[Archived] New Releases from ayufan! (0.6.XX)
(05-24-2018, 02:54 PM)Luke Wrote: That you should ask Lakka devs ...
I have believed it was an initiative by Ayufan, sorry...
0.6.44 released
Quote:This post was last modified: 5 hours ago by Luke. Edit Reason: now 0.6.41
Was 0.6.44 actually, Luke :-P
Maybe we should stop playing wacka-mole with the release numbers and just leave it at "newer" not-so-green-and-experimental images are available? Big Grin Big Grin
And probably also point out that people who have been trying some of the earlier 0.6.x images may want to upgrade to 0.6.44 ASAP, as there are some memory timing gremlins which may only be identifiable after a full memtest, and may cause data corruption long term if they are affected. Edit: I don't mean to be alarmist - it is certainly possible a lot of the images are fine, but some of the images do have memory related and timing gremlins, so even if it does boot, it could have problems that bit you later.
To test on a board with 4GB of memory, run (the 3G is the parameter that specifies the amount of memory to test, 3GB in this case):
sudo apt-get update && sudo apt-get install -y memtester sudo MEMTESTER_TEST_MASK=6144 memtester 3G 1
And if run with no error, your setup should be fine. If it spits the dummy with a load of
FAILURE: 0x6bcf4519d723f861 != 0x9430bae788dc3f86 at offset 0x00000008. FAILURE: 0x9430bae628dc0786 != 0x6bcf45187723c071 at offset 0x00000010. FAILURE: 0x6bcf4519d723f871 != 0x9430bae788dc3fb6 at offset 0x00000018.
you have problems waiting to happen!
Note - do not omit the MEMTESTER_TEST_MASK - it ignores tests that would trigger false positives.
I ran a test
root@rock64:# sudo MEMTESTER_TEST_MASK=6144 memtester 3G 1 memtester version 4.3.0 (32-bit) Copyright (C) 2001-2012 Charles Cazabon. Licensed under the GNU General Public License version 2 (only). pagesize is 4096 pagesizemask is 0xfffff000 using testmask 0x1800 want 3072MB (3221225472 bytes) got  2738MB (2871566336 bytes), trying mlock ...locked. Loop 1/1:  Stuck Address       : ok  Bit Spread          : ok  Bit Flip            : ok Done.
(05-28-2018, 10:14 PM)i69fstop Wrote: I ran a test
Beautiful, and thanks. On 0.6.44?
I've run it on these images so far after a false start and wrong memtester mask, and haven't had issue, but once I've finished that, I'm hoping to run a few more tests and then get it to fail repeatedly.
pass - artful-minimal-rock64-0.5.15-136-arm64.img - http://ix.io/1bG2
pass - bionic-minimal-rock64-0.6.41-227-arm64.img - http://ix.io/1bGf
pass - bionic-minimal-rock64-0.6.44-239-arm64.img - http://ix.io/1bGz
pass - bionic-minimal-rock64-0.7.4-234-arm64.img - http://ix.io/1bGP
Note that 0.7.4 isn't on github anymore atm - it was a build that came out when he was testing getting the rockpro64 builds to work, and has been axed now both are being generated together, so 0.6.44 is still the latest image at time of writing.
yes
root@rock64:~# uname -a Linux rock64 4.4.126-rockchip-ayufan-239 #1 SMP Sun May 27 18:38:24 UTC 2018 aarch64 GNU/Linux root@rock64:~#
My rock64 (ROCK64_V2.0 2017-0713 4GB) :
After "apt upgrade" to 0.6.41, boot stopped at "Starting resolvconf-pull-resolved.service...".
Reinstalled with bionic-minimal-rock64-0.6.44-239-arm64.img.xz, working now.
0.6.41 boot.log:
▒▒▒|▒▒DDR version 1.08 20170628 In LPDDR3 333MHz Bus Width=32 Col=11 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=4096MB ddrconfig:7 OUT U-Boot SPL 2017.09-ga0a2b48 (Apr 22 2018 - 12:19:12) setup_ddr_param  1 booted from eMMC Trying to boot from MMC1 NOTICE:  BL31: v1.3(debug):9d3f591 NOTICE:  BL31: Built : 14:39:02, Jan 17 2018 NOTICE:  BL31:Rockchip release version: v1.3 INFO:    ARM GICv2 driver initialized INFO:    Using opteed sec cpu_context! INFO:    boot cpu mask: 1 INFO:    plat_rockchip_pmu_init: pd status 0xe INFO:    BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR:   Error initializing runtime service opteed_fast INFO:    BL31: Preparing for EL3 exit to normal world INFO:    Entry point address = 0x200000 INFO:    SPSR = 0x3c9 U-Boot 2017.09-ga0a2b48 (Apr 22 2018 - 12:19:32 +0000), Build: jenkins-linux-build-rock-64-210 Model: Pine64 Rock64 DRAM:  4 GiB MMC:   rksdmmc@ff520000: 0, rksdmmc@ff500000: 1 Card did not respond to voltage select! mmc_init: -95, time 9 *** Warning - No block device, using default environment In:    serial@ff130000 Out:   serial@ff130000 Err:   serial@ff130000 Model: Pine64 Rock64 misc_init_r cpuid=55524b50303930303300000000050525 serial=81b3938c80f1d3e Net:   eth0: ethernet@ff540000 Hit any key to stop autoboot:  0 switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:6... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf reading /extlinux/extlinux.conf 688 bytes read in 2 ms (335.9 KiB/s) select kernel 1:      kernel-latest 2:      kernel-previous Enter choice: 1:        kernel-latest Retrieving file: /initrd.img reading /initrd.img 5917625 bytes read in 720 ms (7.8 MiB/s) Retrieving file: /Image reading /Image 19644424 bytes read in 2377 ms (7.9 MiB/s) append: rw root=LABEL=linux-root rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=be:c6:e6:16:2a:ff eth1addr=be:c6:e6:16:2a:1f serial=81b3938c80f1d3e cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 Retrieving file: /dtb reading /dtb 56670 bytes read in 9 ms (6 MiB/s) ## Flattened Device Tree blob at 01f00000    Booting using the fdt blob at 0x1f00000    Loading Ramdisk to fc95c000, end fcf00bb9 ... OK    Loading Device Tree to 00000000fc94b000, end 00000000fc95bd5d ... OK Starting kernel ... [    0.000000] Booting Linux on physical CPU 0x0 [    0.000000] Initializing cgroup subsys cpuset [    0.000000] Initializing cgroup subsys cpu [    0.000000] Initializing cgroup subsys cpuacct [    0.000000] Linux version 4.4.126-rockchip-ayufan-227 (root@5e7a8eef6138) (gcc version 7.2.0 (Ubuntu/Linaro 7.2.0-6ubuntu1) ) #1 SMP Tue May 22 08:12:53 UTC 2018 [    0.000000] Boot CPU: AArch64 Processor [410fd034] [    0.000000] psci: probing for conduit method from DT. [    0.000000] psci: PSCIv1.0 detected in firmware. [    