Rockpro64 Sata Card kills itself
This card is not happy......Anyone know what is going on?? I have a RockPro64 V 2.1 ,ASMedia ASM1061 (THe one that Pine sells) and a, Samsung 860 EVO SSD 1TB
[  129.267142] ata2.00: exception Emask 0x10 SAct 0x7ffeffff SErr 0x400000 action 0x6 frozen [  129.268423] ata2.00: irq_stat 0x08000000, interface fatal error [  129.269429] ata2: SError: { Handshk } [  129.270033] ata2.00: failed command: WRITE FPDMA QUEUED [  129.270841] ata2.00: cmd 61/00:00:00:40:05/08:00:01:00:00/40 tag 0 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.273136] ata2.00: status: { DRDY } [  129.273696] ata2.00: failed command: WRITE FPDMA QUEUED [  129.274526] ata2.00: cmd 61/00:08:00:48:05/08:00:01:00:00/40 tag 1 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.276794] ata2.00: status: { DRDY } [  129.277380] ata2.00: failed command: WRITE FPDMA QUEUED [  129.278209] ata2.00: cmd 61/00:10:00:50:05/08:00:01:00:00/40 tag 2 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.280473] ata2.00: status: { DRDY } [  129.281056] ata2.00: failed command: WRITE FPDMA QUEUED [  129.281883] ata2.00: cmd 61/00:18:00:58:05/08:00:01:00:00/40 tag 3 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.284149] ata2.00: status: { DRDY } [  129.284707] ata2.00: failed command: WRITE FPDMA QUEUED [  129.285535] ata2.00: cmd 61/00:20:00:60:05/08:00:01:00:00/40 tag 4 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.287800] ata2.00: status: { DRDY } [  129.288382] ata2.00: failed command: WRITE FPDMA QUEUED [  129.289224] ata2.00: cmd 61/00:28:00:68:05/08:00:01:00:00/40 tag 5 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.291506] ata2.00: status: { DRDY } [  129.292094] ata2.00: failed command: WRITE FPDMA QUEUED [  129.292924] ata2.00: cmd 61/00:30:00:70:05/08:00:01:00:00/40 tag 6 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.295190] ata2.00: status: { DRDY } [  129.295747] ata2.00: failed command: WRITE FPDMA QUEUED [  129.296574] ata2.00: cmd 61/00:38:00:78:05/08:00:01:00:00/40 tag 7 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.298880] ata2.00: status: { DRDY } [  129.299443] ata2.00: failed command: WRITE FPDMA QUEUED [  129.300289] ata2.00: cmd 61/00:40:00:80:05/08:00:01:00:00/40 tag 8 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.302572] ata2.00: status: { DRDY } [  129.303174] ata2.00: failed command: WRITE FPDMA QUEUED [  129.304017] ata2.00: cmd 61/00:48:00:88:05/08:00:01:00:00/40 tag 9 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.306303] ata2.00: status: { DRDY } [  129.306902] ata2.00: failed command: WRITE FPDMA QUEUED [  129.307704] ata2.00: cmd 61/00:50:00:90:05/08:00:01:00:00/40 tag 10 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.309994] ata2.00: status: { DRDY } [  129.310553] ata2.00: failed command: WRITE FPDMA QUEUED [  129.311406] ata2.00: cmd 61/00:58:00:98:05/08:00:01:00:00/40 tag 11 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.313705] ata2.00: status: { DRDY } [  129.314304] ata2.00: failed command: WRITE FPDMA QUEUED [  129.315145] ata2.00: cmd 61/00:60:00:a0:05/08:00:01:00:00/40 tag 12 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.348484] ata2.00: status: { DRDY } [  129.364856] ata2.00: failed command: WRITE FPDMA QUEUED [  129.381189] ata2.00: cmd 61/00:68:00:a8:05/08:00:01:00:00/40 tag 13 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.414106] ata2.00: status: { DRDY } [  129.430189] ata2.00: failed command: WRITE FPDMA QUEUED [  129.446413] ata2.00: cmd 61/00:70:00:b0:05/08:00:01:00:00/40 tag 14 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.479421] ata2.00: status: { DRDY } [  129.495503] ata2.00: failed command: WRITE FPDMA QUEUED [  129.511769] ata2.00: cmd 61/00:78:00:b8:05/08:00:01:00:00/40 tag 15 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.544879] ata2.00: status: { DRDY } [  129.560998] ata2.00: failed command: WRITE FPDMA QUEUED [  129.577260] ata2.00: cmd 61/78:88:00:d0:04/07:00:01:00:00/40 tag 17 ncq 978944 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.610366] ata2.00: status: { DRDY } [  129.626509] ata2.00: failed command: WRITE FPDMA QUEUED [  129.642795] ata2.00: cmd 61/88:90:78:d7:04/08:00:01:00:00/40 tag 18 ncq 1118208 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.675914] ata2.00: status: { DRDY } [  129.692046] ata2.00: failed command: WRITE FPDMA QUEUED [  129.708321] ata2.00: cmd 61/00:98:00:e0:04/08:00:01:00:00/40 tag 19 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.741493] ata2.00: status: { DRDY } [  129.757654] ata2.00: failed command: WRITE FPDMA QUEUED [  129.773958] ata2.00: cmd 61/00:a0:00:e8:04/08:00:01:00:00/40 tag 20 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.807130] ata2.00: status: { DRDY } [  129.823279] ata2.00: failed command: WRITE FPDMA