Bluetooth CSR8510 not working with Rock64 Android 7.1
Hello Guys,
I have the Rock64 with the last version of Android installed on it. All is good excepted that my CSR8510 BT dongle is not working. I tried everything i can see on my rasperry pie with no issue but not on Rock64.
Anybody has any BT working on this platform on Android ?
Seb
(10-06-2017, 01:47 PM)efreeze Wrote: Hello Guys,
Seb
Blkuetooth does not work as yet. Perhaps an upfate soon.
Seb
Thanks for the answer, is it a limitation on the Rock64 ? or on the Android code ?
Seb
For now, it is a limitation in Android. Support should be coming later for Wifi/Bluetooth, but I can't say when. I look forward to it though.
Does Android still not support the CSR 8510 bluetooth dongle? Just asking as the last report was Oct 2017 and said updates were coming. It is April 2018.
I have the CSR 8510 USB dongle plugged in directly to the top USB port of the Rock64. Using Android TV, there is no response. When I click the Bluetooth button in ATV, it slides to on for about 10 seconds then reverses by itself and slides back to off. It doesn't matter if it is in the top usb, bottom usb, or in the blue usb 3.0 port. None of them work with the CSR8510. There is no error message or anything like that in Android Tv.
Does anyone know how to get the usb dongle to work?
Yet another one with non working CSR8510.
Hope we'll not have to wait infinitely...
According to posts here in Rock64's community forum area that the Bluetooth usb dongle is functional in Linux so one can port the Linux driver to Android:
http://freesoftwaremagazine.com/articles/drivers_linux/
That is how to do it however I am currently not available to work on that type and scope of project but it probably wouldn't take a whole long time in the right hands. It helps to be familiar with embedded concepts of Bluetooth.
Any updates on getting the Bluetooth USB doggle (sold in the Pine64 Store) to work on Android?!
I was curious if anyone has tried to compile
https://github.com/rockchip-linux/kernel
and then use ADB or fastboot from the Android SDK to sideload the kernel and try to get the bluetooth working? I haven't been able to do the experiment yet.
  Android Images (ROCK64) pineadmin 77 235,023 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 12,186 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 12,466 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 10,716 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,119 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 6,840 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,093 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 10,400 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,057 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,234 09-18-2020, 07:58 PM
Last Post: BowerR64