0.000000] psci: Using standard PSCI v0.2 function IDs [    0.000000] psci: MIGRATE_INFO_TYPE not supported. [    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0fef2c000 s46248 r8192 d31576 u86016 [    0.000000] Detected VIPT I-cache on CPU0 [    0.000000] CPU features: enabling workaround for ARM erratum 845719 [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1027656 [    0.000000] Kernel command line: earlyprintk=uart8250-32bit,0xff130000 rw root=LABEL=linux-root rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=be:c6:e6:16:2a:ff eth1addr=be:c6:e6:16:2a:1f serial=81b3938c80f1d3e cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [    0.000000] software IO TLB [mem 0xf5e00000-0xf9e00000] (64MB) mapped at [ffffffc0f5e00000-ffffffc0f9dfffff] [    0.000000] Memory: 4011556K/4175872K available (11966K kernel code, 1584K rwdata, 4440K rodata, 1152K init, 755K bss, 164316K reserved, 0K cma-reserved) [    0.000000] Virtual kernel memory layout: [    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB) [    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB) [    0.000000]       .init : 0xffffff8009090000 - 0xffffff80091b0000   (  1152 KB) [    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008c30000   ( 11968 KB) [    0.000000]     .rodata : 0xffffff8008c30000 - 0xffffff8009090000   (  4480 KB) [    0.000000]       .data : 0xffffff80091b0000 - 0xffffff800933c008   (  1585 KB) [    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum) [    0.000000]               0xffffffbdc0008000 - 0xffffffbdc3fc0000   (    63 MB actual) [    0.000000]     fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB) [    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB) [    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc0ff000000   (  4078 MB) [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [    0.000000] Hierarchical RCU implementation. [    0.000000]  Build-time adjustment of leaf fanout to 64. [    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4 [    0.000000] NR_IRQS:64 nr_irqs:64 0 [    0.000000] GIC: Using split EOI/Deactivate mode [    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [    0.001115] Console: colour dummy device 80x25 [    0.002875] console [tty0] enabled [    0.002934] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000) [    0.003018] pid_max: default: 32768 minimum: 301 [    0.003198] Security Framework initialized [    0.003243] Yama: becoming mindful. [    0.003308] AppArmor: AppArmor disabled by boot time parameter [    0.003433] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [    0.003486] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [    0.004552] Initializing cgroup subsys io [    0.004614] Initializing cgroup subsys memory [    0.004686] Initializing cgroup subsys devices [    0.004739] Initializing cgroup subsys freezer [    0.004789] Initializing cgroup subsys net_cls [    0.004839] Initializing cgroup subsys perf_event [    0.004889] Initializing cgroup subsys net_prio [    0.004944] Initializing cgroup subsys hugetlb [    0.004992] Initializing cgroup subsys pids [    0.005081] ftrace: allocating 44704 entries in 175 pages [    0.131051] sched-energy: CPU device node has no sched-energy-costs [    0.131121] Invalid sched_group_energy for CPU0 [    0.131162] CPU0: update cpu_capacity 1024 [    0.131273] ASID allocator initialised with 32768 entries [    0.137593] Detected VIPT I-cache on CPU1 [    0.137666] Invalid sched_group_energy for CPU1 [    0.137673] CPU1: update cpu_capacity 1024 [    0.137678] CPU1: Booted secondary processor [410fd034] [    0.138446] Detected VIPT I-cache on CPU2 [    0.138500] Invalid sched_group_energy for CPU2 [    0.138505] CPU2: update cpu_capacity 1024 [    0.138510] CPU2: Booted secondary processor [410fd034] [    0.139246] Detected VIPT I-cache on CPU3 [    0.139296] Invalid sched_group_energy for CPU3 [    0.139302] CPU3: update cpu_capacity 1024 [    0.139306] CPU3: Booted secondary processor [410fd034] [    0.139426] Brought up 4 CPUs [    0.139887] SMP: Total of 4 processors activated. [    0.139936] CPU: All CPU(s) started at EL2 [    0.140013] alternatives: patching kernel code [    0.140339] Invalid sched_group_energy for CPU3 [    0.140388] Invalid sched_group_energy for Cluster3 [    0.140428] Invalid sched_group_energy for CPU2 [    0.140468] Invalid sched_group_energy for Cluster2 [    0.140508] Invalid sched_group_energy for CPU1 [    0.140548] Invalid sched_group_energy for Cluster1 [    0.140588] Invalid sched_group_energy for CPU0 [    0.140628] Invalid sched_group_energy for Cluster0 [    0.141595] devtmpfs: initialized [    0.162691] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [    0.162806] futex hash table entries: 1024 (order: 4, 65536 bytes) [    0.163477] xor: measuring software checksum speed [    0.172701]    8regs     :  1080.000 MB/sec [    0.182781]    8regs_prefetch:   968.000 MB/sec [    0.192861]    32regs    :  1456.000 MB/sec [    0.202944]    32regs_prefetch:  1224.000 MB/sec [    0.202988] xor: using function: 32regs (1456.000 MB/sec) [    0.203065] pinctrl core: initialized pinctrl subsystem [    0.204630] NET: Registered protocol family 16 [    0.209202] cpuidle: using governor ladder [    0.213225] cpuidle: using governor menu [    0.213962] vdso: 2 pages (1 code @ ffffff8008c36000, 1 data @ ffffff80091b4000) [    0.214070] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [    0.214827] DMA: preallocated 1024 KiB pool for atomic allocations [    0.283401] raid6: int64x1  gen()   199 MB/s [    0.300441] raid6: int64x1  xor()   169 MB/s [    0.317669] raid6: int64x2  gen()   324 MB/s [    0.334779] raid6: int64x2  xor()   259 MB/s [    0.352069] raid6: int64x4  gen()   480 MB/s [    0.369186] raid6: int64x4  xor()   326 MB/s [    0.386347] raid6: int64x8  gen()   386 MB/s [    0.403460] raid6: int64x8  xor()   302 MB/s [    0.420657] raid6: neonx1   gen()   359 MB/s [    0.437880] raid6: neonx1   xor()   353 MB/s [    0.455079] raid6: neonx2   gen()   550 MB/s [    