RockPro64 power consumption
Hey guys, those Rockchip-based boards sound insane!
I'm thinking about getting my hands on one of the RockPro64-Boards, but I'm a bit curious about the power consumption (idle mostly).
Could anyone of you please share some concrete power consumption values like for the Rock64-board in the youtube-videos here?
Does the RockPro64-board have the same frequency steps as the Rock64, leading to a similar idle power consumption, or is there something else to consider?
4,2 Watt Idle / PCIe mit 960er EVO m.2 (4.18.0-rc3-1042)
8,5 Watt with 'sysbench --threads=6 --test=cpu --cpu-max-prime=20000 run'
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
(08-02-2018, 11:56 AM)seiji Wrote: ... or is there something else to consider?
Yup - what you plug in ti the PCIe slot and/or USB and/or VIN header. Pretty sure it is possible to construct a scenario that could overload the 5A (60W) suggested PSU.
OTOH I have nothing in my PCIe (yet) and only a BT dongle in USB. Measuring my power consumption at the wall (with a Brennenstuhl meter) 7.25W max when idle, often a lot less, and 12W or so with all 6 CPU cores close to 100% (but no GPU load). Dont think my PSU is very efficient, maybe 70%. I am running HDMI screen, 4.4.132 kernel.
Big thank you to both of you, for those values!
OK, just reworked my power supply and did some measurements on the input DC line, which I measured at 12.2V:
0.185A minimum (HDMI plugged in but DPMS screen saver in effect, nothing in USB sockets or PCIe), all CPU idle (at 408MHz)
0.19A if add Bluetooth dongle to USB
0.21A if wake up display (Openbox desktop), also BT dongle
0.65A all CPU at 100% load (not very demanding load but does make 100% at 1416 & 1800MHz), screen alive (Openbox desktop) but no real GPU load
My results, measured at the mains line, with a no-name switched-mode 12V/3A PSU,  a 64 GB eMMC module installed, and a HDMI HD TV + a USB keyboard + a USB mouse plugged in:
  • screen off past 10 min timeout: 3.1 W
  • while I am typing this post on it: 3.5 W
  • watching 1080p film fullscreen: 6–9 W (varies)
  • with 6 threads of burnCortexA9: 11 W
Bottom line is that it's considerably less power-hungry than the ODROID-XU4 (about 15 W maximum) Wink
(08-02-2018, 06:34 PM)dukla2000 Wrote: OTOH I have nothing in my PCIe (yet) and only a BT dongle in USB. Measuring my power consumption at the wall (with a Brennenstuhl meter) 7.25W max when idle, often a lot less
(08-11-2018, 12:54 AM)lucho Wrote: My results, measured at the mains line, with a no-name switched-mode 12V/3A PSU,  a 64 GB eMMC module installed, and a HDMI HD TV + a USB keyboard + a USB mouse plugged in:
What's the explanation for the discrepancy between the two idle values?
I'm looking to build a power-efficient NAS on basis of a RockPro64. But since the NAS would sit idle for most of the time, power consumption during Idle state is of the main concern for me.
There isn't such a big discrepancy:
Quote:0.185A minimum (HDMI plugged in but DPMS screen saver in effect, nothing in USB sockets or PCIe), all CPU idle (at 408MHz)
So the power drawn from the output of the PSU is 0.185 × 12.2 = 2.257 W, but if you divide it to the PSU efficiency (say, 0.75, albeit it varies) and add the consumption of the keyboard and the mouse (however small they are), you get close to my 3.1 W (2.257 / 0.75 ≈ 3).
(08-13-2018, 03:24 AM)TOMillr Wrote: What's the explanation for the discrepancy between the two idle values?
I did draft a reply yesterday but plainly blew it when it came to posting! But yup, gist was PSU efficiency. I am quite sure the PSU I was using at first was not efficient in any way (except at finally expiring - it was about 20 years old).
As per lucho my new numbers measured on the 12V supply are in line with as his at the wall.
Hi
I have both 4GB ROCKPro64 and 4GB Rock64. I have to use both in a wireless kind of environment or locations where grid electricity is not there.
I have tried Rock64 with Portable power bank giving 2.1A current using USB to 3.5mm OD/1.35mm cable and it worked well.
I was wondering what minimum power i can give to RockPro64 without damaging it ? Most commercial power banks gives 2.1 A current with 5V USB cable. I have searched Amazon and could see some portable power banks with variable current options higher than 2.1 A but indeed they are expensive. Giving higher current using USB cable is fine .. ? Please advise what should i do to make ROCKPro64 portable.
If someone can recommend a solar power charger that can work, that will be an added advantage ... All green energy setup Big Grin
  RockPro64 automatically run after power recovery - my solution g2t 1 1,839 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 4,525 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Rock Pro 64 Won't power on matthewmkr 9 9,051 04-29-2025, 12:57 PM
Last Post: matthewmkr
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,856 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,599 11-26-2024, 11:08 AM
  power button not working Vista8720 0 3,486 05-07-2024, 11:26 PM
Last Post: Vista8720
  Installing Wifi drive for the RockPro64 John45595 0 4,810 02-10-2024, 11:32 PM
Last Post: John45595
  enble boot after power loss/restore dkebler 18 30,889 12-04-2023, 12:14 PM
Last Post: ok38
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,327 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,985 08-14-2023, 07:55 AM
Last Post: kundanjha
