ROCK 64 board unresponsive
Hi all. During a recent office reshuffle I had to dismantle all pc's and auxiliary stuff. In the process I pulled the power cord on the ROCK 64  without powering the board down. Now it will not power up. No sign of life atm. No led's - no sign of life. The board was set up to boot off emmc and has a hard drive attached via usb to sata adaptor. Any ideas where to look? Not sure what is going on.
If for example the correct power supply was used then I should get at least one led - is that correct. Have I missed any pre-requisites?
Is there any way to test another cable/adapter? Maybe you just broke the cable and it's just not getting power.
Other possibility if the SPL is only on the eMMC and it can't read that it will also fail to do much
however I would expect a power led somewhere telling me I have power still... (unless you are a led on a sopine board and and you are so near the edge of the board that after a few re-seats you become loose and stop shining... but that's a different story) :-)
Started using FreeBSD at version 2.0 but really started using it at around version 6.4.
If it doesn't do what you want; hack it until it does!
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 5,139 04-26-2023, 11:38 PM
  Audio Pot Board Questions vfr400racer 4 9,775 10-11-2022, 09:21 PM
Last Post: Roberto2020
  Rock64 4K60P HDR Media Board Computer 64 bit MarkHaysHarris777 8 27,030 07-14-2021, 11:52 PM
Last Post: jontumontu
  RS-485 CAN HAT Rock won’t boot gnvdude 1 5,395 01-10-2021, 05:15 PM
Last Post: as365n4
  Help connecting a dvb board in the right gpio pins cosmodeal 0 3,721 11-11-2020, 12:48 PM
Last Post: cosmodeal
  Rock64 stereo audio dac add-on board with RockPro64 Tim13 1 5,807 07-08-2019, 07:15 PM
  Rock64 Stereo Audio DAC add-on board Hukmut 3 9,179 06-15-2019, 07:56 AM
Last Post: MiiCode2
  "ROCK 64 STEREO AUDIO DAC ADD-ON BOARD", Is it okay if I turn on the power ? t4_4t 4 10,523 01-09-2019, 01:02 AM
Last Post: t4_4t
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD and USB serial adapter for Pine64 jovval 2 6,705 12-01-2018, 03:53 AM
Last Post: jovval
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD angelscream09 7 14,431 11-21-2018, 07:02 PM
Last Post: antonv