0.472157] raid6: neonx2   xor()   455 MB/s [    0.489362] raid6: neonx4   gen()   742 MB/s [    0.506559] raid6: neonx4   xor()   558 MB/s [    0.523699] raid6: neonx8   gen()   761 MB/s [    0.540909] raid6: neonx8   xor()   568 MB/s [    0.540951] raid6: using algorithm neonx8 gen() 761 MB/s [    0.540991] raid6: .... xor() 568 MB/s, rmw enabled [    0.541032] raid6: using intx1 recovery algorithm [    0.541627] mpp venc_srv: mpp_probe enter [    0.541697] mpp venc_srv: init success [    0.544263] vcc_sd: regulator get failed, ret=-517 [    0.544772] vcc_host_5v: supplied by vcc_sys [    0.546241] iommu: Adding device ff350000.vpu_service to group 0 [    0.546405] iommu: Adding device ff351000.avsd to group 1 [    0.546530] iommu: Adding device ff360000.rkvdec to group 2 [    0.546653] iommu: Adding device ff330000.h265e to group 3 [    0.546774] iommu: Adding device ff340000.vepu to group 4 [    0.546900] iommu: Adding device ff370000.vop to group 5 [    0.548174] rk_iommu ff360480.iommu: can't get aclk [    0.548236] rk_iommu ff360480.iommu: can't get hclk [    0.549777] SCSI subsystem initialized [    0.550210] usbcore: registered new interface driver usbfs [    0.550325] usbcore: registered new interface driver hub [    0.550505] usbcore: registered new device driver usb [    0.550710] media: Linux media interface: v0.10 [    0.550812] Linux video capture interface: v2.00 [    0.550958] pps_core: LinuxPPS API ver. 1 registered [    0.550999] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [    0.551096] PTP clock support registered [    0.553134] Advanced Linux Sound Architecture Driver Initialized. [    0.554178] Bluetooth: Core ver 2.21 [    0.554295] NET: Registered protocol family 31 [    0.554337] Bluetooth: HCI device and connection manager initialized [    0.554389] Bluetooth: HCI socket layer initialized [    0.554437] Bluetooth: L2CAP socket layer initialized [    0.554512] Bluetooth: SCO socket layer initialized [    0.555349] NetLabel: Initializing [    0.555397] NetLabel:  domain hash size = 128 [    0.555436] NetLabel:  protocols = UNLABELED CIPSOv4 [    0.555545] NetLabel:  unlabeled traffic allowed by default [    0.556180] rockchip-cpuinfo cpuinfo: Serial         : 81b3938c80f1d3ed [    0.557515] clocksource: Switched to clocksource arch_sys_counter [    0.664941] NET: Registered protocol family 2 [    0.665901] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [    0.666453] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes) [    0.668012] TCP: Hash tables configured (established 32768 bind 32768) [    0.668240] UDP hash table entries: 2048 (order: 5, 196608 bytes) [    0.668613] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes) [    0.669292] NET: Registered protocol family 1 [    0.670021] RPC: Registered named UNIX socket transport module. [    0.670074] RPC: Registered udp transport module. [    0.670114] RPC: Registered tcp transport module. [    0.670155] RPC: Registered tcp NFSv4.1 backchannel transport module. [    0.671253] Trying to unpack rootfs image as initramfs... [    1.144621] Freeing initrd memory: 5776K [    1.145930] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [    1.147545] kvm [1]: 8-bit VMID [    1.147589] kvm [1]: Hyp mode initialized successfully [    1.148158] kvm [1]: interrupt-controller@ff814000 IRQ44 [    1.148632] kvm [1]: timer IRQ3 [    1.152986] audit: initializing netlink subsys (disabled) [    1.153099] audit: type=2000 audit(1.076:1): initialized [    1.154395] HugeTLB registered 2 MB page size, pre-allocated 0 pages [    1.167842] VFS: Disk quotas dquot_6.6.0 [    1.168158] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [    1.171317] squashfs: version 4.0 (2009/01/31) Phillip Lougher [    1.173705] NFS: Registering the id_resolver key type [    1.173803] Key type id_resolver registered [    1.173843] Key type id_legacy registered [    1.173906] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [    1.175164] fuse init (API version 7.23) [    1.176629] JFS: nTxBlock = 8192, nTxLock = 65536 [    1.186640] SGI XFS with ACLs, security attributes, realtime, no debug enabled [    1.189765] Key type big_key registered [    1.189924] [    1.189924] TEE Core Framework initialization (ver 1:0.1) [    1.190030] TEE armv7 Driver initialization [    1.190678] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0" [    1.190731] TEE core: Alloc the misc device "opteearmtz00" (id=0) [    1.191154] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62) [    1.196952] NET: Registered protocol family 38 [    1.197053] Key type asymmetric registered [    1.197104] Asymmetric key parser 'x509' registered [    1.197576] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248) [    1.197900] io scheduler noop registered [    1.197955] io scheduler deadline registered (default) [    1.198069] io scheduler cfq registered [    1.201072] phy phy-ff450000.syscon:usb2-phy@100.1: Failed to get VBUS supply regulator [    1.202266] rockchip-u3phy ff470000.usb3-phy: Failed to get VBUS supply regulator [    1.205194] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully [    1.209842] rk-vcodec vpu_combo: no regulator for vcodec [    1.210203] rk-vcodec vpu_combo: failed on clk_get clk_cabac [    1.210259] rk-vcodec vpu_combo: failed on clk_get clk_core [    1.210393] platform ff350000.vpu_service: probe device [    1.210537] platform ff350000.vpu_service: vpu mmu dec ffffffc0f5044410 [    1.210948] platform ff350000.vpu_service: allocator is drm [    1.211082] platform ff350000.vpu_service: checking hw id 0 [    1.212166] platform ff351000.avsd: probe device [    1.212340] platform ff351000.avsd: vpu mmu dec ffffffc0f5044410 [    1.212790] platform ff351000.avsd: allocator is drm [    1.212888] platform ff351000.avsd: checking hw id 6731 [    1.215218] rk-vcodec vpu_combo: could not find power_model node [    1.215279] rk-vcodec vpu_combo: init success [    1.215788] rk-vcodec ff360000.rkvdec: no regulator for vcodec [    1.215888] rk-vcodec ff360000.rkvdec: parent devfreq is disabled [    