pinebook 14" sd card slot stopped working
Anyone run into this issue on the 14" pinebook?  I can't boot from the sd card nor does it see it after I boot from the eMMC. I had to disassemble it to remove the eMMC storage to flash via the eMMC to micro sd card adapter on another computer.  I can see/mount/read a thumb drive plugged into the usb port on the same daughter card that the micro sd card reader is on.  Not sure what device to search for in dmesg for this micro sd card reader or what to check.
(11-28-2018, 03:52 PM)eclay Wrote: Anyone run into this issue on the 14" pinebook?  I can't boot from the sd card nor does it see it after I boot from the eMMC. I had to disassemble it to remove the eMMC storage to flash via the eMMC to micro sd card adapter on another computer.  I can see/mount/read a thumb drive plugged into the usb port on the same daughter card that the micro sd card reader is on.  Not sure what device to search for in dmesg for this micro sd card reader or what to check.
looks like your SD card bootable image already corrupted?
I do not believe so since I put in a brand new samsung evo sd card into the slot after booting up via the eMMC storage device and it still couldn't see the sd storage which could be seen and mounted on my laptop.  I see the following in the dmesg results.
[  268.213539] sunxi-mmc 1c0f000.mmc: no support for card's volts [  268.213555] mmc0: error -22 whilst initialising SDIO card [  271.317294] sunxi-mmc 1c0f000.mmc: no support for card's volts [  271.317309] mmc0: error -22 whilst initialising SDIO card [  274.421102] sunxi-mmc 1c0f000.mmc: no support for card's volts [  274.421118] mmc0: error -22 whilst initialising SDIO card [  275.477006] sunxi-mmc 1c0f000.mmc: no support for card's volts [  275.477023] mmc0: error -22 whilst initialising SDIO card [  276.531823] sunxi-mmc 1c0f000.mmc: no support for card's volts [  276.531839] mmc0: error -22 whilst initialising SDIO card [  277.588847] sunxi-mmc 1c0f000.mmc: no support for card's volts [  277.588863] mmc0: error -22 whilst initialising SDIO card [  278.643564] sunxi-mmc 1c0f000.mmc: no support for card's volts [  278.643578] mmc0: error -22 whilst initialising SDIO card [  279.700530] sunxi-mmc 1c0f000.mmc: no support for card's volts [  279.700542] mmc0: error -22 whilst initialising SDIO card [  280.756534] sunxi-mmc 1c0f000.mmc: no support for card's volts [  280.756551] mmc0: error -22 whilst initialising SDIO card [  281.812469] sunxi-mmc 1c0f000.mmc: no support for card's volts [  281.812483] mmc0: error -22 whilst initialising SDIO card [  282.868261] sunxi-mmc 1c0f000.mmc: no support for card's volts [  282.868275] mmc0: error -22 whilst initialising SDIO card [  283.924234] sunxi-mmc 1c0f000.mmc: no support for card's volts [  283.924249] mmc0: error -22 whilst initialising SDIO card [  284.980031] sunxi-mmc 1c0f000.mmc: no support for card's volts [  284.980047] mmc0: error -22 whilst initialising SDIO card [  286.035978] sunxi-mmc 1c0f000.mmc: no support for card's volts [  286.035996] mmc0: error -22 whilst initialising SDIO card [  287.091771] sunxi-mmc 1c0f000.mmc: no support for card's volts [  287.091787] mmc0: error -22 whilst initialising SDIO card [  288.147663] sunxi-mmc 1c0f000.mmc: no support for card's volts [  288.147677] mmc0: error -22 whilst initialising SDIO card [  289.203553] sunxi-mmc 1c0f000.mmc: no support for card's volts [  289.203569] mmc0: error -22 whilst initialising SDIO card [  290.259446] sunxi-mmc 1c0f000.mmc: no support for card's volts [  290.259461] mmc0: error -22 whilst initialising SDIO card [  291.315398] sunxi-mmc 1c0f000.mmc: no