LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs
(10-16-2018, 05:00 AM)icehot Wrote: Hi!. I hava a Odroid C2 with rb-krypton19. Now I'm buying an ROCK64. I need the rb-krypton19 for ROCK64 IMG file. Github has delete all IMG files for all versions.
Have anyone a backup of krypton19 IMG?.
Thanks a lot.
Do you want to complier a rb-krypton19 version for ROCK64 ?
LibreELEC-Odroid_C2.arm-8.2-rb-krypton19.img.gz
New libreelec alpha release, just for everyone here watching:
https://libreelec.tv/2018/11/libreelec-l...007-alpha/
New LibreELEC BETA image for the Rock64 is now available.
Hi, I have a problem with my new Rock64 and Libreelec (Leia). The problem is when I click in a movie this starts but in green not with real colors. It happends several times. The thing that I do to correct this is to select another movie and the return to the first one and it is solved. The addon that I use is Exodus Redux
The other problem that I have is with the Addon Exodus Redux, when I want to see the trailer of a movie the Rock64 reboots every time I do this. No matter the movie it always does the same.
Until now those are the erros that I have with my new Rock64 and Libreelec.
Can anyone tell me if the same happends to you and how can I fix this?
Thanks.
  How to boot an older, working kernel bits 0 3,165 11-01-2024, 04:43 PM
Last Post: bits
  Libreelec nfs shares nberg@xs4all.nl 0 2,118 11-11-2022, 01:18 PM
Last Post: nberg@xs4all.nl
  Linux 5.15 Kernel - openSuse mark1250 0 3,087 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 14,817 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian kernel stuck at 4.4.167 Enig123 5 11,008 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 22,494 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 7,627 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 12,534 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 8,241 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 3,717 02-05-2020, 10:58 PM
Last Post: dkebler
