gcc-multilib on ayufan's builds
Hi.
I'm trying to compile some 32 bit binaries on my Rock64, running ayufan's stretch-minimal 0.6.32. I'm stuck on the following:
Quote:Package gcc-multilib is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'gcc-multilib' has no installation candidate
Anyone knows what to do?
The reason I'm doing this is because openhab only works well on 32 bit Java on arm, so I have to run openhab and all it's dependencies in 32 bits. Java is up and running, what I need to do now is build telldus-core.
I've found threads with Raspberry users having the same problem, so I guess this is in some way arm related?
edit: Ok, looks like I'm completely stuck. Maybe it isn't possible compiling armhf binaries on arm64 anyway? Found this: https://stackoverflow.com/questions/4497...v8-machine
I am not familiar with the Tellbus/Tellstick binding myself - what is telldus-core that you are trying to compile?
As far as I can see from the sources, the binding does not require any native parts, it merely uses JNA (which should be readily available for all platforms).
Wrt how to compile armhf on a 64-bit OS, I do not have an answer either - the simplest way might be to simply do this job on an 32-bit OS and copy the result over :-).
Regards,
Kai
(05-03-2018, 11:46 PM)kai Wrote: Hi,
Regards,
Kai
Oh, what a nice surprise seeing you here, kai Tongue
Telldus-core are some libraries and executables from Telldus that the binding needs installed and running on the server to work, and it needs to be in the correct bitness. See this thread for more info on that subject. I actually tried compiling them on my old 32-bit server and copying the executables over, but they turned out not to be working anyway since the old server is Debian 8 and the new one is Debian 9 so the executables are linked to wrong version of stuff like libconfuse.
The best thing from my perspective would be to run everything in 64 bits, but I read through this thread and came to the conclusion that it doesn't, though I don't understand the details. Tried to revive the thread, you're welcome to comment on that Wink
I am everywhere :-D
Ok, thanks for the background infos. Will try to follow up on the openHAB forum then.
  Ayufan LXDE with Teamviewer or Dwservice? cenicero 0 3,444 03-14-2020, 06:39 AM
Last Post: cenicero
Information New Builds from ayufan (0.8.X) w Video/3D/Mate desktop Luke 37 80,114 09-09-2019, 04:01 AM
Last Post: ayufan
Star [archived] New Stable release from Ayufan (0.8.3) Luke 3 11,082 07-10-2019, 10:40 AM
Last Post: Malmgren
Star ayufan's 0.8.0rc12 (Rock64 Rev 3) Luke 1 5,090 06-13-2019, 02:05 AM
Last Post: pineadmin
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 3,630 03-26-2019, 07:28 PM
Last Post: Poincare
  ayufan 0.7.12 pre-release images (help testing) Luke 1 6,510 03-22-2019, 05:11 PM
Last Post: Luke
Star 0.7.8 Linux release from ayufan for Rock64 Luke 30 89,291 02-25-2019, 02:53 PM
Last Post: Luke
  testing latest ayufan u-boot (2017.09-rockchip-ayufan-1035-gd646df03ac) jandastroy 1 4,844 12-24-2018, 08:58 PM
  GPU not working with Ubuntu and Debian builds kdawgpoker 10 21,774 12-19-2018, 03:53 PM
Last Post: va88
  HDMI sound on ayufan 0.7.x Trash_Can_Man 0 3,452 10-26-2018, 12:57 PM
Last Post: Trash_Can_Man
