Armbian Bionic on Pine A64+ black screen
Exclamation
I tried to flash the latest Armbian (Armbian_5.50.180630_Pine64_Ubuntu_bionic_dev_4.17.3) on my A64+. When starting I get the following message:
[Image: 33159061wy.jpg]
Anybody have any idea what might go wrong? I know it's not stable yet. Smile
After that message I get a black screen.
regards
If you don't get a response on here, then I suggest you try Armbian forum.
(07-05-2018, 06:00 AM)Luke Wrote: If you don't get a response on here, then I suggest you try Armbian forum.
Ok I will try.
For you to know, I started a post in the Armbian Forum.
https://forum.armbian.com/topic/7844-arm...ice-error/
It looks like the image cannot boot from the SD-Card.
At least according to the error messages.
Quote:Loading Environment from FAT... ** Bad Device mmc 0 **
Loading Environment from FAT... Unable to use mmc 0:1... Failed (-5)
(07-05-2018, 05:30 AM)starmagoo Wrote: I tried to flash the latest Armbian (Armbian_5.50.180630_Pine64_Ubuntu_bionic_dev_4.17.3) on my A64+. When starting I get the following message:
regards
Simplefb is the Framebuffer driver..
You are using the wrong image.. your image is for a device with a different type of framebuffer.
Try another image.
I would like to but there is no other image.
https://dl.armbian.com/pine64/
(07-31-2018, 03:06 PM)starmagoo Wrote: I would like to but there is no other image.
Did you see this one?
https://dl.armbian.com/pine64so/
http://wiki.pine64.org/index.php/Pine_A6...re_Release
Try some stuff with A64+ in the name.. if it works find the DTB file and use that to fix other distributions.
(07-31-2018, 03:32 PM)evilbunny Wrote: Did you see this one?
Yes, these images don't work. I don't even get a boot screen.
(07-31-2018, 04:17 PM)paradise Wrote: http://wiki.pine64.org/index.php/Pine_A6...re_Release
What exactly do you mean?
I found out that the DTB (Device Tree Blob) is a file which describes all the physical devices in a system. Right? How can I find it and where should I put it?
Most of the distro's put it in the msdos boot partition in the folder dtb or overlays
Example Linux (some jesse version)
root@SuperBSD:/ # ls /mnt/msdos/ Image.version* boot.cmd*      bootlogo.bmp*  font32.sft*    kernel*        uEnv.txt*       bat/           boot.scr*      font24.sft*    initrd.img*    pine64/         root@SuperBSD:/ # ls /mnt/msdos/pine64/ boot0-pine64-pinebook.bin*      fes1-pine64-pinebook.bin*       sun50i-a64-pine64-pinebook.dtb* u-boot-pine64-pinebook.bin* boot0-pine64-plus.bin*          fes1-pine64-plus.bin*           sun50i-a64-pine64-plus.dtb*     u-boot-pine64-plus.bin* boot0-pine64-sopine.bin*        fes1-pine64-sopine.bin*         sun50i-a64-pine64-sopine.dtb*   u-boot-pi
You will want sun50i-a64-pine64-plus.dtb for your device
Also make sure to check the u-boot/kerel messages and try and figure out what dtb file it's loading so you get/replace the right one.
ps. Linux DTB will most likely not work with BSD and vise versa.
ps2. You can also edit your DTB I don't know the command in Linux but FreeBSD I use
extract: dtc -O dts -I dtb -o sun50i-a64-pine64-plus.dts sun50i-a64-pine64-plus.dtb
edit with some text editor
extract: dtc -O dtb -I dts -o sun50i-a64-pine64-plus.dtb sun50i-a64-pine64-plus.dts
  A64 Euler FAN Support on Armbian Breacher 0 1,783 09-20-2024, 09:57 AM
Last Post: Breacher
Question PINE64 PA642GB Armbian - no Microphone plug spel 1 7,135 11-09-2022, 01:46 PM
Last Post: pinebug
  Armbian 22.02 Release Announcement TRS-80 0 4,919 02-28-2022, 05:04 PM
Last Post: TRS-80
Question Pine A64+ audio POT not recognized joho500 0 4,102 11-24-2021, 07:00 AM
Last Post: joho500
  Software Updates in Armbian CVBruce 1 6,953 07-10-2020, 09:07 AM
Last Post: martinayotte
  Armbian for Pine64 xalius 22 75,284 05-07-2020, 06:27 PM
Last Post: bratoff
  Armbian enable toucscreen right-click burningkrome 0 4,949 12-03-2018, 03:05 PM
Last Post: burningkrome
  PineA64+ Armbian not boot, black screen and log klode 3 12,087 10-14-2018, 04:02 AM
Last Post: evilbunny
  +LTS/SOPINE kivy on armbian with lcd baumbachandrew 0 4,923 05-29-2018, 10:15 PM
Last Post: baumbachandrew
  Install VNC Armbian netpr 1 8,593 08-30-2017, 07:03 PM
Last Post: vinodmenon80