support for card's volts [  291.315414] mmc0: error -22 whilst initialising SDIO card [  292.371190] sunxi-mmc 1c0f000.mmc: no support for card's volts [  292.371207] mmc0: error -22 whilst initialising SDIO card [  293.427063] sunxi-mmc 1c0f000.mmc: no support for card's volts [  293.427076] mmc0: error -22 whilst initialising SDIO card [  294.482912] sunxi-mmc 1c0f000.mmc: no support for card's volts [  294.482927] mmc0: error -22 whilst initialising SDIO card [  295.538773] sunxi-mmc 1c0f000.mmc: no support for card's volts [  295.538789] mmc0: error -22 whilst initialising SDIO card [  296.594732] sunxi-mmc 1c0f000.mmc: no support for card's volts [  296.594746] mmc0: error -22 whilst initialising SDIO card [  297.650701] sunxi-mmc 1c0f000.mmc: no support for card's volts [  297.650714] mmc0: error -22 whilst initialising SDIO card [  298.706634] sunxi-mmc 1c0f000.mmc: no support for card's volts [  298.706648] mmc0: error -22 whilst initialising SDIO card [  299.762590] sunxi-mmc 1c0f000.mmc: no support for card's volts [  299.762604] mmc0: error -22 whilst initialising SDIO card [  300.818558] sunxi-mmc 1c0f000.mmc: no support for card's volts [  300.818574] mmc0: error -22 whilst initialising SDIO card [  301.874503] sunxi-mmc 1c0f000.mmc: no support for card's volts [  301.874517] mmc0: error -22 whilst initialising SDIO card [  302.930412] sunxi-mmc 1c0f000.mmc: no support for card's volts [  302.930427] mmc0: error -22 whilst initialising SDIO card [  303.986392] sunxi-mmc 1c0f000.mmc: no support for card's volts [  303.986410] mmc0: error -22 whilst initialising SDIO card [  305.042288] sunxi-mmc 1c0f000.mmc: no support for card's volts [  305.042303] mmc0: error -22 whilst initialising SDIO card [  306.098172] sunxi-mmc 1c0f000.mmc: no support for card's volts [  306.098188] mmc0: error -22 whilst initialising SDIO card [  307.154150] sunxi-mmc 1c0f000.mmc: no support for card's volts [  307.154166] mmc0: error -22 whilst initialising SDIO card [  308.209996] sunxi-mmc 1c0f000.mmc: no support for card's volts [  308.210009] mmc0: error -22 whilst initialising SDIO card [  309.265945] sunxi-mmc 1c0f000.mmc: no support for card's volts [  309.265961] mmc0: error -22 whilst initialising SDIO card [  310.321835] sunxi-mmc 1c0f000.mmc: no support for card's volts [  310.321848] mmc0: error -22 whilst initialising SDIO card [  311.377784] sunxi-mmc 1c0f000.mmc: no support for card's volts [  311.377802] mmc0: error -22 whilst initialising SDIO card [  312.433640] sunxi-mmc 1c0f000.mmc: no support for card's volts [  312.433653] mmc0: error -22 whilst initialising SDIO card [  313.489545] sunxi-mmc 1c0f000.mmc: no support for card's volts [  313.489559] mmc0: error -22 whilst initialising SDIO card [  314.545450] sunxi-mmc 1c0f000.mmc: no support for card's volts [  314.545464] mmc0: error -22 whilst initialising SDIO card [  315.601317] sunxi-mmc 1c0f000.mmc: no support for card's volts [  315.601331] mmc0: error -22 whilst initialising SDIO card [  316.657257] sunxi-mmc 1c0f000.mmc: no support for card's volts [  316.657273] mmc0: error -22 whilst initialising SDIO card [  317.713125] sunxi-mmc 1c0f000.mmc: no support for card's volts [  317.713140] mmc0: error -22 whilst initialising SDIO card [  318.769033] sunxi-mmc 1c0f000.mmc: no support for card's volts [  318.769048] mmc0: error -22 whilst initialising SDIO card [  319.824843] sunxi-mmc 1c0f000.mmc: no support for card's volts [  319.824860] mmc0: error -22 whilst initialising SDIO card [  320.880787] sunxi-mmc 1c0f000.mmc: no support for card's volts [  320.880800] mmc0: error -22 whilst initialising SDIO card [  