Not able to write u-boot to SPI
Hello everyone.
I have a trouble flashing uboot to my RockPro64 4GB variant. I am trying to use rock64_write_spi_flash.sh script, but nothing is flashing.
I made all steps according to wiki, booted from SD card, used latest ubuntu image, but everything I get is following error:
rock64@rockpro64:/dev$ sudo su [sudo] password for rock64: root@rockpro64:/dev# rock64_write_spi_flash.sh Doing this will overwrite data stored on SPI Flash  and it will require that you use eMMC or SD  as your boot device. Type YES to continue or Ctrl-C to abort. YES Writing /dev/mtd0 with content of /usr/lib/u-boot-rockpro64/rkspi_loader.img Erasing 4 Kibyte @ 0 --  0 % complete libmtd: error!: MEMERASE64 ioctl failed for eraseblock 0 (mtd0)        error 110 (Connection timed out) flash_erase: error!: /dev/mtd0: MTD Erase failure             error 110 (Connection timed out) Erasing 4 Kibyte @ 1000 --  0 % complete libmtd: error!: MEMERASE64 ioctl failed for eraseblock 1 (mtd0)        error 110 (Connection timed out) flash_erase: error!: /dev/mtd0: MTD Erase failure             error 110 (Connection timed out) Erasing 4 Kibyte @ 2000 --  0 % complete libmtd: error!: MEMERASE64 ioctl failed for eraseblock 2 (mtd0)        error 110 (Connection timed out) flash_erase: error!: /dev/mtd0: MTD Erase failure             error 110 (Connection timed out) Erasing 4 Kibyte @ 3000 --  0 % complete libmtd: error!: MEMERASE64 ioctl failed for eraseblock 3 (mtd0)        error 110 (Connection timed out) flash_erase: error!: /dev/mtd0: MTD Erase failure             error 110 (Connection timed out) Erasing 4 Kibyte @ 4000 --  0 % complete libmtd: error!: MEMERASE64 ioctl failed for eraseblock 4 (mtd0)        error 110 (Connection timed out) flash_erase: error!: /dev/mtd0: MTD Erase failure             error 110 (Connection timed out) Erasing 4 Kibyte @ 5000 --  0 % complete ^C^C
I have even tried steps written here: https://forum.pine64.org/showthread.php?...e#pid40677   (,only changed the overlay address to "ff1d0000" to fit to RockPro64 dts).
I never flashed anything to SPI before, so it can't be messed up. I tried the SD card method with only ayufan uboot image and this don't work either. Nothing is written to it..
Output of "mtdinfo":
root@rockpro64:/dev# mtdinfo Count of MTD devices:           3 Present MTD devices:            mtd0, mtd1, mtd2 Sysfs interface supported:      yes root@rockpro64:/dev# mtdinfo /dev/mtd0 mtd0 Name:                           loader Type:                           nor Eraseblock size:                4096 bytes, 4.0 KiB Amount of eraseblocks:          1016 (4161536 bytes, 4.0 MiB) Minimum input/output unit size: 1 byte Sub-page size:                  1 byte Character device major/minor:   90:0 Bad blocks are allowed:         false Device is writable:             true root@rockpro64:/dev# mtdinfo /dev/mtd1 mtd1 Name:                           env Type:                           nor Eraseblock size:                4096 bytes, 4.0 KiB Amount of eraseblocks:          8 (32768 bytes, 32.0 KiB) Minimum input/output unit size: 1 byte Sub-page size:                  1 byte Character device major/minor:   90:2 Bad blocks are allowed:         false Device is writable:             true root@rockpro64:/dev# mtdinfo /dev/mtd2 mtd2 Name:                           vendor Type:                           nor Eraseblock size:                4096 bytes, 4.0 KiB Amount of eraseblocks:          64 (262144 bytes, 256.0 KiB) Minimum input/output unit size: 1 byte Sub-page size:                  1 byte Character device major/minor:   90:4 Bad blocks are allowed:         false Device is writable:             true
Output of dmesg:
root@rockpro64:/dev# dmesg | grep spi [    2.015555] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel [    2.016160] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel [    2.016778] rockchip-spi ff1d0000.spi: no high_speed pinctrl state [    2.017904] m25p80 spi32766.0: gd25q128 (16384 Kbytes) [    2.018394] 3 ofpart partitions found on MTD device spi32766.0 [    2.018924] Creating 3 MTD partitions on "spi32766.0": [  164.537097] m25p80 spi32766.0: flash operation timed out [  204.537255] m25p80 spi32766.0: flash operation timed out [  244.537347] m25p80 spi32766.0: flash operation timed out [  284.537402] m25p80 spi32766.0: flash operation timed out [  324.537509] m25p80 spi32766.0: flash operation timed out [  364.537587] m25p80 spi32766.0: flash operation timed out
Thanks for any suggestions. This is really driving me nuts.. Any help will be appreciated.. :-)
Hi! I have same issue.I tried all roms from https://github.com/ayufan-rock64/linux-build/releases
I found two solution:
1. https://github.com/ayufan-rock64/linux-u-boot/releases write image and do boot, spi will be writen, white led will blinking.