QUEUED [  129.839587] ata2.00: cmd 61/c0:a8:00:f0:04/06:00:01:00:00/40 tag 21 ncq 884736 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.872762] ata2.00: status: { DRDY } [  129.888950] ata2.00: failed command: WRITE FPDMA QUEUED [  129.905279] ata2.00: cmd 61/40:b0:c0:f6:04/09:00:01:00:00/40 tag 22 ncq 1212416 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  129.938537] ata2.00: status: { DRDY } [  129.954734] ata2.00: failed command: WRITE FPDMA QUEUED [  129.971063] ata2.00: cmd 61/00:b8:00:00:05/08:00:01:00:00/40 tag 23 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  130.004352] ata2.00: status: { DRDY } [  130.020605] ata2.00: failed command: WRITE FPDMA QUEUED [  130.037015] ata2.00: cmd 61/00:c0:00:08:05/08:00:01:00:00/40 tag 24 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  130.070357] ata2.00: status: { DRDY } [  130.086643] ata2.00: failed command: WRITE FPDMA QUEUED [  130.103079] ata2.00: cmd 61/00:c8:00:10:05/08:00:01:00:00/40 tag 25 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  130.136476] ata2.00: status: { DRDY } [  130.152749] ata2.00: failed command: WRITE FPDMA QUEUED [  130.169163] ata2.00: cmd 61/00:d0:00:18:05/08:00:01:00:00/40 tag 26 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  130.202614] ata2.00: status: { DRDY } [  130.218923] ata2.00: failed command: WRITE FPDMA QUEUED [  130.235351] ata2.00: cmd 61/00:d8:00:20:05/08:00:01:00:00/40 tag 27 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  130.268852] ata2.00: status: { DRDY } [  130.285132] ata2.00: failed command: WRITE FPDMA QUEUED [  130.301587] ata2.00: cmd 61/00:e0:00:28:05/08:00:01:00:00/40 tag 28 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  130.335076] ata2.00: status: { DRDY } [  130.351393] ata2.00: failed command: WRITE FPDMA QUEUED [  130.367817] ata2.00: cmd 61/00:e8:00:30:05/08:00:01:00:00/40 tag 29 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  130.401265] ata2.00: status: { DRDY } [  130.417601] ata2.00: failed command: WRITE FPDMA QUEUED [  130.434096] ata2.00: cmd 61/00:f0:00:38:05/08:00:01:00:00/40 tag 30 ncq 1048576 out                        res 40/00:90:78:d7:04/00:00:01:00:00/40 Emask 0x10 (ATA bus error) [  130.467591] ata2.00: status: { DRDY } [  130.483918] ata2: hard resetting link
After further research and testing it looks to be a problem with ext4 and this card ssd combo?
i mounted the ssd as a ext3 and dd tested the drive and haven't gotten one error
I'll report back with more data after further testing
[  320.133123] EXT4-fs (sda1): mounting ext3 file system using the ext4 subsystem [  320.208644] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
After further testing on ext3 this is the result...........Anyone have any ideas? I'm stumped here
[ 4787.855196] ata1.00: exception Emask 0x0 SAct 0x7ffffeff SErr 0x0 action 0x6 frozen [ 4787.856648] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.857605] ata1.00: cmd 61/08:00:00:08:f8/00:00:05:00:00/40 tag 0 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.859872] ata1.00: status: { DRDY } [ 4787.860430] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.861515] ata1.00: cmd 61/08:08:00:08:fc/00:00:05:00:00/40 tag 1 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.863976] ata1.00: status: { DRDY } [ 4787.864541] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.865480] ata1.00: cmd 61/08:10:00:08:00/00:00:06:00:00/40 tag 2 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.867769] ata1.00: status: { DRDY } [ 4787.868328] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.869254] ata1.00: cmd 61/08:18:00:08:04/00:00:06:00:00/40 tag 3 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.871598] ata1.00: status: { DRDY } [ 4787.872299] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.873235] ata1.00: cmd 61/08:20:00:08:08/00:00:06:00:00/40 tag 4 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.875477] ata1.00: status: { DRDY } [ 4787.876248] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.877305] ata1.00: cmd 61/08:28:00:08:0c/00:00:06:00:00/40 tag 5 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.879112] ata1.00: status: { DRDY } [ 4787.879562] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.880290] ata1.00: cmd 61/08:30:00:08:10/00:00:06:00:00/40 tag 6 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.882004] ata1.00: status: { DRDY } [ 4787.882427] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.883139] ata1.00: cmd 61/08:38:00:08:14/00:00:06:00:00/40 tag 7 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.884991] ata1.00: status: { DRDY } [ 4787.885417] ata1.00: failed command: SEND FPDMA QUEUED [ 4787.886086] ata1.00: cmd 64/01:48:00:00:00/00:00:00:00:00/a0 tag 9 ncq 512 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.887794] ata1.00: status: { DRDY } [ 4787.888215] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.888907] ata1.00: cmd 61/08:50:18:08:00/00:00:00:00:00/40 tag 10 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.890753] ata1.00: status: { DRDY } [ 4787.891178] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.891840] ata1.00: cmd 61/08:58:d8:08:00/00:00:00:00:00/40 tag 11 ncq 4096 out                        res 40/00:01:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.893584] ata1.00: status: { DRDY } [ 4787.894063] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.894661] ata1.00: cmd 61/08:60:00:08:d4/00:00:05:00:00/40 tag 12 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.896379] ata1.00: status: { DRDY } [ 4787.896999] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.897586] ata1.00: cmd 61/08:68:00:08:d8/00:00:05:00:00/40 tag 13 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.899273] ata1.00: status: { DRDY } [ 4787.904829] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.910519] ata1.00: cmd 61/08:70:00:08:dc/00:00:05:00:00/40 tag 14 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.922303] ata1.00: status: { DRDY } [ 4787.927042] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.931832] ata1.00: cmd 61/08:78:00:08:e0/00:00:05:00:00/40 tag 15 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.941830] ata1.00: status: { DRDY } [ 4787.946563] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.951491] ata1.00: cmd 61/08:80:28:18:70/00:00:35:00:00/40 tag 16 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.961438] ata1.00: status: { DRDY } [ 4787.966142] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.971016] ata1.00: cmd 61/08:88:60:19:70/00:00:35:00:00/40 tag 17 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4787.981013] ata1.00: status: { DRDY } [ 4787.985689] ata1.00: failed command: WRITE FPDMA QUEUED [ 4787.990450] ata1.00: cmd 61/08:90:a8:19:70/00:00:35:00:00/40 tag 18 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4788.000324] ata1.00: status: { DRDY } [ 4788.004944] ata1.00: failed command: WRITE FPDMA QUEUED [ 4788.009686] ata1.00: cmd 61/08:98:a0:23:70/00:00:35:00:00/40 tag 19 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4788.019551] ata1.00: status: { DRDY } [ 4788.024195] ata1.00: failed command: WRITE FPDMA QUEUED [ 4788.029010] ata1.00: cmd 61/18:a0:68:3f:70/00:00:35:00:00/40 tag 20 ncq 12288 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4788.039061] ata1.00: status: { DRDY } [ 4788.043789] ata1.00: failed command: WRITE FPDMA QUEUED [ 4788.048580] ata1.00: cmd 61/08:a8:88:3f:70/00:00:35:00:00/40 tag 21 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4788.058740] ata1.00: status: { DRDY } [ 4788.063414] ata1.00: failed command: WRITE FPDMA QUEUED [ 4788.068191] ata1.00: cmd 61/30:b0:b0:3f:70/00:00:35:00:00/40 tag 22 ncq 24576 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4788.078159] ata1.00: status: { DRDY } [ 4788.082796] ata1.00: failed command: WRITE FPDMA QUEUED [ 4788.087576] ata1.00: cmd 61/b8:b8:e8:3f:70/00:00:35:00:00/40 tag 23 ncq 94208 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4788.097570] ata1.00: status: { DRDY } [ 4788.102287] ata1.00: failed command: WRITE FPDMA QUEUED [ 4788.107095] ata1.00: cmd 61/40:c0:a8:40:70/00:00:35:00:00/40 tag 24 ncq 32768 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4788.117127] ata1.00: status: { DRDY } [ 4788.121919] ata1.00: failed command: WRITE FPDMA QUEUED [ 4788.126761] ata1.00: cmd 61/10:c8:f0:40:70/00:00:35:00:00/40 tag 25 ncq 8192 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4788.136809] ata1.00: status: { DRDY } [ 4788.141517] ata1.00: failed command: WRITE FPDMA QUEUED [ 4788.146345] ata1.00: cmd 61/08:d0:00:08:e4/00:00:05:00:00/40 tag 26 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4788.156384] ata1.00: status: { DRDY } [ 4788.161072] ata1.00: failed command: WRITE FPDMA QUEUED [ 4788.165904] ata1.00: cmd 61/08:d8:00:08:e8/00:00:05:00:00/40 tag 27 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4788.176009] ata1.00: status: { DRDY } [ 4788.180724] ata1.00: failed command: WRITE FPDMA QUEUED [ 4788.185556] ata1.00: cmd 61/08:e0:00:08:ec/00:00:05:00:00/40 tag 28 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4788.195619] ata1.00: status: { DRDY } [ 4788.200298] ata1.00: failed command: WRITE FPDMA QUEUED [ 4788.205119] ata1.00: cmd 61/08:e8:00:08:f0/00:00:05:00:00/40 tag 29 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4788.215248] ata1.00: status: { DRDY } [ 4788.219959] ata1.00: failed command: WRITE FPDMA QUEUED [ 4788.224820] ata1.00: cmd 61/08:f0:00:08:f4/00:00:05:00:00/40 tag 30 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4788.234991] ata1.00: status: { DRDY } [ 4788.239863] ata1: hard resetting link [ 