Pinebook accessories (emmc usb card)
If I see the "options available" correct for the Pinebook, it shows an EMMC _USB card to mount the upgrade/purchased 64gb EMMC and ai can etch it directly to the EMMC.... allowing me access to install it into the Pinebook.  (Am I seeing that correctly?  (Is the Pinebook internal accessible to install the larger flashed 64mb EMMC myself?)
If not, then I do not need the EMMC_USB card for flashing EMMC memory internal to the PINEBOOK.
2) Micro SD sdxc Class 10 memory.  Other vendors also show and reference the SD-UHS1 class 10 card as a double performance in read and write over the offered Class 10 sdxc card.
As long as it is class 10, it should be identifiable, I assume the increase in read/write will be the same on PineBook.
(ANYONE VERIFY THAT AS BEING THE CASE FOR PINEBOOK OR PINE CARDS?)
3) WHAT IS THE LARGEST Micro sdxc in MB the Pinebook can identify? 256mb or higher?
4)I will image the EMMC with the OS.  Can I specify the MicroSD as data storage location? in addition to using the EMMC for OS/Programs.
5) I have nice Linux Nas(2) I will backup the Pinebook to regularly.
I need to identify software that will allow me to map/see network and attach to / map to external drives (nas). Unless that is included in KUBUNTU.  I am just now starting to read up on it.
If you have any specific info to direct me to please do so.  I called myself looking THOROUGHLY through website for specific answers abut none were shown.
Thank you again,
Alton
  Running Pinebook (non-Pro) without battery? guidol 0 3,034 11-09-2025, 04:19 AM
Last Post: guidol
  Anyone selling a Pinebook ams 2 12,233 09-08-2025, 09:26 AM
Last Post: ams
  Giving away a Pinebook Pro for free (with a broken hinge) tuxifan 4 7,166 09-01-2025, 12:24 AM
Last Post: alchemist
  pinebook 1080p power/barrel connector/cable cel 0 2,885 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 4,306 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 4,222 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 5,887 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 8,815 01-03-2022, 03:28 AM
Last Post: kqlnut
  Manjaro/Cinnamon customised on sdcard: how to transfer to emmc? quixote 0 4,478 10-16-2021, 02:03 PM
Last Post: quixote
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 6,791 09-25-2021, 12:03 AM