1.216600] rk-vcodec ff360000.rkvdec: probe device [    1.216698] rk-vcodec ff360000.rkvdec: vpu mmu dec ffffffc0f5045810 [    1.217293] rk-vcodec ff360000.rkvdec: allocator is drm [    1.217437] rk-vcodec ff360000.rkvdec: checking hw id 3410 [    1.218405] rk-vcodec ff360000.rkvdec: init success [    1.219562] probe device ff330000.h265e [    1.220029] mpp_dev ff330000.h265e: try to get iommu dev ffffffc0f5046010 [    1.220630] mpp_dev ff330000.h265e: resource ready, register device [    1.221230] probe device ff340000.vepu [    1.221732] mpp_dev ff340000.vepu: try to get iommu dev ffffffc0f5046810 [    1.222196] mpp_dev ff340000.vepu: resource ready, register device [    1.225737] dma-pl330 ff1f0000.dmac: Loaded driver for PL330 DMAC-241330 [    1.225801] dma-pl330 ff1f0000.dmac:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [    1.227084] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled [    1.230243] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 13, base_baud = 1500000) is a 16550A [    1.345528] console [ttyS2] enabled [    1.347731] [drm] Initialized drm 1.1.0 20060810 [    1.352024] [drm] Rockchip DRM driver version: v1.0.0 [    1.352857] rockchip-drm display-subsystem: devfreq is not set [    1.353937] rockchip-vop ff370000.vop: invalid resource [    1.354442] rockchip-vop ff370000.vop: failed to get vop lut registers [    1.355080] rockchip-vop ff370000.vop: invalid resource [    1.355594] rockchip-vop ff370000.vop: failed to get vop cabc lut registers [    1.356591] rockchip-drm display-subsystem: bound ff370000.vop (ops 0xffffff8008cfd3a0) [    1.357831] i2c i2c-4: of_i2c: modalias failure on /hdmi@ff3c0000/ports [    1.358468] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver [    1.359372] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2) [    1.361677] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops 0xffffff8008cf40d0) [    1.362472] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [    1.363109] [drm] No driver support for vblank timestamp query. [    1.363791] rockchip-drm display-subsystem: failed to parse display resources [    1.364538] rockchip-drm display-subsystem: No connectors reported connected with modes [    1.365377] [drm] Cannot find any crtc or sizes - going 1024x768 [    1.392294] Console: switching to colour frame buffer device 128x48 [    1.412385] rockchip-drm display-subsystem: fb0:  frame buffer device [    1.419525] usbcore: registered new interface driver udl [    1.423284] Unable to detect cache hierarchy for CPU 0 [    1.425607] brd: module loaded [    1.436284] loop: module loaded [    1.437254] lkdtm: No crash points registered, enable through debugfs [    1.440270] rockchip-spi ff190000.spi: no high_speed pinctrl state [    1.442158] m25p80 spi32766.0: gd25q128 (16384 Kbytes) [    1.442904] 2 ofpart partitions found on MTD device spi32766.0 [    1.443666] Creating 2 MTD partitions on "spi32766.0": [    1.444328] 0x000000008000-0x000000400000 : "loader" [    1.446715] 0x0000007c0000-0x000000800000 : "vendor" [    1.451692] force_sf_dma_mode is ignored if force_thresh_dma_mode is set. [    1.452803] rk_gmac-dwmac ff540000.ethernet: clock input or output? (input). [    1.453732] rk_gmac-dwmac ff540000.ethernet: TX delay(0x26). [    1.454456] rk_gmac-dwmac ff540000.ethernet: RX delay(0x11). [    1.455203] rk_gmac-dwmac ff540000.ethernet: integrated PHY? (no). [    1.456253] rk_gmac-dwmac ff540000.ethernet: cannot get clock clk_mac_speed [    1.457151] rk_gmac-dwmac ff540000.ethernet: clock input from PHY [    1.462957] rk_gmac-dwmac ff540000.ethernet: init for RGMII [    1.463862] stmmac - user ID: 0x10, Synopsys ID: 0x35 [    1.464523]  Ring mode enabled [    1.464923]  DMA HW capability register supported [    1.465517]  Normal descriptors [    1.481519]  RX Checksum Offload Engine supported (type 2) [    1.489997]  Wake-Up On Lan supported [    1.498343]  Enable RX Mitigation via HW Watchdog Timer [    1.582364] libphy: stmmac: probed [    1.590686] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active [    1.599378] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01) [    1.609736] Rockchip WiFi SYS interface (V1.00) ... [    1.618476] usbcore: registered new interface driver cdc_ether [    1.627156] usbcore: registered new interface driver rndis_host [    1.637975] phy phy-ff470000.usb3-phy.2: u3phy u2 power on [    1.646395] phy phy-ff470000.usb3-phy.3: u3phy u3 power on [    1.655932] ff580000.usb supply vusb_d not found, using dummy regulator [    1.664401] ff580000.usb supply vusb_a not found, using dummy regulator [    1.685167] dwc2 ff580000.usb: DWC OTG Controller [    1.693022] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1 [    1.701003] dwc2 ff580000.usb: irq 41, io mem 0xff580000 [    1.708945] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [    1.716748] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.724565] usb usb1: Product: DWC OTG Controller [    1.732044] usb usb1: Manufacturer: Linux 4.4.126-rockchip-ayufan-227 dwc2_hsotg [    1.739926] usb usb1: SerialNumber: ff580000.usb [    1.748469] hub 1-0:1.0: USB hub found [    1.755911] hub 1-0:1.0: 1 port detected [    1.764719] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [    1.772368] ehci-pci: EHCI PCI platform driver [    1.779795] ehci-platform: EHCI generic platform driver [    1.789954] ehci-platform ff5c0000.usb: EHCI Host Controller [    1.797805] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2 [    1.805756] ehci-platform ff5c0000.usb: irq 42, io mem 0xff5c0000 [    1.818552] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00 [    1.826288] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [    1.833799] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.841331] usb usb2: Product: EHCI Host Controller [    1.848608] usb usb2: Manufacturer: Linux 4.4.126-rockchip-ayufan-227 ehci_hcd [    1.856211] usb usb2: SerialNumber: ff5c0000.usb [    1.864625] hub 2-0:1.0: USB hub found [    1.871958] hub 2-0:1.0: 1 port detected [    