4788.699917] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 4788.700568] ata1.00: supports DRM functions and may not be fully accessible [ 4788.702644] ata1.00: supports DRM functions and may not be fully accessible [ 4788.703798] ata1.00: configured for UDMA/133 [ 4788.703833] ata1.00: device reported invalid CHS sector 0 [ 4788.703855] ata1.00: device reported invalid CHS sector 0 [ 4788.703874] ata1.00: device reported invalid CHS sector 0 [ 4788.703894] ata1.00: device reported invalid CHS sector 0 [ 4788.703912] ata1.00: device reported invalid CHS sector 0 [ 4788.703931] ata1.00: device reported invalid CHS sector 0 [ 4788.703950] ata1.00: device reported invalid CHS sector 0 [ 4788.703968] ata1.00: device reported invalid CHS sector 0 [ 4788.703987] ata1.00: device reported invalid CHS sector 0 [ 4788.704005] ata1.00: device reported invalid CHS sector 0 [ 4788.704027] ata1.00: device reported invalid CHS sector 0 [ 4788.704046] ata1.00: device reported invalid CHS sector 0 [ 4788.704065] ata1.00: device reported invalid CHS sector 0 [ 4788.704084] ata1.00: device reported invalid CHS sector 0 [ 4788.704102] ata1.00: device reported invalid CHS sector 0 [ 4788.704121] ata1.00: device reported invalid CHS sector 0 [ 4788.704139] ata1.00: device reported invalid CHS sector 0 [ 4788.704157] ata1.00: device reported invalid CHS sector 0 [ 4788.704176] ata1.00: device reported invalid CHS sector 0 [ 4788.704195] ata1.00: device reported invalid CHS sector 0 [ 4788.704215] ata1.00: device reported invalid CHS sector 0 [ 4788.704238] ata1.00: device reported invalid CHS sector 0 [ 4788.704259] ata1.00: device reported invalid CHS sector 0 [ 4788.704278] ata1.00: device reported invalid CHS sector 0 [ 4788.704296] ata1.00: device reported invalid CHS sector 0 [ 4788.704315] ata1.00: device reported invalid CHS sector 0 [ 4788.704333] ata1.00: device reported invalid CHS sector 0 [ 4788.704351] ata1.00: device reported invalid CHS sector 0 [ 4788.704370] ata1.00: device reported invalid CHS sector 0 [ 4788.704656] ata1: EH complete [ 4788.705321] ata1.00: Enabling discard_zeroes_data [ 4818.895330] ata1.00: exception Emask 0x0 SAct 0x7fffffff SErr 0x0 action 0x6 frozen [ 4818.911412] ata1.00: failed command: WRITE FPDMA QUEUED [ 4818.927323] ata1.00: cmd 61/08:00:00:08:14/00:00:06:00:00/40 tag 0 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4818.959425] ata1.00: status: { DRDY } [ 4818.975231] ata1.00: failed command: WRITE FPDMA QUEUED [ 4818.991109] ata1.00: cmd 61/08:08:00:08:10/00:00:06:00:00/40 tag 1 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.023093] ata1.00: status: { DRDY } [ 4819.038699] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.045393] ata1.00: cmd 61/08:10:00:08:0c/00:00:06:00:00/40 tag 2 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.059045] ata1.00: status: { DRDY } [ 4819.065541] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.072202] ata1.00: cmd 61/08:18:00:08:08/00:00:06:00:00/40 tag 3 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.085841] ata1.00: status: { DRDY } [ 4819.092346] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.098989] ata1.00: cmd 61/08:20:00:08:04/00:00:06:00:00/40 tag 4 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.112623] ata1.00: status: { DRDY } [ 4819.118125] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.123753] ata1.00: cmd 61/08:28:00:08:00/00:00:06:00:00/40 tag 5 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.135375] ata1.00: status: { DRDY } [ 4819.140880] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.146561] ata1.00: cmd 61/08:30:00:08:fc/00:00:05:00:00/40 tag 6 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.158210] ata1.00: status: { DRDY } [ 4819.163657] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.169265] ata1.00: cmd 61/08:38:00:08:f8/00:00:05:00:00/40 tag 7 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.180808] ata1.00: status: { DRDY } [ 4819.186248] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.191107] ata1.00: cmd 61/20:40:a0:a2:1d/00:00:06:00:00/40 tag 8 ncq 16384 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.201124] ata1.00: status: { DRDY } [ 4819.205793] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.210627] ata1.00: cmd 61/08:48:00:08:70/00:00:35:00:00/40 tag 9 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.220608] ata1.00: status: { DRDY } [ 4819.225279] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.230109] ata1.00: cmd 61/20:50:e0:a2:1d/00:00:06:00:00/40 tag 10 ncq 16384 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.240112] ata1.00: status: { DRDY } [ 4819.244786] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.249587] ata1.00: cmd 61/40:58:20:a3:1d/00:00:06:00:00/40 tag 11 ncq 32768 out                        res 