Pine H64 1Gb|2Gb "out of stock"
(05-11-2018, 05:49 AM)sineloco Wrote: Still out of stock Sad
Seems, no chance to buy one in the near future?
yes, we are currently work on manufacturing next PINE H64 model B batch. The model B is a smaller board that has exact dimension as ROCK64.
Wow, great news, thank you Smile I hope, mini PCI-e was preserved?
And any predictions on release and stock dates?
Only model A has mini-PCIe slot, model B board is too small to accommodate miniPCI slot.
Plan to back in stock on June.
I'm interesting exactly in model A (with mini-PCIe).
So, will "PINE H64 model A" be available in stock?
Probably there is another place where I can purchase it? Really need board with mini-PCIe.
Thank you.
(05-16-2018, 03:59 AM)sineloco Wrote: I'm interesting exactly in model A (with mini-PCIe).
Thank you.
Per developer comments, the PINE H64 miniPCIe needs special driver to work and cannot be mainline. Please advise why you needs board with miniPCIe?
For my part, i want to use the mini pci express with an pci extender, to use with a SAS card, if possible, or a network card with 4 ports.
I also have a pci card for two sata.
Ok. To sum up, revision B will be smaller, no mPCI (that is bad news as I wanted to connect here LTE modem) but other spec will be preserved? I am asking particularly about the CPU clock speed.
Anyway when I will be able to order some? Same goes for RockPro64 - also not possible to order .
And for those still interested in mPCI - will rev A be available as well?
(05-31-2018, 02:05 PM)Arkadiusz Wrote: Ok. To sum up, revision B will be smaller, no mPCI (that is bad news as I wanted to connect here LTE modem) but other spec will be preserved? I am asking particularly about the CPU clock speed.
pine64 only has a limited amount of capital available, so there can sometimes be delays between batches, and now that they are spreading out to more boards, they're probably being stretched thin atm. I don't think the wait will be too long though, especially if the demand is there, And whilst TL will have to confirm it, I doubt many of the other specs of the model B pneH64 will have changed. just the removal of the mPCIslot due to size constraints.
#19
Hi again, any update when revB will be available?
#20
Just receive the PINE H64 model B board, production will be arranged once once tested.
Attached is the model B photo.
  Pine H64 rajsachdev 10 27,344 06-09-2023, 10:50 AM
Last Post: as365n4
  Pine H64 Stock ky56 0 4,149 10-26-2022, 04:37 PM
Last Post: ky56
  Pine H64 antenna connector auxym 2 7,633 03-10-2022, 02:14 PM
Sad Pine A64 parts Miguelito71 0 4,509 01-18-2022, 02:24 PM
Last Post: Miguelito71
  PINE H64 Wiki page is up tllim 2 15,779 03-27-2019, 08:03 PM
Last Post: tuxd3v
  Pine H64 Model B OS images ameridroid 2 9,223 03-13-2019, 09:48 AM
Last Post: NicoD
  PINE H64 u-boot and kernel shinymetal 2 10,058 02-28-2018, 02:05 PM
Last Post: shinymetal