1.879885] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [    1.887428] ohci-platform: OHCI generic platform driver [    1.895600] ohci-platform ff5d0000.usb: Generic Platform OHCI controller [    1.903758] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3 [    1.911896] ohci-platform ff5d0000.usb: irq 43, io mem 0xff5d0000 [    1.974831] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [    1.982827] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.990844] usb usb3: Product: Generic Platform OHCI controller [    1.998740] usb usb3: Manufacturer: Linux 4.4.126-rockchip-ayufan-227 ohci_hcd [    2.006868] usb usb3: SerialNumber: ff5d0000.usb [    2.015730] hub 3-0:1.0: USB hub found [    2.023571] hub 3-0:1.0: 1 port detected [    2.032778] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller [    2.041147] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4 [    2.049640] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00210010 [    2.058020] xhci-hcd xhci-hcd.10.auto: irq 179, io mem 0xff600000 [    2.066393] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 [    2.074614] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    2.082864] usb usb4: Product: xHCI Host Controller [    2.090963] usb usb4: Manufacturer: Linux 4.4.126-rockchip-ayufan-227 xhci-hcd [    2.099359] usb usb4: SerialNumber: xhci-hcd.10.auto [    2.108629] hub 4-0:1.0: USB hub found [    2.116793] hub 4-0:1.0: 1 port detected [    2.125542] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller [    2.134296] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 5 [    2.143067] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM. [    2.151972] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003 [    2.160541] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    2.169150] usb usb5: Product: xHCI Host Controller [    2.177470] usb usb5: Manufacturer: Linux 4.4.126-rockchip-ayufan-227 xhci-hcd [    2.186066] usb usb5: SerialNumber: xhci-hcd.10.auto [    2.195371] hub 5-0:1.0: USB hub found [    2.203654] hub 5-0:1.0: 1 port detected [    2.214296] usbcore: registered new interface driver iforce [    2.222889] usbcore: registered new interface driver xpad [    2.231836] usbcore: registered new interface driver usbtouchscreen [    2.241366] i2c /dev entries driver [    2.252735] rk808 1-0018: Pmic Chip id: 0x8050 [    2.262045] rk808 1-0018: source: on=0x40, off=0x01 [    2.277028] DCDC_REG1: supplied by vcc_sys [    2.288562] DCDC_REG2: supplied by vcc_sys [    2.299279] DCDC_REG3: supplied by vcc_sys [    2.309057] DCDC_REG4: supplied by vcc_sys [    2.318551] vcc_sd: supplied by vcc_io [    2.326147] LDO_REG1: supplied by vcc_io [    2.336960] LDO_REG2: supplied by vcc_io [    2.347838] LDO_REG3: supplied by vcc_sys [    2.358556] rk808 1-0018: register rk8050 regulators [    2.366391] rk8xx-gpio rk8xx-gpio: register rk8050 gpio successful [    2.376108] input: rk8xx_pwrkey as /devices/platform/ff160000.i2c/i2c-1/1-0018/input/input0 [    2.394312] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0 [    2.403020] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff8009e7a000 [    2.412914] IR NEC protocol handler initialized [    2.420533] IR RC5(x/sz) protocol handler initialized [    2.428174] IR RC6 protocol handler initialized [    2.435689] IR JVC protocol handler initialized [    2.443045] IR Sony protocol handler initialized [    2.450352] IR SANYO protocol handler initialized [    2.457664] IR Sharp protocol handler initialized [    2.464939] IR MCE Keyboard/mouse protocol handler initialized [    2.472362] IR XMP protocol handler initialized [    2.480273] usbcore: registered new interface driver uvcvideo [    2.487677] USB Video Class driver (1.1.1) [    2.501829] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com [    2.509687] Bluetooth: Virtual HCI driver ver 1.5 [    2.517346] Bluetooth: HCI UART driver ver 2.3 [    2.524653] Bluetooth: HCI UART protocol H4 registered [    2.531921] Bluetooth: HCI UART protocol LL registered [    2.539041] Bluetooth: HCI UART protocol ATH3K registered [    2.546277] usbcore: registered new interface driver bfusb [    2.553605] usbcore: registered new interface driver btusb [    2.561152] cpu cpu0: cpu_leakage=9 [    2.568039] cpu cpu0: cpu_leakage=9 [    2.574637] cpu cpu0: cpu_leakage-volt-sel=1 [    2.584411] sdhci: Secure Digital Host Controller Interface driver [    2.591286] sdhci: Copyright(c) Pierre Ossman [    2.597851] Synopsys Designware Multimedia Card Interface Driver [    2.606045] dwmmc_rockchip ff520000.dwmmc: IDMAC supports 32-bit address mode. [    2.610556] dwmmc_rockchip ff520000.dwmmc: Using internal DMA controller. [    2.614890] dwmmc_rockchip ff520000.dwmmc: Version ID is 270a [    2.619184] dwmmc_rockchip ff520000.dwmmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo [    2.623911] dwmmc_rockchip ff520000.dwmmc: 'clock-freq-min-max' property was deprecated. [    2.640567] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [    2.655603] dwmmc_rockchip ff520000.dwmmc: 1 slots initialized [    2.660201] dwmmc_rockchip ff500000.dwmmc: IDMAC supports 32-bit address mode. [    2.664419] dwmmc_rockchip ff500000.dwmmc: Using internal DMA controller. [    2.668481] dwmmc_rockchip ff500000.dwmmc: Version ID is 270a [    2.672473] dwmmc_rockchip ff500000.dwmmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo [    2.676959] dwmmc_rockchip ff500000.dwmmc: 'clock-freq-min-max' property was deprecated. [    2.692533] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [    2.707620] dwmmc_rockchip ff500000.dwmmc: 1 slots initialized [    2.711944] sdhci-pltfm: SDHCI platform and OF driver helper [    2.717950] hidraw: raw HID events driver (C) Jiri Kosina [    2.722969] usbcore: registered new interface driver usbhid [    2.727203] usbhid: USB HID core driver [    2.731230] mmc0: MAN_BKOPS_EN bit is not set [    2.733418] usbcore: registered new interface driver snd-usb-audio [    2.734736] rk3328-codec ff410000.codec: spk_depop_time use default value. [    2.739359] u32 classifier [    