SOPINE MAC Address
I have bought several SOPINEs and SOPINE Boards as well as the SOPINE cluster board. I have installed the Ubuntu Mate on one SD card and copy it to others. It seems that that the SOPINE boards all have the same hardware Mac Address and this causes some other issues. Any thoughts on how should I deal with this? Thank you.
Best,
H.
(07-19-2018, 03:40 AM)htg20@yahoo.com Wrote: Hi,
Best,
H.
Unless you clone the microSD card, then the mac address becomes identical. You can edit the boot/uEnx.txt and manually reassign. Some OS build, using CPUid as mac address and some OS build randomly assign one at first boot.
Thank you. I had some other problems and I switched to Arch Linux and that MAC address is gone. Eventually I switched again to Armbian which seems to be the most stable.
  Tow-boot on Sopine module? poVoq 2 5,243 04-05-2023, 12:48 PM
Last Post: poVoq
  Benchmarking the SOPINE Modules on the Clusterboard clusterDude 4 11,099 08-20-2020, 12:56 PM
Last Post: xmixahlx
  Sopine Fedora 32 on clusterboard w/networking revoman 0 5,154 05-20-2020, 01:23 AM
Last Post: revoman
  SOPINE LTS Availability and Plan aldrich@tulip.co 0 4,377 05-14-2020, 10:00 AM
Last Post: aldrich@tulip.co
  SoPine eMMC compatibility Terra854 4 12,637 02-20-2020, 07:52 PM
Last Post: mcrognale
  Sopine baseboard CSI port camera not work olivaw 2 6,882 02-20-2019, 09:50 AM
Last Post: maya.b
  Is it Sopine, SOPINE, SOPine or SoPine? Pine 2 8,496 01-07-2019, 08:37 AM
Last Post: Pine
  +SOPINE baseboard datasheet is different gamelaster 3 9,941 09-09-2018, 05:08 PM
  How to control the SOPINE UART and SPI pins as GPIO? Pine 1 5,809 08-22-2018, 10:15 AM
Last Post: martinayotte
  Two of our sopine's only register 1GB RAM paradise 3 8,333 08-09-2018, 08:35 AM
Last Post: paradise
