How can I install tvheadend server un rock64?
Hello i am newbie , and I want install tvheadend server On my rock64 with debían
How can I do? Any tutorial?
Thanks a lot
You'll probably need to supply a little more information. Do you have the desktop version of Debian. It should be in the apt repos. Try this link to check it out https://tvheadend.org/projects/tvheadend...Repository
Thanks for your reply
Yes i have a debian with desktop version .
Yes i look this page , but i Don't Know what repository i can put for install
What version of Debian have you installed. If you have Stretch just follow the instructions for installing that version.
I have stretch , but wath i can choose
Armhf/. Arm64 ? Amd i386?
Arm64. That's the Rock64 chip.
Thanks, tren I Try this Ubuntu Xenial "xenial"
Can i change debían for ubuntu ? For try?
If you have the desktop version you should be able to install it from your Debian repo on the GUI using the GUI package installer.
(07-30-2018, 06:29 PM)Rocklobster Wrote: If you have the desktop version you should be able to install it from your Debian repo on the GUI using the GUI package installer.
What repo can i agregatte, i’m very newbiee
Assuming you are using Debian Stretch choose either Doozer or Bintray from this link https://tvheadend.org/projects/tvheadend...Repository
Just read through this link and follow the steps laid out.
  Rock64 v2.0 u-boot SPI issues ju0n 0 776 07-05-2026, 11:02 AM
Last Post: ju0n
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 6,100 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 28,310 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 16,709 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 18,645 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,817 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 9,898 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 10,914 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,246 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,905 11-28-2022, 02:18 PM
Last Post: Macgyver