2.739376] Netfilter messages via NETLINK v0.30. [    2.739456] ip_set: protocol 6 [    2.739661] Initializing XFRM netlink socket [    2.740290] NET: Registered protocol family 10 [    2.741472] NET: Registered protocol family 17 [    2.741545] NET: Registered protocol family 15 [    2.741593] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. [    2.741619] Bridge firewalling registered [    2.741769] Bluetooth: RFCOMM socket layer initialized [    2.741812] Bluetooth: RFCOMM ver 1.11 [    2.741825] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [    2.741845] Bluetooth: HIDP socket layer initialized [    2.741911] 8021q: 802.1Q VLAN Support v1.8 [    2.741939] [WLAN_RFKILL]: Enter rfkill_wlan_init [    2.742302] [BT_RFKILL]: Enter rfkill_rk_init [    2.742474] Key type dns_resolver registered [    2.744140] Registered cp15_barrier emulation handler [    2.744150] Registered setend emulation handler [    2.744961] registered taskstats version 1 [    2.747196] Btrfs loaded, integrity-checker=on [    2.747318] BTRFS: selftest: Running btrfs free space cache tests [    2.747362] BTRFS: selftest: Running extent only tests [    2.747383] BTRFS: selftest: Running bitmap only tests [    2.747411] BTRFS: selftest: Running bitmap and extent tests [    2.747438] BTRFS: selftest: Running space stealing from bitmap to extent [    2.748288] BTRFS: selftest: Free space cache tests finished [    2.748292] BTRFS: selftest: Running extent buffer operation tests [    2.748293] BTRFS: selftest: Running btrfs_split_item tests [    2.748342] BTRFS: selftest: Running find delalloc tests [    2.878170] mmc_host mmc0: Bus speed (slot 0) = 200000000Hz (slot req 200000000Hz, actual 200000000HZ div = 0) [    2.990092] BTRFS: selftest: Running btrfs_get_extent tests [    2.994352] BTRFS: selftest: Running hole first btrfs_get_extent test [    2.998542] BTRFS: selftest: Running outstanding_extents tests [    3.002602] BTRFS: selftest: Running qgroup tests [    3.006439] BTRFS: selftest: Qgroup basic add [    3.010254] BTRFS: selftest: Qgroup multiple refs test [    3.026228] asoc-simple-card hdmi-sound: i2s-hifi <-> ff000000.i2s mapping ok [    3.052786] asoc-simple-card sound: rk3328-hifi <-> ff010000.i2s mapping ok [    3.057530] asoc-simple-card sound: snd-soc-dummy-dai <-> ff010000.i2s mapping ok [    3.063813] asoc-simple-card spdif-sound: dit-hifi <-> ff030000.spdif mapping ok [    3.070668] rk808-rtc rk808-rtc: setting system clock to 2016-01-21 08:50:14 UTC (1453366214) [    3.074832] of_cfs_init [    3.078356] of_cfs_init: OK [    3.094901] vcc_sd: disabling [    3.098681] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 415; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-71c5d165', rk_ko_ver is '5', built at '08:11:00', on 'May 22 2018'. [    3.107602] mali-utgard ff300000.gpu: mali_platform_device->num_resources = 9 [    3.111756] mali-utgard ff300000.gpu: resource[0].start = 0x0x00000000ff300000 [    3.115903] mali-utgard ff300000.gpu: resource[1].start = 0x0x00000000ff300000 [    3.120004] mali-utgard ff300000.gpu: resource[2].start = 0x0x0000000000000012 [    3.124069] mali-utgard ff300000.gpu: resource[3].start = 0x0x0000000000000013 [    3.128134] mali-utgard ff300000.gpu: resource[4].start = 0x0x0000000000000014 [    3.132209] mali-utgard ff300000.gpu: resource[5].start = 0x0x0000000000000015 [    3.136137] mali-utgard ff300000.gpu: resource[6].start = 0x0x0000000000000016 [    3.139903] mali-utgard ff300000.gpu: resource[7].start = 0x0x0000000000000017 [    3.143622] mali-utgard ff300000.gpu: resource[8].start = 0x0x0000000000000018 [    3.147291] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 617; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali. [    3.155245] mali-utgard ff300000.gpu: gpu_leakage=7 [    3.158946] mali-utgard ff300000.gpu: gpu_leakage-volt-sel=0 [    3.165224] Mali: Mali device driver loaded [    3.170389] ALSA device list: [    3.173933]   #0: HDMI [    3.177332]   #1: I2S [    3.180656]   #2: SPDIF [    3.184269] of_dma_request_slave_channel: dma-names property of node '/serial@ff130000' missing or empty [    3.188411] ttyS2 - failed to request DMA [    3.192618] dwmmc_rockchip ff520000.dwmmc: Successfully tuned phase to 264 [    3.192928] Freeing unused kernel memory: 1152K [    3.202624] mmc0: new HS200 MMC card at address 0001 Loading, please wait... [    3.210642] mmcblk0: mmc0:0001 NCard  57.6 GiB [    3.215214] mmcblk0boot0: mmc0:0001 NCard  partition 1 4.00 MiB [    3.220079] mmcblk0boot1: mmc0:0001 NCard  partition 2 4.00 MiB [    3.224781] mmcblk0rpmb: mmc0:0001 NCard  partition 3 4.00 MiB [    3.233086]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 [    3.245291] vendor storage:20160801 ret = 0 starting version 237 [    3.325219] devfreq ff300000.gpu: Couldn't update frequency transition information. [    3.613780] mmcblk0: error -84 sending status command, retrying [    4.049579] dwmmc_rockchip ff520000.dwmmc: Successfully tuned phase to 203 [    4.061292] mmcblk0: response CRC error sending SET_BLOCK_COUNT command, card status 0x900 Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... done. Warning: fsck not present, so skipping root file system [    4.285392] EXT4-fs (mmcblk0p7): recovery complete [    4.289793] EXT4-fs (mmcblk0p7): mounted filesystem with writeback data mode. Opts: (null) done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. [    4.570201] systemd[1]: System time before build time, advancing clock. [    4.631978] ip_tables: (C) 2000-2006 Netfilter Core Team [    4.648904] cgroup: cgroup2: unknown option "nsdelegate" [    4.670196] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [    4.682978] systemd[1]: Detected architecture arm64. Welcome to Ubuntu 18.04 LTS! [    4.696471] systemd[1]: Set hostname to <rock64>. [    4.868330] systemd-gpt-auto-generator[237]: Failed to dissect: Input/output error [    4.875020] systemd[231]: /lib/systemd/system-generators/systemd-gpt-auto-generator failed with exit status 1. [    4.912984] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [    