Compiling android kernel
Hey guys!
I need to change a few lines of code in the android kernel. I'm using this build but can't seem to find the kernel sources used to compile it. I tried to compile these sources up to the 3.10.104 merge tag but I get a lot of compilation errors. What gcc version should I be using? And once I compile the kernel how do I flash it to the rock64? Do I just use the compiled Image file as the kernel.img in AndroidTool or do I have to package it somehow?
Thanks!
(06-12-2018, 04:38 AM)ddaarrius Wrote: Hey guys!
Thanks!
ayufan is the best one to answer most of your questions. All I can say is that the build is done inside this docker container as instructed by this Jenkinsfile. Hopefully perusing those two files will give you an idea as to what is going on.
Thank you very much, this seems to be exactly what I need, I'll try it out soon.
  Android Images (ROCK64) pineadmin 77 245,875 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,415 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,695 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,867 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,865 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,569 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,738 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,399 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,670 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 9,027 09-18-2020, 07:58 PM
Last Post: BowerR64
