[Archived] New Releases from ayufan! (0.6.XX)
Thumbs Up
Hello everyone, I am just relaying that 0.6.37 0.6.40 0.6.41 0.6.44 images from ayufan have been labeled 'release' and are hence the new stable go-to Linux OS image for the Rock64.
ayufan's git
Good news, Ayufan great man!!!
I hope he will continue to develop linux and now will address the problems with graphics.
I've got no network connection with 0.6.40. Someone had the same problem?
(05-21-2018, 03:22 PM)majomi Wrote: I've got no network connection with 0.6.40. Someone had the same problem?
Yep, same issue.
Probably why my 0.6.37 build still is reporting that it is the most current version when running a apt version update, unless there is normally a delay between new updates being posted on github and them being available for update through apt.
I've hit this issue as well. I raised a Github issue at https://github.com/ayufan-rock64/linux-build/issues/189. Would be helpful if anyone with a working setup could post tips and config.
0.6.40 at least booted for me... it was the first image since 0.6.27 that actually booted up instead of crashing and burning early on. However, I had no IPv4 networking and apparently had an IPv6 address which was non-responsive.
0.6.41 was pushed several hours ago, and reverts some tx/rx gmac changes that must have crept in re-syncing with the rockchip kernel, and I now have networking... so the fix if you've just installed 0.6.40 is to update to 0.6.41, or you can probably decompile the DTS, make the changes in this commit, and recompile it if you have already configured the system, but you won't get the DMA changes that are also in 0.6.41.
SD Boot - quick ping test at the end: https://pastebin.com/MgvwcW2m
eMMC boot - ping and iperf test at the end: https://pastebin.com/piGuwGmD
Based on what I've seen so far, I'm happy moving over to this image as the base image for the rock64 I use all the time. I just need to check something related to the memory, as I think one of the boards I have is being over or under-reported as to memory size... need to boot to an older image to see what is going on there. Just me, the board I had thought was 1GB was actually a 2GB board...
(05-22-2018, 05:08 PM)pfeerick Wrote: 0.6.40 at least booted for me... it was the first image since 0.6.27 that actually booted up instead of crashing and burning early on. However, I had no IPv4 networking and apparently had an IPv6 address which was non-responsive.
Quick ping test at the end: https://pastebin.com/MgvwcW2m
Took a bit of fiddling with putting the 0.6.41 files on a USB to get them across to my Rock64 (remember, no network) but now that I've manually upgraded I have network connectivity again. Thanks.
Is Lakka for R64 an abandoned project? Thanks.
(05-24-2018, 02:14 PM)Danielsan Wrote: Is Lakka for R64 an abandoned project? Thanks.
That you should ask Lakka devs ...
  Ayufan LXDE with Teamviewer or Dwservice? cenicero 0 3,506 03-14-2020, 06:39 AM
Last Post: cenicero
Information New Builds from ayufan (0.8.X) w Video/3D/Mate desktop Luke 37 81,303 09-09-2019, 04:01 AM
Last Post: ayufan
Star [archived] New Stable release from Ayufan (0.8.3) Luke 3 11,285 07-10-2019, 10:40 AM
Last Post: Malmgren
Star ayufan's 0.8.0rc12 (Rock64 Rev 3) Luke 1 5,171 06-13-2019, 02:05 AM
Last Post: pineadmin
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 3,667 03-26-2019, 07:28 PM
Last Post: Poincare
  ayufan 0.7.12 pre-release images (help testing) Luke 1 6,565 03-22-2019, 05:11 PM
Last Post: Luke
Star 0.7.8 Linux release from ayufan for Rock64 Luke 30 90,673 02-25-2019, 02:53 PM
Last Post: Luke
  testing latest ayufan u-boot (2017.09-rockchip-ayufan-1035-gd646df03ac) jandastroy 1 4,904 12-24-2018, 08:58 PM
  HDMI sound on ayufan 0.7.x Trash_Can_Man 0 3,500 10-26-2018, 12:57 PM
Last Post: Trash_Can_Man
Smile [Archived] ANNOUNCING RECALBOX FOR THE ROCK64 - ALPHA RELEASE Mrfixit2001 95 151,492 08-04-2018, 01:47 AM
Last Post: Luke
