ayufan's bionic minimal boots only the first time
I got my rockpro64 and I am trying to get it running, I have created a sd card with the image bionic-minimal-rockpro64-0.7.3-1040-arm64.img.xz
The first boot works seamlessly, the white LED is on, hdmi tv is detected and login with rock64/rock64 takes me to the shell...
But if I turn the computer off and on again, nothing happens anymore: no LED, no signal on hdmi...
Any ideas on how to get more information or what might be happening?
mount the image on loopback and check for first run scripts.
The 0.7.3 is likely to be broken.
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
(07-07-2018, 02:41 PM)ayufan Wrote: The 0.7.3 is likely to be broken.
ok, stretch minimal fails with:
cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
I will try older/stable releases, thanks! Smile
0.6.59 boots fine after shutdown, so I will go with that for now, thanks again!
It was a problem of 0.7.3. It is fixed now.
Releases:
Buy me a Beer
(07-11-2018, 03:57 AM)ayufan Wrote: It was a problem of 0.7.3. It is fixed now.
I installed latest stretch version and the error is still there. Can there anything be done? Best regards from Slovenia
This is a very old thread - would recommend you start with the bionic minimal 0.7.9 thread from here.
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 8,638 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 9,989 04-23-2023, 01:32 PM
Last Post: diederik
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 3,429 07-24-2021, 09:46 PM
Last Post: Mentaluproar
  ayufan kernel update unbootable TheHunter 2 6,161 03-12-2021, 05:17 PM
Last Post: LMM
Question Ayufan RockPro64 updates? hemertje 3 10,369 10-22-2020, 01:16 PM
Last Post: dukla2000
  Kernel Update from 4.4 (Ayufan) on Ubuntu 20.04 db579 3 9,960 10-22-2020, 01:12 PM
  Slow/dead ethernet on (non-Ayufan) Linux Mainline (fixed) mmatyas 1 6,292 04-17-2020, 02:53 AM
Last Post: Thra11
  New Pre-release 0.10.9 from Ayufan Bullet64 0 3,949 04-09-2020, 06:49 AM
Last Post: Bullet64
  Ayufan 5.4.0 rc1 release - cannot boot Mentaluproar 2 9,434 01-05-2020, 02:39 PM
Last Post: mmiigg
  Reboot problem on latest ayufan and 4.4 /dev/null 2 6,668 11-27-2019, 04:23 AM
