RockPro Wireless+Bluetooth Issue - Linux (ayufan 0.7.8 and previous)
I may be overlooking something very simple. Here is what I have observed so far. I am referencing the image file from ayufan, 0.7.8 LDXE RockPro. I have went all the way down from dev releases to the 0.6.X stable releases, but I have the same results. It's actually worse on older builds, which I expected.
I have two separate units, with two separate RockPro bt+wifi modules that integrate in to the board. I have ran several commands to try to see the issue, but with no success.
The lsusb output does not show the adapter, which is expected since it doesn't use USB.
The "lshw -C network" shows that the adapter is wlan0.
The "rfkill list" shows that the adapter is there, and wireless isn't blocked. However, it shows that Bluetooth is soft blocked so I issued the unblock all command. This fixed the software block, but the wireless still wouldn't work.
iwconfig isnt even available. The "ifconfig wlan0 up" command returns "The operation is not permitted".
To validate that it isn't hardware related, I loaded the other Android builds and they work great with wireless. But those builds are extremely limited functionally and visibly without the tablet.
Sorry if this is a solid noob question, so feel free to cut jokes, lmao. I just tried about everything I could think of. wicd wasn't even an option, but that's likely due to the build not recognizing the adapter fully.
Any help is appreciated!! Thanks all, especially to ayufan for everything! You are a kind soul, and I'll buy you a beer anytime. ;-)
Lukasz pointed this out to me last night:
0.7.8: Disable sdio (no wifi/bt) to fix pcie/nvme support on 4.4 for RockPro64,
Thanks for the reply! I noticed that in the release notes. I found it by searching with the keyword "wifi", which was mentioned 3 times within his releases. I downgraded to 0.7.7 and even the 0.6.X stable, but still have the issue unfortunately.
(07-25-2018, 08:57 AM)JeffD Wrote: Thanks for the reply! I noticed that in the release notes. I found it by searching with the keyword "wifi", which was mentioned 3 times within his releases. I downgraded to 0.7.7 and even the 0.6.X stable, but still have the issue unfortunately.
I haven't had any luck getting it to work yet either and I've resorted to using the USB one.
So after a ton of digging, a close friend and I were able to find a solution. Here is what we found.
The wireless+bt chip is an AMPAK AP6359SA, but it uses the Broadcom 4359 chipset. After more digging, we found the kernel calling for /system/etc/firmware instead of /etc/firmware which is what the Linux distro uses. After realizing that, we researched the current stable Android release that has working wireless+bt firmware.
The folder for the firmware on the stable Android release referenced /system/etc/firmware, which is what the Linux kernel is using. We archived the file on to a USB from the Android release, then brought back up the Linux release. We moved the files over to the folder structure that the Linux kernel was calling. Once we got everything in order, we reissued the rfkill unblock all command then proceeded to reboot.
Once rebooted, the wireless module was fully recognized and scanning SSID's. To make it where we didn't have to use a wpa_supplicant file every time(for my wife's usability), I installed WICD. It works pretty well from what we have tested thus far. We still need to validate further.
But there is a good thing coming up soon to make this much easier for all, but some may want it quickly so we will write up a report and put the files out for downloading. However in 4.5+, the chipset will be fully supported out of the box. I just wanted to send an update that it is working and that we are going to put something together just in case anyone wants to leverage it prior to the 4.5 release.
I should have something written up today, but the information here can be used to get the wireless module up and going. I hope this helps others!!
Thanks for being an awesome community and making great boards!  Smile
@JeffD: Very nice! On which board? v2.0 or v2.1?
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
(07-27-2018, 10:29 AM)Bullet64 Wrote: @JeffD: Very nice! On which board? v2.0 or v2.1?
I don't have the board with me, but it was the second preorder. I imagine it is V2.1, but I'll definitely update that once I get off work!
We did heed the release notes for 0.7.8 concerning the wireless being disabled, so we ran with 0.7.7. I will give it a shot on 0.7.8 as well, just for the sake of fun.  Tongue
Yeah, i forgot about 0.7.8 With 0.7.7 on ROCKPro64 v2.1 i got this
rock64@rockpro64:~$ rfkill list 0: bt_default: Bluetooth Soft blocked: no Hard blocked: no 1: phy0: Wireless LAN Soft blocked: no Hard blocked: no 2: brcmfmac-wifi: Wireless LAN Soft blocked: no Hard blocked: no
And
rock64@rockpro64:~$ ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00    inet 127.0.0.1/8 scope host lo       valid_lft forever preferred_lft forever    inet6 ::1/128 scope host       valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000    link/ether 1e:0e:99:52:8e:40 brd ff:ff:ff:ff:ff:ff    inet 192.168.3.17/24 brd 192.168.3.255 scope global dynamic eth0       valid_lft 3368sec preferred_lft 3368sec    inet6 fe80::1c0e:99ff:fe52:8e40/64 scope link       valid_lft forever preferred_lft forever 3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000    link/ether ac:83:f3:e6:1f:b2 brd ff:ff:ff:ff:ff:ff
Will need more tests. Thanks for the hint! Big Grin
3. RockPro64 v2.1
Well. I purposely disabled, for now, the sdio (wireless and bt) as more people look at pcie support, and there seems to be some conflict of interest (probably with clocks) that prevents both of them working always, at the same time.
I have all other bits to enable it, but since it is not stable yet, I will likely leave it like that for time being Smile
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
(07-30-2018, 03:51 PM)ayufan Wrote: I have all other bits to enable it, but since it is not stable yet, I will likely leave it like that for time being Smile
Can you describe what are those "bits to enable it" ?
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 23,036 09-27-2026, 11:42 AM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 6,300 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 8,637 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 9,989 04-23-2023, 01:32 PM
Last Post: diederik
  Linux laptop does not detect the board when plugged in via USB soupy 1 7,991 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 5,289 01-03-2023, 06:53 PM
Last Post: raph
  RockPro64 linux console video mode callegar 0 2,982 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 18,590 04-30-2022, 03:57 PM
Last Post: TRS-80
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 2,988 02-17-2022, 12:10 PM
Last Post: flounder
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 12,024 01-03-2022, 10:32 AM
Last Post: whitecat23