4.922742] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [    5.080170] random: systemd: uninitialized urandom read (16 bytes read, 97 bits of entropy available) [    5.086053] systemd[1]: Started ntp-systemd-netif.path. [  OK  ] Started ntp-systemd-netif.path. [    5.093941] random: systemd: uninitialized urandom read (16 bytes read, 97 bits of entropy available) [    5.099540] systemd[1]: Reached target Remote File Systems. [  OK  ] Reached target Remote File Systems. [    5.106724] random: systemd: uninitialized urandom read (16 bytes read, 97 bits of entropy available) [    5.112517] systemd[1]: Reached target System Time Synchronized. [  OK  ] Reached target System Time Synchronized. [    5.119713] random: systemd: uninitialized urandom read (16 bytes read, 97 bits of entropy available) [    5.125972] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [  OK  ] Started Forward Password Requests to Wall Directory Watch. [    5.134746] random: systemd: uninitialized urandom read (16 bytes read, 97 bits of entropy available) [    5.141620] systemd[1]: Created slice User and Session Slice. [  OK  ] Created slice User and Session Slice. [    5.149862] random: systemd: uninitialized urandom read (16 bytes read, 97 bits of entropy available) [    5.156199] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [  OK  ] Started Dispatch Password Requests to Console Directory Watch. [    5.164720] random: systemd: uninitialized urandom read (16 bytes read, 97 bits of entropy available) [    5.171119] systemd[1]: Reached target Local Encrypted Volumes. [  OK  ] Reached target Local Encrypted Volumes. [    5.178766] random: systemd: uninitialized urandom read (16 bytes read, 97 bits of entropy available) [    5.185944] systemd[1]: Created slice System Slice. [  OK  ] Created slice System Slice. [    5.193839] random: systemd: uninitialized urandom read (16 bytes read, 97 bits of entropy available) [    5.200813] systemd[1]: Listening on udev Kernel Socket. [  OK  ] Listening on udev Kernel Socket. [    5.208721] random: systemd: uninitialized urandom read (16 bytes read, 97 bits of entropy available) [    5.215849] systemd[1]: Listening on Journal Socket (/dev/log). [  OK  ] Listening on Journal Socket (/dev/log). [    5.225215] systemd[1]: Listening on udev Control Socket. [  OK  ] Listening on udev Control Socket. [    5.234619] systemd[1]: Created slice system-serial\x2dgetty.slice. [  OK  ] Created slice system-serial\x2dgetty.slice. [    5.243119] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [  OK  ] Listening on /dev/initctl Compatibility Named Pipe. [    5.252259] systemd[1]: Listening on Journal Socket. [  OK  ] Listening on Journal Socket. [    5.264420] systemd[1]: Mounting Huge Pages File System...          Mounting Huge Pages File System... [    5.277281] systemd[1]: Mounting POSIX Message Queue File System...          Mounting POSIX Message Queue File System... [    5.290429] systemd[1]: Starting Remount Root and Kernel File Systems...          Starting Remount Root and Kernel File Systems... [    5.303188] systemd[1]: Starting Restore / save the current clock...          Starting Restore / save the current clock... [    5.318018] systemd[1]: Starting Create list of required static device nodes for the current kernel...          Starting Create list of required st…ce nodes for the current kernel... [    5.332672] systemd[1]: Starting Nameserver information manager...          Starting Nameserver information manager... [    5.348871] systemd[1]: Starting Set the console keyboard layout...          Starting Set the console keyboard layout... [    5.364990] systemd[1]: Starting Load Kernel Modules...          Starting Load Kernel Modules... [    5.374088] systemd[1]: Reached target Slices. [  OK  ] Reached target Slices. [    5.389178] systemd[1]: Mounting Kernel Debug File System...          Mounting Kernel Debug File System... [    5.399694] systemd[1]: Listening on Journal Audit Socket. [  OK  ] Listening on Journal Audit Socket. [    5.412075] systemd[1]: Starting udev Coldplug all Devices...          Starting udev Coldplug all Devices... [    5.420011] systemd[1]: Reached target Swap. [  OK  ] Reached target Swap. [    5.427797] systemd[1]: Listening on Syslog Socket. [  OK  ] Listening on Syslog Socket. [    5.440181] systemd[1]: Starting Journal Service...          Starting Journal Service... [    5.452243] systemd[1]: Mounted Huge Pages File System. [  OK  ] Mounted Huge Pages File System. [    5.461912] systemd[1]: Mounted POSIX Message Queue File System. [  OK  ] Mounted POSIX Message Queue File System. [    5.472956] systemd[1]: Started Remount Root and Kernel File Systems. [  OK  ] Started Remount Root and Kernel File Systems. [    5.482778] systemd[1]: Started Restore / save the current clock. [  OK  ] Started Restore / save the current clock. [    5.492829] systemd[1]: Started Create list of required static device nodes for the current kernel. [  OK  ] Started Create list of required sta…vice nodes for the current kernel. [    5.507047] systemd[1]: Started Load Kernel Modules. [  OK  ] Started Load Kernel Modules. [    5.516304] systemd[1]: Mounted Kernel Debug File System. [  OK  ] Mounted Kernel Debug File System. [    5.532594] systemd[1]: Started Nameserver information manager. [  OK  ] Started Nameserver information manager. [    5.551671] systemd[1]: Mounting Kernel Configuration File System...          Mounting Kernel Configuration File System... [    5.565416] systemd[1]: Mounting FUSE Control File System...          Mounting FUSE Control File System... [    5.579338] systemd[1]: Starting Apply Kernel Variables...          Starting Apply Kernel Variables... [    5.604473] systemd[1]: Starting Create Static Device Nodes in /dev...          Starting Create Static Device Nodes in /dev... [    5.632751] systemd[1]: Starting Load/Save Random Seed...          