my case, that my SATA PCIe card which I'm trying to get to work, get extremely hot.
To the point you can 'smell' the card due to the heat and you can't touch the heatsink on the different chips of the card.
After just a few seconds I need to shutdown the board because I'm afraid it would damage the card (or eventually catch fire?).
In my opinion this just shouldn't happen, putting the card in a regular PC doesn't lead to this kind of heat problems.
Has anyone else have similar experiences?
Best regards,
Jan
  Compatible PCIe Sata Controller spacebricker 1 4,898 02-06-2023, 10:03 AM
Last Post: diizzy
  PCIe bifurcation support (on RK3399) Arn 1 4,913 11-28-2022, 05:12 PM
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 7,097 11-27-2021, 11:38 PM
Last Post: Cerberus
  Carte PCIe bloquant le démarrage du Noyau / PCIe card blocking Kernel boot dml-pc 4 8,964 02-17-2021, 11:35 AM
Last Post: dml-pc
  Specifications of fan connectors? kuleszdl 3 5,793 02-14-2021, 07:32 AM
Last Post: kuleszdl
  Nvidia GPU on PCIe User 18962 4 8,295 12-22-2020, 02:54 PM
Last Post: amiraeva
Question RockPro64 Lithium Battery Port TitleOS 0 3,126 12-05-2020, 12:35 AM
Last Post: TitleOS
  Won't boot with 2.5GBe PCIe adaptor connected voltagex 1 4,764 10-20-2020, 12:22 PM
Last Post: xmixahlx
  NAS mods: external serial port and power button foresto 4 11,257 10-04-2020, 11:21 PM
Last Post: zer0sig
  Cheap 4-port SATA card working with RockPro64 4Gb andyburn 6 16,282 08-10-2020, 08:36 PM
Last Post: zer0sig
