startup failure Pine64
I have PineA64  with Ubuntu image installed on SD card. sometimes it fails to startup and get into OS. the HDMI display recognizes the signal but still shows black screen for a while then back to "NO Signal" message. this happens only on startup.
if I plug out / plug in the power cable again, the system works correctly.
This issue occurs many times.
Any solution for that?
Thx for help,
(09-03-2018, 02:15 AM)yasser.moj Wrote: I have PineA64  with Ubuntu image installed on SD card. sometimes it fails to startup and get into OS. the HDMI display recognizes the signal but still shows black screen for a while then back to "NO Signal" message. this happens only on startup.
Thx for help,
Please make sure your power supply is not under power.
Thx for help,
Thanks for your reply.
Actually, I am sure it is not a power issue. because I tried (5V ,2A ) and (5V,5A) but still sometimes (40%) it doesn't get into system.
check this video please:
https://drive.google.com/open?id=1clDSzg...WLlb3k_YmU
here I am using (5V,5A) power supply!!
Thx for help,
Even you uses the 5V 5A power supply, your cable connection seems not able to deliver the 5A current.
Please use multimeter and measure on Pi2 bus "DC in" point to check whether you have 5V supply to your board. If you measure only 4.8V, then please revisit your wiring or use the actual 5V 3A power supply.
Thx for help,
I've checked it. it is regular 5V and the quality of the cable is good it is Samsung-made.
Thx for help,
If Samsung made, then looks like a mobile phone power supply. Please note that most mobile phone power supply not capable of deliver enough power to SBC, even stated 2A rating. This due to the 2A deliver only when "match" to their own mobile phone. If not match happen, the power supply only deliver 500mA.
(09-05-2018, 11:07 PM)tllim Wrote: Please make sure your power supply is not under power.
just to clarify ,only the cable is Samsung made, but I have an external power supply 5A , and I measured the voltage on DC input of the board it's stable 5V.
May the issue occurs because the image installed directly on the SD card? what do u think? could it be more stable if I use EMMC?
  Ordering from Pine64 website NonPlayableCharacter22 0 631 07-28-2026, 02:07 PM
Last Post: NonPlayableCharacter22
  Has anyone installed Trisquel (linux-libre) on Pine64 RockPro64? libreboy 1 4,501 11-03-2025, 12:08 PM
Last Post: RandB
  Problem joining Discord Pine64 dhdurgee 1 4,642 09-30-2025, 11:44 AM
Last Post: dhdurgee
  SBC Case Builder and Pine64 SBC hominoid 1 5,164 06-13-2025, 03:03 PM
Last Post: hominoid
Star Pine64 Logo Submissions Admiral Snackbar 0 3,480 06-08-2025, 03:00 PM
Last Post: Admiral Snackbar
  Advice on Choosing the Best Pine64 Device for My Use Case? Ingrid 4 5,851 02-28-2025, 01:14 AM
Last Post: stefan_hdb
  Registering my 'nick' on Pine64's IRC network diederik 7 9,607 12-04-2024, 05:44 AM
Last Post: mmonster
  Need Help Choosing the Right Pine64 Board for My Project jacoballen 1 3,633 09-22-2024, 06:28 PM
  [Article] RISC-V Emulator for Pine64 Oz64 SBC lupyuen 2 4,797 07-07-2024, 04:19 AM
Last Post: lupyuen
  Unable to connect to Pine64 IRC channel due to certificate error? Must-Borrow 1 3,458 03-10-2024, 02:43 PM
Last Post: Must-Borrow
