Rock64 Power Supply Polarity
(12-18-2017, 10:57 AM)nmhart322 Wrote: The barrel jack on the board has 3 pins connecting it to the board. Is the third pin for structural integrity then?
Yes, it is, as i mentioned earlier.
Hi there, got my ROCK64 today, whithout power supply beacause I found one that may be suitable in my stuff...
I seem to have powerup issue with it (no led after pluging supply and pushing power button). My power supply is 5V (center positive) with max output 3.5A. Do you think th output is too high ?
thanks,
(05-26-2018, 07:15 AM)NablaMetal Wrote: Hi there, got my ROCK64 today, whithout power supply beacause I found one that may be suitable in my stuff...
thanks,
There is a green led that is connected to the power socket that will illuminate when plugged into power.
thanks,
The A(mperage) could be 100A and it wouldn't matter, it's the voltage (i.e. pressure) that can cause damage. As long as the voltage is 5v (+/- 5%) and correctly polarized (i.e. centre postiive as you indicated) it should be fine. If you plug in the power, and the green LED between the DC jack and IR sensor doesn't come on, you either have a faulty board, connector or power supply.
Yes that was what I was thinking but was'nt much sure. The power supply does power correctly the usb hub it was made for, but still I will buy another power supply to be sure...
Thanks,
Ok my power supply was just faulty. Everything works with my new supply.
Thanks for helping Smile
  Rock64 v2.0 u-boot SPI issues ju0n 0 885 07-05-2026, 11:02 AM
Last Post: ju0n
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 6,227 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 28,897 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 17,003 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 19,029 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,928 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 10,070 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 11,085 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,458 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,996 11-28-2022, 02:18 PM
Last Post: Macgyver
