Android and SD Card
i try to get Android running, with an SD card.
I Downloaded android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img.gz
When im trying to Flash it with Etcher, its telling me "It looks like this is not a bootable image. The image does not appear to contain a partition table, and might not be recognized or bootable by your device"
When i Flash it to my sd card and insert the card into the Rock, my Window keeps being black.
When im using the Pine64 Installer, and select "Community Android TV 7.1. (ROCK64 microSD) (should be the same as i dowonloaded..) same behaviour -> Window keeps being black.
So how the heck can i get Android running with an SD card ?
Thanks for helping and sry for bad english
(05-05-2018, 06:50 PM)gigagames Wrote: Hello,
Please try another mciroSD card if you have additional one. Make sure than your power supply is 5V 3A type.
In case anyone else goes down this route.
I got the same warning about boot partition when writing android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img.gz to an SD card but it booted fine (I used a 16b card, probably way larger than needed).
On the rock64 (v2) board with 1Gb I have it's a little sluggish. YouTube works fine. Google Play store was so sluggish got the option wait/stop it. But you can install some apps..
  Android Images (ROCK64) pineadmin 77 244,670 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,263 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,520 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,676 06-27-2021, 02:43 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,437 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,627 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,261 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,545 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,906 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 16,202 09-09-2020, 08:44 AM
Last Post: BowerR64
