Arch Linux USB3 Issues?
Hi! I flashed the SPI on my Rock64 4GB board so that I could boot from an external hard drive.
I then put ARM Arch Linux on the hard drive and it boots from the USB2 ports but the USB3 does not work at all. Regardless of what device I plug into it, even after the OS is running from the drive connected to USB2. It worked fine on Kernel 4.4 but seems to be broken in the latest.
Linux 4.17.2-1-ARCH #1 SMP Sun Jun 17 13:11:24 MDT 2018 aarch64 GNU/Linux
I see on ayu-fan's rock64 mainline kernel repo that there is a PR to fix USB3.
Does anyone know when this fix will be applied to the mainline Linux kernel?
Thanks!
(06-22-2018, 06:30 AM)decontainerized Wrote: Hi! I flashed the SPI on my Rock64 4GB board so that I could boot from an external hard drive.
Thanks!
I was able to get the USB 3 port working using the default archlinuxarm kernel (4.18 rc3) by replacing the rk3328-arm64.dtb file in the /boot/dtbs folder with the one from Ayufan's mainline kernel image.  https://github.com/ayufan-rock64/linux-m...l/releases
I'm sure there is a patch that needs to be applied somewhere upstream, but I wasn't able to locate the .dts files in this image in order to generate it.  Maybe Ayufan might point us in the right direction.
Thanks!
Nice! So I just replace the file and reboot?
Thanks for the info!
This indeed worked for me. I'm really shocked that it was so simple.
Thanks again!
Someone has made a PKGBUILD to make it work.
https://archlinuxarm.org/forum/viewtopic...k64#p58896
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 20,696 06-27-2026, 02:43 PM
  arch rock64 does not boot nemnob 1 4,877 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 4,929 06-02-2023, 07:52 AM
Last Post: diederik
  USB3.0 Issues at DietPi(Armbian) #22.02.1 t4_4t 3 5,761 08-15-2022, 06:58 PM
Last Post: TRS-80
  Linux 5.15 Kernel - openSuse mark1250 0 2,966 12-02-2021, 04:36 PM
Last Post: mark1250
  Alpine Linux isndw 12 30,168 08-12-2021, 05:41 PM
Last Post: pix
Lightbulb RK3399 Linux rtl8822cu module bluetooth not working shivarj89 0 3,002 07-29-2021, 07:19 AM
Last Post: shivarj89
Information Linux Mainline ayufan 63 145,388 05-14-2021, 10:41 AM
Last Post: Wizzard
  Linux Images (ROCK64) pineadmin 164 412,300 02-12-2021, 10:14 AM
Last Post: useful64
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 21,880 08-31-2020, 01:41 AM
Last Post: as365n4
