Screen halo?
Hey.
I've got a new 1080p pinebook but mine is suffering from what I can only describe as a "screen halo". Is this normal, or does my pinebook have a defect?
It's on all four sides but the left and right sides are the most visible.
Thanks for reading!
[Image: gXpu0Qc.jpg][Image: X6FVa9J.jpg]
This is not normal. When using for a week and the halo effect still there, please file a RMA ticket at http://support.pine64.org
(11-19-2018, 11:44 PM)tllim Wrote: This is not normal. When using for a week and the halo effect still there, please file a RMA ticket at http://support.pine64.org
I tried but the support person said they couldn't see an issue. My display is also now flickering (as seen here) https://youtu.be/oAeQd_4agfk https://support.pine64.org/portal/ticket/2897
https://imgur.com/a/B9wIo0f
Here are a variety of images (and a gif of the flickering that just started less than 12 hours ago) compiled into a single post.
My screen has developed a halo too Sad
(12-08-2018, 04:18 AM)ImmortanJoe Wrote: My screen has developed a halo too Sad
Same here though it's not as pronounced as the image above.
I have a slightly lighter part of screen near the bottom border (a little to the left from center, roughly above start of "Pinebook" text on the screen). It's like display's backlight is a bit brighter in this area. If I slightly press my finger against screen's border to the left of "P" letter, backlight comes to normal. When I remove pressure, screen backlight there again would become slightly brighter.
It's nowhere as massive and pronounced, though, as in this post (and I'm perfectly fine with that). In my case it's just one spot, rather than entire screen border. I assume halo problem got something to do with misalignment of IPS panel and display case (or, perhaps, excessive pressure/bending of IPS panel by the case), i.e. defect during assembly, rather than IPS panel itself.
I know this is an old thread, just hoping this helps anyone who runs into the same issue...
I just had the same issue with my Pinebook Pro (early 2020). I closed the lid to suspend to suspend the machine, and when I reopened it a few hours later, the screen was garbled and there was a pronounced "halo" effect around the edges, just like the OP. After rebooting, the screen was no longer garbled, but the halo effect persisted and on dark screens there appeared to be burn-in from one of the windows I had open. I suspect it never suspended... Fortunately, I gave one of those LCD burn-in fix videos a try. After about an hour and a half, everything was completely back to normal. Woohoo!
Here's the one I used, but I suspect any in full screen with the right aspect ratio would work too.
https://www.youtube.com/watch?v=39HUG7QrQi8
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 5,509 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook 14" smashed screen. frank-zappa 4 13,759 10-18-2020, 09:24 AM
  Screen staying dark. ocschwar 2 8,114 07-18-2020, 04:54 PM
Last Post: ocschwar
  Screen resolution heywire 5 11,782 04-03-2019, 01:42 PM
Last Post: bigCamel
  DCOP communications error (Welcome screen) jschall 2 6,044 11-17-2018, 02:33 PM
Last Post: jschall
  How to adjust screen brightness? jschall 4 10,833 11-15-2018, 12:38 PM
Last Post: jschall
  Just broke the screen on this POS. Anyone need parts?? Nierika 1 4,951 10-20-2018, 03:58 PM
Last Post: soupbowl
  Read if you experience issues with screen flickering Luke 18 42,598 10-15-2017, 06:43 AM
Last Post: Luke
Question Read if your Pinebook arrived with Cracked Screen from DHL MarkHaysHarris777 0 3,384 08-17-2017, 02:08 AM
Last Post: MarkHaysHarris777
  DHL delivered Pinebook with broken screen please help. Sudoapt-getburrito 15 27,381 08-16-2017, 03:39 PM
Last Post: Luke