321.936656] sunxi-mmc 1c0f000.mmc: no support for card's volts [  321.936673] mmc0: error -22 whilst initialising SDIO card [  322.992538] sunxi-mmc 1c0f000.mmc: no support for card's volts [  322.992554] mmc0: error -22 whilst initialising SDIO card [  324.047240] sunxi-mmc 1c0f000.mmc: no support for card's volts [  324.047253] mmc0: error -22 whilst initialising SDIO card [  325.104177] sunxi-mmc 1c0f000.mmc: no support for card's volts [  325.104188] mmc0: error -22 whilst initialising SDIO card [  326.160244] sunxi-mmc 1c0f000.mmc: no support for card's volts [  326.160261] mmc0: error -22 whilst initialising SDIO card [  327.215931] sunxi-mmc 1c0f000.mmc: no support for card's volts [  327.215944] mmc0: error -22 whilst initialising SDIO card [  328.271799] sunxi-mmc 1c0f000.mmc: no support for card's volts [  328.271812] mmc0: error -22 whilst initialising SDIO card [  329.327733] sunxi-mmc 1c0f000.mmc: no support for card's volts [  329.327750] mmc0: error -22 whilst initialising SDIO card [  330.383657] sunxi-mmc 1c0f000.mmc: no support for card's volts [  330.383675] mmc0: error -22 whilst initialising SDIO card [  331.439494] sunxi-mmc 1c0f000.mmc: no support for card's volts [  331.439508] mmc0: error -22 whilst initialising SDIO card [  332.495283] sunxi-mmc 1c0f000.mmc: no support for card's volts [  332.495294] mmc0: error -22 whilst initialising SDIO card [  333.551129] sunxi-mmc 1c0f000.mmc: no support for card's volts [  333.551143] mmc0: error -22 whilst initialising SDIO card [  334.607011] sunxi-mmc 1c0f000.mmc: no support for card's volts [  334.607024] mmc0: error -22 whilst initialising SDIO card [  335.662933] sunxi-mmc 1c0f000.mmc: no support for card's volts [  335.662949] mmc0: error -22 whilst initialising SDIO card [  336.718771] sunxi-mmc 1c0f000.mmc: no support for card's volts [  336.718787] mmc0: error -22 whilst initialising SDIO card [  337.774636] sunxi-mmc 1c0f000.mmc: no support for card's volts [  337.774650] mmc0: error -22 whilst initialising SDIO card [  338.830462] sunxi-mmc 1c0f000.mmc: no support for card's volts [  338.830479] mmc0: error -22 whilst initialising SDIO card [  339.886371] sunxi-mmc 1c0f000.mmc: no support for card's volts [  339.886387] mmc0: error -22 whilst initialising SDIO card
I get these message when attempting to insert  128G or 32G samsung evo or a 32G sandisk red and grey card.  All of which are readable in my main laptop.
it could possibly be, an outside chance, that the metal tabs of the sd card slot are not making good enough contact with the card itself. the solution that once helped me on a different device was to use fine long tweezers to gently lift up each tab just a very little bit and then try it and repeat a few times until that possibility either works or not. not sure if you can get clear shot at the tabs on the pinebook or not but be very careful in any mod.
  Running Pinebook (non-Pro) without battery? guidol 0 3,083 11-09-2025, 04:19 AM
Last Post: guidol
  Anyone selling a Pinebook ams 2 12,274 09-08-2025, 09:26 AM
Last Post: ams
  Giving away a Pinebook Pro for free (with a broken hinge) tuxifan 4 7,186 09-01-2025, 12:24 AM
Last Post: alchemist
  pinebook 1080p power/barrel connector/cable cel 0 2,901 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 4,323 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 4,245 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 5,906 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 8,835 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 6,814 09-25-2021, 12:03 AM
  SD card read/write troubles jezek 1 6,702 03-26-2021, 09:27 AM
Last Post: jezek