40/00:01:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.259565] ata1.00: status: { DRDY } [ 4819.264215] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.269041] ata1.00: cmd 61/20:60:a0:a3:1d/00:00:06:00:00/40 tag 12 ncq 16384 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.279043] ata1.00: status: { DRDY } [ 4819.283707] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.288519] ata1.00: cmd 61/20:68:e0:a3:1d/00:00:06:00:00/40 tag 13 ncq 16384 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.298567] ata1.00: status: { DRDY } [ 4819.303205] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.307970] ata1.00: cmd 61/20:70:c0:e5:1d/00:00:06:00:00/40 tag 14 ncq 16384 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.317903] ata1.00: status: { DRDY } [ 4819.322526] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.327285] ata1.00: cmd 61/08:78:80:4e:1e/00:00:06:00:00/40 tag 15 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.337204] ata1.00: status: { DRDY } [ 4819.341835] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.346631] ata1.00: cmd 61/10:80:a0:8c:1d/00:00:06:00:00/40 tag 16 ncq 8192 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.356569] ata1.00: status: { DRDY } [ 4819.361237] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.366022] ata1.00: cmd 61/e0:88:20:8f:18/00:00:06:00:00/40 tag 17 ncq 114688 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.376016] ata1.00: status: { DRDY } [ 4819.380694] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.385506] ata1.00: cmd 61/f8:90:08:a8:19/01:00:06:00:00/40 tag 18 ncq 258048 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.395528] ata1.00: status: { DRDY } [ 4819.400202] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.405018] ata1.00: cmd 61/c8:98:d8:8c:1d/01:00:06:00:00/40 tag 19 ncq 233472 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.415090] ata1.00: status: { DRDY } [ 4819.419771] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.424599] ata1.00: cmd 61/80:a0:00:20:1b/00:00:06:00:00/40 tag 20 ncq 65536 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.434684] ata1.00: status: { DRDY } [ 4819.439396] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.444294] ata1.00: cmd 61/20:a8:a0:60:1b/00:00:06:00:00/40 tag 21 ncq 16384 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.454402] ata1.00: status: { DRDY } [ 4819.459103] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.463970] ata1.00: cmd 61/20:b0:e0:a0:1b/00:00:06:00:00/40 tag 22 ncq 16384 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.474084] ata1.00: status: { DRDY } [ 4819.478812] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.483651] ata1.00: cmd 61/20:b8:20:e1:1b/00:00:06:00:00/40 tag 23 ncq 16384 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.493772] ata1.00: status: { DRDY } [ 4819.498513] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.503372] ata1.00: cmd 61/20:c0:60:61:1c/00:00:06:00:00/40 tag 24 ncq 16384 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.513505] ata1.00: status: { DRDY } [ 4819.518241] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.523128] ata1.00: cmd 61/20:c8:a0:a1:1c/00:00:06:00:00/40 tag 25 ncq 16384 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.533295] ata1.00: status: { DRDY } [ 4819.538038] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.542908] ata1.00: cmd 61/20:d0:e0:e1:1c/00:00:06:00:00/40 tag 26 ncq 16384 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.553028] ata1.00: status: { DRDY } [ 4819.557774] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.562640] ata1.00: cmd 61/20:d8:20:22:1d/00:00:06:00:00/40 tag 27 ncq 16384 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.572790] ata1.00: status: { DRDY } [ 4819.577521] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.582424] ata1.00: cmd 61/20:e0:60:62:1d/00:00:06:00:00/40 tag 28 ncq 16384 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.592580] ata1.00: status: { DRDY } [ 4819.597324] ata1.00: failed command: WRITE FPDMA QUEUED [ 4819.602203] ata1.00: cmd 61/08:e8:18:08:00/00:00:00:00:00/40 tag 29 ncq 4096 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.612319] ata1.00: status: { DRDY } [ 4819.617062] ata1.00: failed command: SEND FPDMA QUEUED [ 4819.621923] ata1.00: cmd 64/01:f0:00:00:00/00:00:00:00:00/a0 tag 30 ncq 512 out                        res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [ 4819.632007] ata1.00: status: { DRDY } [ 4819.636737] ata1: hard resetting link [ 4820.096131] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 4820.096753] ata1.00: supports DRM functions and may not be fully accessible [ 4820.099413] ata1.00: supports DRM functions and may not be fully accessible [ 4825.100299] ata1.00: qc timeout (cmd 0x47) [ 4825.100341] ata1.00: READ LOG DMA EXT