Debian (Raspbian-like)
Lightbulb
Please consider a Raspbian-like build from Debian to run on this hardware.
(12-20-2015, 03:54 AM)Pander Wrote: Please consider a Raspbian-like build from Debian to run on this hardware.
Please advise why need to be "Paspbian-like" and the benefit. Thanks.
Yes im also interested to make default system like Raspbian instead of Ubuntu. I want to use Debian based distro, not Ubuntu.
EDIT: This is good starting point, what systems must be supported by default for PINE64+
http://www.hardkernel.com/main/products/...3703355573
Allot of "howto" are written by the Raspberry Pi community. These are mostly written with Debian Linux in mind (Raspbian).
Ubuntu has a deep connection with Debian as well.
+1 for making easy to use, debian instalation image for Pine64.
+1 for Pine Corp, choosing Debian as recommend distribution to foster easy migration for pi user over to pine64.
(12-29-2015, 07:31 AM)deanMKD Wrote: Yes im also interested to make default system like Raspbian instead of Ubuntu. I want to use Debian based distro, not Ubuntu.
Noted.
Couldn't be more pleased if this come to a reality. "Debian... What else?" ;-)
Guess where my aka is coming from...
A+
Debcool
Et si je poussais une longue plainte déchirante pudiquement masquée sous la morsure cinglante de mon humour ravageur! Pierre Desproge
I also would be delighted if debian ran on this board.
(12-30-2015, 06:46 AM)Ketsa Wrote: I also would be delighted if debian ran on this board.
If it can run Ubuntu. It can run debian..
Ubuntu is built off the foundation Debian.
~ B
As a Raspbery Pi user (and Pine64 KickStarter backer) I +1 Debian!
~ B
Using arm64 images? https://www.debian.org/distrib/netinst
  Arch, Debian or other for Pinebook? cootcraig 3 11,662 05-01-2019, 09:11 AM
Last Post: cootcraig
  Found this fully working RASPBIAN Image that boots to desktop speedro86 21 45,238 10-07-2017, 10:06 PM
Last Post: speedro86
  Pine64 will be supported by HypriotOS (a Debian Jessie based OS for running Docker) Quintus23M 9 26,077 02-03-2017, 05:50 AM
Last Post: pfeerick
  Netatalk on Debian pictus 10 22,332 09-28-2016, 08:01 AM
Last Post: wojciech_czyz
  How to make multicast working on ubuntu and debian brengthdom 3 10,683 09-18-2016, 02:05 PM
Last Post: brengthdom
  SSH for noobs on Debian robertnew 12 30,762 05-07-2016, 08:02 AM
Last Post: Leoncito81
  Minimal 64bit ARM RootFS for Debian and Ubuntu umiddelb 46 108,331 03-06-2016, 10:28 AM
Last Post: umiddelb
  1st Debian image and further information umiddelb 13 32,697 03-04-2016, 02:08 AM
Last Post: umiddelb
