Stock Android Oreo 8.1 release
#41
(10-09-2018, 08:31 PM)fusionneur Wrote: I tried several times flashing 8.1 with AndroidTool on EMMC, but after first reboot all I get is a black screen. 7.1.2 works fine however. Any1 managed to flash 8.1 on EMMC? (if yes, how??)
Same for me, pal. Don't know who is that release built for...
I will ask QA to recheck the A8.1 on eMMC boot build.
Will there be any changes with that non-bootable oreo 8.1?
Flashing via usb2emmc adaptor makes non-usable image which boots to recovery page and that's all.
rock64&4Gb
And can anybody tell whether this 8.1 will support bluetooth usb probably ?
Asking took too long, where is result?
Please could you at least include navigation bar and status bar in the next build? Otherwise the board is absolutely unusable with a touchscreen
(08-03-2018, 12:36 AM)kostaman Wrote:
(08-02-2018, 11:52 AM)dougunder Wrote: I created with dd directly to usb mmc.
It boots but freezes. It does it enough to be unusable.
Same result with every Android image on either  mmc or sdcard excluding Android 7.1.2 Stock Image.
4GB boards are lemons  Angry
Use Pine Installer. I tested Android stock on eMMC and preferred ayufan Android TV .
I also run LibreELEC devel-20180708142741-4dc93d7 SD Card
Very good results. Whilst not 100% these images are over 90% stable.
Android TV is very stable. Kodi from App Store works. Refresh rate change working as well.
Give it a shot and then retract the lemon quote.
You purchased a Development Board. So you are a tester as well as all others in various forums.
Been a linux admin for 20years. I know what I'm doing with disk imaging,
This POS lives in a drawer now, I bought a "development" board that actually works, an odroid c2.
None of these problems.
I will not buy another pine device.
I also have the same issue that after logo is black screen
2nd option don't work :
>>DD image to eMMC module. Highly recommend using Etcher
[url=https://etcher.io/][/url]
Etcher don't recognize the unit  Exclamation
use this one has no issue Android 7.1.2 Stock Image [microSD to eMMC] [Rooted] [20171204] Idea
Will there be Android 8.1 [microSD to eMMC] built ?
I also have same problem flashing to eMMC with option 1 - black screen after logo
Option 2 -
Not recognize the unit
Will there be [microsd->eMMC] like android 7.1.2? Thanks a lot
Using android 7.1.2 on eMMC with this option now
Has anyone got Bluetooth working on Android 8.1? Just wondering as I haven't been able to get it to work on 7.1, and I gave up on 8 momentarily due to experiencing a whole lot more slowness than in 7.1 (I'm using the 4GB Rock64, SD card).
I can confirm that Android 8.1. Stock Image [eMMC Boot] using ROCKChip tools method [20180606] worked for me. There is preinstalled Google Play Store , which is not in Android 9.x. However, when you go to Google Play Store it tells you:
Quote:This version of the app isn't compatible with your device. To fix this problem, go to Settings and uninstall updates for the Google Play Store app.
Which of course, does not work.
// EDIT: Downloading the latest version of Google Play Store (Android TV)  as .apk worked! Unfortunately, the same does not work on Android 9.x.
  Android Images (ROCK64) pineadmin 77 245,300 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,349 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,637 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,793 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,812 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,515 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,691 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,345 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,612 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,974 09-18-2020, 07:58 PM
Last Post: BowerR64