failed, trying unqueued [ 4825.100363] ata1.00: failed to get Identify Device Data, Emask 0x40 [ 4825.100409] ata1.00: configured for UDMA/133 [ 4825.100440] ata1.00: device reported invalid CHS sector 0 [ 4825.100462] ata1.00: device reported invalid CHS sector 0 [ 4825.100481] ata1.00: device reported invalid CHS sector 0 [ 4825.100501] ata1.00: device reported invalid CHS sector 0 [ 4825.100520] ata1.00: device reported invalid CHS sector 0 [ 4825.100539] ata1.00: device reported invalid CHS sector 0 [ 4825.100557] ata1.00: device reported invalid CHS sector 0 [ 4825.100576] ata1.00: device reported invalid CHS sector 0 [ 4825.100594] ata1.00: device reported invalid CHS sector 0 [ 4825.100612] ata1.00: device reported invalid CHS sector 0 [ 4825.100631] ata1.00: device reported invalid CHS sector 0 [ 4825.100653] ata1.00: device reported invalid CHS sector 0 [ 4825.100672] ata1.00: device reported invalid CHS sector 0 [ 4825.100690] ata1.00: device reported invalid CHS sector 0 [ 4825.100709] ata1.00: device reported invalid CHS sector 0 [ 4825.100727] ata1.00: device reported invalid CHS sector 0 [ 4825.100747] ata1.00: device reported invalid CHS sector 0 [ 4825.100766] ata1.00: device reported invalid CHS sector 0 [ 4825.100792] ata1.00: device reported invalid CHS sector 0 [ 4825.100811] ata1.00: device reported invalid CHS sector 0 [ 4825.100829] ata1.00: device reported invalid CHS sector 0 [ 4825.100848] ata1.00: device reported invalid CHS sector 0 [ 4825.100866] ata1.00: device reported invalid CHS sector 0 [ 4825.100885] ata1.00: device reported invalid CHS sector 0 [ 4825.101133] ata1.00: device reported invalid CHS sector 0 [ 4825.101154] ata1.00: device reported invalid CHS sector 0 [ 4825.101174] ata1.00: device reported invalid CHS sector 0 [ 4825.101193] ata1.00: device reported invalid CHS sector 0 [ 4825.101212] ata1.00: device reported invalid CHS sector 0 [ 4825.101231] ata1.00: device reported invalid CHS sector 0 [ 4825.101278] ata1: hard resetting link [ 4835.101030] ata1: softreset failed (1st FIS failed) [ 4835.116682] ata1: hard resetting link [ 4845.117089] ata1: softreset failed (1st FIS failed) [ 4845.132563] ata1: hard resetting link [ 4880.132343] ata1: softreset failed (1st FIS failed) [ 4880.147557] ata1: limiting SATA link speed to 3.0 Gbps [ 4880.147609] ata1: hard resetting link [ 4885.147327] ata1: softreset failed (1st FIS failed) [ 4885.162321] ata1: reset failed, giving up [ 4885.177157] ata1.00: disabled [ 4885.177376] ata1: EH complete [ 4885.177569] sd 0:0:0:0: [sda] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00 [ 4885.177685] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x93 93 08 00 00 00 00 00 21 40 f0 00 00 00 90 00 00 [ 4885.177709] blk_update_request: I/O error, dev sda, sector 2179312 [ 4885.178435] sd 0:0:0:0: [sda] tag#15 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00 [ 4885.178459] sd 0:0:0:0: [sda] tag#15 CDB: opcode=0x2a 2a 00 00 00 08 18 00 00 08 00 [ 4885.178471] blk_update_request: I/O error, dev sda, sector 2072 [ 4885.178511] Buffer I/O error on dev sda1, logical block 3, lost async page write [ 4885.178622] sd 0:0:0:0: [sda] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00 [ 4885.178643] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x2a 2a 00 06 1d 62 60 00 00 20 00 [ 4885.178653] blk_update_request: I/O error, dev sda, sector 102589024 [ 4885.178673] EXT4-fs warning (device sda1): ext4_end_bio:330: I/O error -5 writing to inode 51052547 (offset 0 size 0 starting block 12823629) [ 4885.178690] Buffer I/O error on device sda1, logical block 12823372 [ 4885.178718] EXT4-fs warning (device sda1): ext4_end_bio:330: I/O error -5 writing to inode 51052547 (offset 0 size 0 starting block 12823630) [ 4885.178729] Buffer I/O error on device sda1, logical block 12823373 [ 4885.178751] EXT4-fs warning (device sda1): ext4_end_bio:330: I/O error -5 writing to inode 51052547 (offset 0 size 0 starting block 12823631) [ 4885.178762] Buffer I/O error on device sda1, logical block 12823374 [ 4885.178802] EXT4-fs warning (device sda1): ext4_end_bio:330: I/O error -5 writing to inode 51052547 (offset 0 size 0 starting block 12823632) [ 4885.178813] Buffer I/O error on device sda1, logical block 12823375 [ 4885.178913] sd 0:0:0:0: [sda] tag#17 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00 [ 4885.178932] sd 0:0:0:0: [sda] tag#17 CDB: opcode=0x2a 2a 00 06 1d 22 20 00 00 20 00 [ 4885.178942] blk_update_request: I/O error, dev sda, sector 102572576 [ 4885.178959] EXT4-fs warning (device sda1): ext4_end_bio:330: I/O error -5 writing to inode 51052547 (offset 0 size 0 starting block 12821573) [ 4885.178971] Buffer I/O error on device sda1, logical block 12821316 [ 4885.178994] EXT4-fs warning (device sda1): ext4_end_bio:330: I/O error -5 writing to inode 