LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs
hope its ok to post my problems here Big Grin
Problem 1:
I tried to install
-leia24
-some nightbuilds from test.libreelec.
They doint boot from eMMC (Red + White led lit forever and nothing happens) I only can boot them if i insert a SD-Card, Install a Jumper on eMMC "pins" and remove the jumper directly when i start.
Or if i install leia21 -> Boot -> go into a linux build -> mount the eMMC p1 and the img from the libreelec build i want and copy the Image / System files to the eMMC (replace them from the installed leia21 build)
Problem 2:
I got Inputstream.adaptive running (why is it not in all this builds ...?)
If i have hardware acceleration - PRIME active and Try to change the Source, i got a blackscreen my monitor says no signal. And i never get the image back (need to restart)
In the logs i get WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
If i deactivate hardware acceleration, it works without any problems (only 90-100% cpu load..)
If i now reactivate hardware acceleration, the video starts playing with the settings i set before. But when i close it / it ends. Same behaviour (blackscreen and only restart helps)
Is there a solution that i can add ?
Does the Rock64 LibreELEC image from here (http://test.libreelec.tv/) work for anyone?
I tried the one mentioned below, but after reboot it goes into kernel panic mode and a lot of HEX numbers are being displayed.
LibreELEC-RK3328.arm-9.0-nightly-20180603-330aad4-rock64.img.gz
I would wish to get back to @Raybuntu's provided images as they worked (I still have some old images downloaded), but the docker addon can't be installed.
Anyone knows how to bring the docker addon back?
(06-04-2018, 02:20 PM)zarusz Wrote: Does the Rock64 LibreELEC image from here (http://test.libreelec.tv/) work for anyone?
https://forum.libreelec.tv/thread/12151-...#post93393
That last Nightly was a bad one.
Thanks for pointing out the LE relevant topic, I was not able to find anything related. It is good that the LE Rock64 image is still being developed by Kwiboo.
Two days passed and there is no new nightly build. Do you know how often or when is the next nightly build going to arrive?
(06-05-2018, 01:28 PM)zarusz Wrote: Thanks for pointing out the LE relevant topic, I was not able to find anything related. It is good that the LE Rock64 image is still being developed by Kwiboo.
Just keep checking in the nightly link and track test results in LE forum. The nightlies come every one to 2 days and kwiboo has lots of commits . It's a bit of a mess with Leia at the moment.
The LibreELEC work in progress are not yet in the nightly build location (http://test.libreelec.tv/).
At this point they are made available by Kwiboo under a different location - more details in this LibreELEC post
(06-07-2018, 12:30 PM)zarusz Wrote: The LibreELEC work in progress are not yet in the nightly build location (http://test.libreelec.tv/).
Are you sure?
I see this 'LibreELEC-RK3328.arm-9.0-nightly-20180612-a0d6cb2-rock64.tar' in http://test.libreelec.tv
(06-12-2018, 07:13 PM)Wizardknight Wrote: Are you sure?
That was a Quick Test File Posted with Patches.
Use http://kwiboo.libreelec.tv/test/
(05-14-2018, 11:51 AM)gigagames Wrote: Hello,
Problem 1:
I tried to install
-leia24
Problem 2:
I have same problem as your problem 2 on nightly-20180517-2417476, but devel-20180606204626-0267cea is OK.
Hi!. I hava a Odroid C2 with rb-krypton19. Now I'm buying an ROCK64. I need the rb-krypton19 for ROCK64 IMG file. Github has delete all IMG files for all versions.
Have anyone a backup of krypton19 IMG?.
Thanks a lot.
  How to boot an older, working kernel bits 0 3,164 11-01-2024, 04:43 PM
Last Post: bits
  Libreelec nfs shares nberg@xs4all.nl 0 2,115 11-11-2022, 01:18 PM
Last Post: nberg@xs4all.nl
  Linux 5.15 Kernel - openSuse mark1250 0 3,086 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 14,813 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian kernel stuck at 4.4.167 Enig123 5 11,002 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 22,472 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 7,626 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 12,531 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 8,230 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 3,717 02-05-2020, 10:58 PM
Last Post: dkebler