Starting Load/Save Random Seed... [    5.646665] systemd[1]: Mounted Kernel Configuration File System. [  OK  ] Mounted Kernel Configuration File System. [    5.655047] systemd[1]: Mounted FUSE Control File System. [  OK  ] Mounted FUSE Control File System. [  OK  ] Started Load/Save Random Seed. [  OK  ] Started Apply Kernel Variables. [  OK  ] Started Create Static Device Nodes in /dev.          Starting udev Kernel Device Manager... [  OK  ] Started Set the console keyboard layout. [  OK  ] Reached target Local File Systems (Pre).          Mounting /var/tmp...          Mounting /var/log...          Mounting /tmp... [  OK  ] Started Journal Service. [  OK  ] Mounted /var/tmp. [  OK  ] Mounted /var/log. [  OK  ] Mounted /tmp.          Starting Flush Journal to Persistent Storage... [  OK  ] Started udev Coldplug all Devices. [  OK  ] Started udev Kernel Device Manager. [  OK  ] Started Flush Journal to Persistent Storage. [  OK  ] Found device /dev/ttyS2. [  OK  ] Reached target Sound Card. [  OK  ] Found device /dev/disk/by-label/boot. [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.          Mounting /boot/efi... [  OK  ] Found device /sys/subsystem/net/devices/eth0. [  OK  ] Mounted /boot/efi. [  OK  ] Reached target Local File Systems.          Starting netfilter persistent configuration...          Starting Set console font and keymap...          Starting Create Volatile Files and Directories... [  OK  ] Started Set console font and keymap. [  OK  ] Started Create Volatile Files and Directories.          Starting Update UTMP about System Boot/Shutdown...          Starting Network Time Synchronization... [  OK  ] Started Entropy daemon using the HAVEGE algorithm. [  OK  ] Started Update UTMP about System Boot/Shutdown. [  OK  ] Started netfilter persistent configuration. [  OK  ] Reached target Network (Pre).          Starting Raise network interfaces... [  OK  ] Started ifup for eth0.          Starting Network Service... [  OK  ] Started Network Time Synchronization. [  OK  ] Reached target System Initialization. [  OK  ] Started Message of the Day. [  OK  ] Listening on D-Bus System Message Bus Socket. [  OK  ] Reached target Sockets. [  OK  ] Started resolvconf-pull-resolved.path. [  OK  ] Reached target Paths. [  OK  ] Started Discard unused blocks once a week. [  OK  ] Started Daily apt download activities. [  OK  ] Started Daily apt upgrade and clean activities. [  OK  ] Started Clean PHP session files every 30 mins. [  OK  ] Started Daily Cleanup of Temporary Directories. [  OK  ] Reached target Timers. [  OK  ] Reached target Basic System.          Starting Initializes zram swaping...          Starting Login Service... [  OK  ] Started ntp-systemd-netif.service.          Starting System Logging Service... [  OK  ] Started D-Bus System Message Bus. [  OK  ] Started Set the CPU Frequency Scaling governor. [  OK  ] Started Regular background program processing daemon.          Starting Generate SSH keys if not there...          Starting Resets System Activity Data Collector...          Starting Save/Restore Sound Card State...          Starting Rock 64 First boot... [  OK  ] Started Network Service. [  OK  ] Started System Logging Service. [  OK  ] Started Initializes zram swaping. [  OK  ] Started Generate SSH keys if not there. [  OK  ] Started Resets System Activity Data Collector. [  OK  ] Started Rock 64 First boot. [  OK  ] Started Save/Restore Sound Card State. [  OK  ] Started Login Service.          Starting Wait for Network to be Configured...          Starting Network Name Resolution... [  OK  ] Started Network Name Resolution. [  OK  ] Reached target Host and Network Name Lookups.          Starting resolvconf-pull-resolved.service... [  OK  ] Started resolvconf-pull-resolved.service.          Starting resolvconf-pull-resolved.service... [  OK  ] Started resolvconf-pull-resolved.service.          Starting resolvconf-pull-resolved.service...
I just got my new 4 GB Rock64 today, loaded up stretch-minimal-rock64-0.6.44-239-arm64.img which I had downloaded a couple days ago, and for every keypress I get on the console some line about rockchip-sip.  I looks like it's not interpreting the keypresses right either: I don't think I typed ooikcd.
I can probably mount the SD on a Pi and edit a file if I knew what to change.  I have a screen picture but no online host so I guess I can't post it here, at least yet.  The lines say something like:
[  203.143690] rockchip-sip: function[82000008: args:[2,0,2] => res:[ (goes out of view)
I had tried an Ubuntu something from Ayufan earlier and it worked better, but I don't really like Ubuntu.  I want Debian, minimal is fine as long as it takes standard arm64/aarch64 debs.  I'm running arm64 Debian Buster on a Pi right now.  I've used debootstrap a few times, should I start with that?
#19
(06-04-2018, 09:11 PM)ab1jx Wrote: [  203.143690] rockchip-sip: function[82000008: args:[2,0,2] => res:[ (goes out of view)
https://github.com/ayufan-rock64/linux-build/issues/196
#20
Thank you, I thought I'd seen something about a keyboard issue, couldn't find it again when it actually happened to me.
  Ayufan LXDE with Teamviewer or Dwservice? cenicero 0 3,701 03-14-2020, 06:39 AM
Last Post: cenicero
Information New Builds from ayufan (0.8.X) w Video/3D/Mate desktop Luke 37 85,744 09-09-2019, 04:01 AM
Last Post: ayufan
Star [archived] New Stable release from Ayufan (0.8.3) Luke 3 11,916 07-10-2019, 10:40 AM
Last Post: Malmgren
Star ayufan's 0.8.0rc12 (Rock64 Rev 3) Luke 1 5,455 06-13-2019, 02:05 AM
Last Post: pineadmin
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 3,850 03-26-2019, 07:28 PM
Last Post: Poincare
  ayufan 0.7.12 pre-release images (help testing) Luke 1 6,810 03-22-2019, 05:11 PM
Last Post: Luke
Star 0.7.8 Linux release from ayufan for Rock64 Luke 30 93,815 02-25-2019, 02:53 PM
Last Post: Luke
  testing latest ayufan u-boot (2017.09-rockchip-ayufan-1035-gd646df03ac) jandastroy 1 5,115 12-24-2018, 08:58 PM
  HDMI sound on ayufan 0.7.x Trash_Can_Man 0 3,666 10-26-2018, 12:57 PM
Last Post: Trash_Can_Man
Smile [Archived] ANNOUNCING RECALBOX FOR THE ROCK64 - ALPHA RELEASE Mrfixit2001 95 159,016 08-04-2018, 01:47 AM
Last Post: Luke