51052547 (offset 0 size 0 starting block 12821574) [ 4885.179004] Buffer I/O error on device sda1, logical block 12821317 [ 4885.179025] EXT4-fs warning (device sda1): ext4_end_bio:330: I/O error -5 writing to inode 51052547 (offset 0 size 0 starting block 12821575) [ 4885.179036] Buffer I/O error on device sda1, logical block 12821318 [ 4885.179058] EXT4-fs warning (device sda1): ext4_end_bio:330: I/O error -5 writing to inode 51052547 (offset 0 size 0 starting block 12821576) [ 4885.179068] Buffer I/O error on device sda1, logical block 12821319 [ 4885.179141] sd 0:0:0:0: [sda] tag#18 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00 [ 4885.179161] sd 0:0:0:0: [sda] tag#18 CDB: opcode=0x2a 2a 00 06 1c e1 e0 00 00 20 00 [ 4885.179170] blk_update_request: I/O error, dev sda, sector 102556128 [ 4885.179186] EXT4-fs warning (device sda1): ext4_end_bio:330: I/O error -5 writing to inode 51052547 (offset 0 size 0 starting block 12819517) [ 4885.179198] Buffer I/O error on device sda1, logical block 12819260 [ 4885.179221] EXT4-fs warning (device sda1): ext4_end_bio:330: I/O error -5 writing to inode 51052547 (offset 0 size 0 starting block 12819518) [ 4885.179232] Buffer I/O error on device sda1, logical block 12819261 [ 4885.179371] sd 0:0:0:0: [sda] tag#19 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00 [ 4885.179390] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x2a 2a 00 06 1c a1 a0 00 00 20 00 [ 4885.179400] blk_update_request: I/O error, dev sda, sector 102539680 [ 4885.179504] sd 0:0:0:0: [sda] tag#20 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00 [ 4885.179523] sd 0:0:0:0: [sda] tag#20 CDB: opcode=0x2a 2a 00 06 1c 61 60 00 00 20 00 [ 4885.179532] blk_update_request: I/O error, dev sda, sector 102523232 [ 4885.179632] sd 0:0:0:0: [sda] tag#21 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00 [ 4885.179651] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x2a 2a 00 06 1b e1 20 00 00 20 00 [ 4885.179660] blk_update_request: I/O error, dev sda, sector 102490400 [ 4885.179761] sd 0:0:0:0: [sda] tag#22 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00 [ 4885.179781] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x2a 2a 00 06 1b a0 e0 00 00 20 00 [ 4885.179790] blk_update_request: I/O error, dev sda, sector 102473952 [ 4885.179903] sd 0:0:0:0: [sda] tag#23 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00 [ 4885.179923] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x2a 2a 00 06 1b 60 a0 00 00 20 00 [ 4885.179932] blk_update_request: I/O error, dev sda, sector 102457504 [ 4885.181959] Buffer I/O error on dev sda1, logical block 112066560, lost async page write [ 4885.182105] Buffer I/O error on dev sda1, logical block 12517376, lost async page write [ 4885.182167] Buffer I/O error on dev sda1, logical block 12550144, lost async page write [ 4885.182225] Buffer I/O error on dev sda1, logical block 12582912, lost async page write [ 4885.182320] Buffer I/O error on dev sda1, logical block 12615680, lost async page write [ 4885.182379] Buffer I/O error on dev sda1, logical block 12648448, lost async page write [ 4885.182439] Buffer I/O error on dev sda1, logical block 12681216, lost async page write [ 4885.182497] Buffer I/O error on dev sda1, logical block 12713984, lost async page write [ 4885.182556] Buffer I/O error on dev sda1, logical block 12746752, lost async page write [ 4885.186760] JBD2: Detected IO errors while flushing file data on sda1-8 [ 4885.186840] Aborting journal on device sda1-8. [ 4885.186874] EXT4-fs error (device sda1) in ext4_write_begin:1125: IO failure [ 4885.186934] JBD2: Error -5 detected when updating journal superblock for sda1-8. [ 4885.187031] JBD2: Detected IO errors while flushing file data on sda1-8 [ 4885.187533] EXT4-fs (sda1): previous I/O error to superblock detected [ 4885.191072] EXT4-fs error (device sda1): ext4_journal_check_start:56: Detected aborted journal [ 4885.191080] EXT4-fs (sda1): Remounting filesystem read-only [ 4885.191088] EXT4-fs (sda1): previous I/O error to superblock detected
Hi jerry,
i have exactly the same issues, using 2 HDDs on the official PCIe-Sata adapter card and the
stretch-openmediavault-rock64-0.7.9-1067-arm64 Image.
I am even not able to create a filesystem on those disks due to this issues.
Have you tried a different PCIe card? What image are you using?
hmmm, which PSU are you guys using ?
Chiming in here: My sata card from Pine has been giving me same kind of trouble. Couple of dmesgs from ayufan's ubuntu minimal + kernels (4.4 and 4.20):
- https://pastebin.com/c9S7ECFt
- https://pastebin.com/N6gJ4Min
RockPro64 setup:
- RP64 4GB, v2.1
- Pine64 SATA card (ASM1062)
- 500GB Samsung 860 Evo SSD
- 7-port USB3 Hub in USB3 port
- Keyboard in USB2 port
- 12V/6A Salcar PSU (from Amazon). This powers all of above.