2. I was able to flash SPI using http://wiki.pine64.org/index.php/ROCKPro...htly_Build , do download files from first link in os
Please use this image to write to spi.
https://github.com/ayufan-rock64/linux-u...o64.img.xz
Quick test
U-Boot SPL 2017.09-rockchip-ayufan-1035-gd646df03ac (Oct 26 2018 - 08:36:09)     booted from SD        Trying to boot from MMC2                                                         NOTICE:  BL31: v1.3(debug):65aa5ce                                               NOTICE:  BL31: Built : 10:47:37, Jun 19 2018                                     NOTICE:  BL31: Rockchip release version: v1.1                                   INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO:    Using opteed sec cpu_context!                                           INFO:    boot cpu mask: 0                                                       INFO:    plat_rockchip_pmu_init(1151): pd status 3e                             INFO:    BL31: Initializing runtime services                                     WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE iniK ERROR:   Error initializing runtime service opteed_fast                         INFO:    BL31: Preparing for EL3 exit to normal world                           INFO:    Entry point address = 0x200000                                         INFO:    SPSR = 0x3c9        U-Boot 2017.09-rockchip-ayufan-1035-gd646df03ac (Oct 26 2018 - 08:36:24 +0000)        Model: Pine64 RockPro64                                                         DRAM:  2 GiB        DCDC_REG1@vdd_center: ; enabling                                                 DCDC_REG2@vdd_cpu_l: ; enabling                                                 DCDC_REG3@vcc_ddr: ; enabling (ret: -38)                                         DCDC_REG4@vcc_1v8: set 1800000 uV; enabling                                     LDO_REG1@vcc1v8_dvp: set 1800000 uV; enabling                                   LDO_REG2@vcc3v0_touch: set 3000000 uV; enabling                                 LDO_REG3@vcc1v8_pmu: set 1800000 uV; enabling                                   LDO_REG4@vcc_sd: set 3300000 uV; enabling                                       LDO_REG5@vcca3v0_codec: set 3000000 uV; enabling                                 LDO_REG6@vcc_1v5: set 1500000 uV; enabling                                       LDO_REG7@vcca1v8_codec: set 1800000 uV; enabling                                 LDO_REG8@vcc_3v0: set 3000000 uV; enabling                                       SWITCH_REG1@vcc3v3_s3: ; enabling (ret: -38)                                     SWITCH_REG2@vcc3v3_s0: ; enabling (ret: -38)                                     vcc1v8-s0@vcc1v8_s0: set 1800000 uV; enabling (ret: -38)                         dc-12v@dc_12v: set 12000000 uV; enabling (ret: -38)                             vcc-sys@vcc_sys: set 5000000 uV; enabling (ret: -38)                             vcc3v3-sys@vcc3v3_sys: set 3300000 uV; enabling (ret: -38)                       vcc-phy-regulator@vcc_phy: ; enabling (ret: -38)                                 vdd-log@vdd_log: ; enabling (ret: -38)                                           MMC:   sdhci@fe330000: 0, dwmmc@fe320000: 1                                     SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB   *** Warning - bad CRC, using default environment        In:    serial@ff1a0000                                                           Out:   serial@ff1a0000                                                           Err:   serial@ff1a0000                                                           Model: Pine64 RockPro64                                                         Net:   eth0: ethernet@fe300000                                                   Hit any key to stop autoboot:  0                                                 Card did not respond to voltage select!                                         mmc_init: -95, time 19                                                           switch to partitions #0, OK                                                     mmc1 is current device                                                           Scanning mmc 1:2...                                                             Found U-Boot script /boot.scr                                                   reading /boot.scr                                                               827 bytes read in 3 ms (268.6 KiB/s)                                             ## Executing script at 00500000                                                 SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB   reading rkspi_loader.img                                                         1461372 bytes read in 156 ms (8.9 MiB/s)                                         SF: 4194304 bytes @ 0x0 Erased: OK                                               device 0 offset 0x0, size 0x164c7c                                               SF: 1461372 bytes @ 0x0 Written: OK
And please use image for rockpro64 Exclamation
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 13,084 06-21-2025, 06:21 AM
Last Post: aleksei
  enble boot after power loss/restore dkebler 18 31,076 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 230,598 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 4,725 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 14,111 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 14,453 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 4,726 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 20,340 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 3,650 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 8,215 07-02-2022, 09:24 AM
Last Post: dkebler