What seems to happen in my logs is that ata/sata errors and after a couple of tries kernel (at least 4.20) disables NCQ and after that the card starts working. There's a little difference between kernels: If I remember correctly in 4.4 mkfs already caused errors. From user's point of view it looks like the command just halted. In 4.20 mkfs and mount went ok but first attempt to actually do something (ls -l in mount point) caused errors. Removing keyboard and USB hub didn't have any effect.
I tried the card in x86_64 PC with 18.04 Ubuntu and same errors happened is that setup too. When I tried using the SSD drive connected directly to PC motherboard with same SATA cable it worked without errors. This makes me believe there's something wrong with the SATA card itself.
PC setup:
- Asus Fatal1ty H87 performance
- Intel Xeon E3-1230 v3
- 32GB Ram
- Pine64 SATA card (ASM1062, in PCIe 2.0 x16 slot)
- MSI Radeon R9 270X
- Seagate Momentus 500GB Hybrid drive as boot + rootfs device
- 500GB Samsung 860 Evo SSD as "drive under test"
- XFX TS 550W PSU
As a workaround I disabled NCQ from kernel by adding libata.force=noncq to kernel command line (to line that says "append" in /boot/extlinux/extlinux.conf). After that I haven't experienced any ATA/SATA errors yet. Note that disabling NCQ may cause serious performance drop especially with spinning disks! For me it's okayish as I'm using it on my retro/Recalbox build with SSD. But personally I wouldn't use it on NAS (I have Marvell 88SE9230 and 88SE9215 cards working just fine on that purpose).
Edit: Pine64 store page (https://www.pine64.org/?product=rockpro6...rface-card) says the card is ASM1061 but lspci says it's ASM1062. The card is from Pine store anyway Smile
(01-18-2019, 05:30 AM)Luke Wrote: hmmm, which PSU are you guys using ?
I am using the 12V/5A EU version from the pine64 store.
greetings
Thanks, for sharing your achievements with this issue, nuumio.
I really appreciate this.
Hopefully the issue gets resolved when replacing the sata card.
greetings,
flocke
"As a workaround I disabled NCQ from kernel by adding libata.force=noncq to kernel command line (to line that says "append" in /boot/extlinux/extlinux.conf). After that I haven't experienced any ATA/SATA errors yet."
Unfortunately, this is not working for me. I am able to create a raid1, but it is degraded, right after creating a filesystem (ext4) on it.
It seems, one disk is thrown off, while creating the filesystem.
sudo mdadm --detail /dev/md0 /dev/md0:           Version : 1.2     Creation Time : Fri Jan 18 17:39:52 2019        Raid Level : raid1        Array Size : 5801784320 (5533.01 GiB 5941.03 GB)     Used Dev Size : 5801784320 (5533.01 GiB 5941.03 GB)      Raid Devices : 2     Total Devices : 1       Persistence : Superblock is persistent     Intent Bitmap : Internal       Update Time : Fri Jan 18 18:06:48 2019             State : clean, degraded    Active Devices : 1   Working Devices : 1    Failed Devices : 0     Spare Devices : 0 Consistency Policy : unknown              Name : rockpro64:0  (local to host rockpro64)              UUID : 794330d2:d90eb680:9ee17e0e:de6c3317            Events : 8675    Number   Major   Minor   RaidDevice State       -       0        0        0      removed       1       8       17        1      active sync   /dev/sdb1
[  150.255479] ata2.00: status: { DRDY } [  150.255970] ata2: hard resetting link [  150.715440] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [  150.717721] ata2.00: configured for UDMA/133 [  150.717792] ata2: EH complete [  150.872720] ata2.00: exception Emask 0x10 SAct 0x0 SErr 0x400000 action 0x6 frozen [  150.873912] ata2.00: irq_stat 0x08000000, interface fatal error [  150.874876] ata2: SError: { Handshk } [  150.875472] ata2.00: failed command: WRITE DMA EXT [  150.876244] ata2.00: cmd 35/00:40:c0:d4:ca/00:05:59:01:00/e0 tag 16 dma 688128 out                        res 50/00:00:c0:d4:ca/00:00:59:01:00/e0 Emask 0x10 (ATA bus error)
I think i should try another sata card.
The issues are gone using a proper power supply.
The use of the official psu(12v/5A) with the official sata2-interface-card gave me the errors, mentioned above.
Upgrading to a 12V/7.5A psu (Leicke NT33402) resolved those issues.
I even tried another sata card and the "delock 88SE9230" works like a charm using the tips, mentioned in the following thread : https://forum.pine64.org/showthread.php?tid=6459 .
greetings
  Powering two disks from RockPro64 some_pinephone_user 3 6,767 02-24-2026, 04:43 PM
Last Post: evilbunny
  TPM module for rockpro64 misha64 0 3,973 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 15,265 04-01-2024, 10:24 PM
Last Post: nano2
  AW-CM256SM wifi card mtek 4 11,291 10-30-2023, 12:00 PM
Last Post: diederik
  Powering on the Rockpro64 JPT223 1 4,681 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  Which SATA card should I use my NAS server RAID5 Louysa 3 5,915 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 4,580 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 3,377 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 5,602 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 50,635 12-18-2022, 06:25 PM
Last Post: heyghoge
