Some questions about r64 and ayufan android tv
I ordered a r64 2gb today with 16gb Emmc and wifi antenna. Can't wait to get my hands on it.
I'm planning to run android tv on it, does it support hdmi-cec, so I can use the remote from my TV?
And will the wifi antenna and Bluetooth stick work right out of the box or did I need to configure them?
And there are 3 images of android tv from ayufan(raw, update and the normal one). Which one do I need to flash it on Emmc (I ordered Emmc to USB connector for easy flashing )
Thanks in advantage Smile
CEC works on some TVs - on my Samsung and Sharp it works just fine.
Wifi will work out of the box, not so sure about BT.
The three OS options on ayufan's git relate to different means of flashing the image:
* RAW image for booting from SD card (using DD or GUI installer such as etcher)
* Update image (to be used on windows /compatible with the update utility from Rockchip)
* Folder with partitions used with nix as per instructions here: https://github.com/ayufan-rock64/android.../README.md
  Are you guys still using Ayufan's OMV on your Rock64? AkiraSensei 0 2,955 11-26-2021, 07:01 PM
Last Post: AkiraSensei
  DAC Questions codebreaker 1 4,594 09-19-2020, 02:14 PM
  Download IDB fail when trying to flash Android image cherkasoff 0 9,025 04-05-2020, 07:41 AM
Last Post: cherkasoff
  Ayufan apt repository? ab1jx 2 6,285 11-23-2019, 10:08 PM
Last Post: ab1jx
Lightbulb NAS + ​Pine64 ROCK64 = Few Important Questions FilipWozniak 8 22,938 04-14-2019, 09:21 AM
Last Post: default_user8
  How to compile ayufan repo step by step? hisstone 0 3,262 03-12-2019, 03:09 AM
Last Post: hisstone
  Pre-purchase Questions InSearchOfNAS 4 9,247 11-11-2018, 06:50 PM
Last Post: InSearchOfNAS
Wink SDR104 on ayufan 0.7.7+ XFer 0 2,923 10-25-2018, 06:30 AM
Last Post: XFer
  How to get UHD 4k working (with Android TV 7) Hotkey 7 14,728 09-18-2018, 09:39 AM
Last Post: Trash_Can_Man
  Reboot Issue with ROCK64 Linux version 4.4.77-rockchip-ayufan-141 techyjtmb 9 18,040 06-23-2018, 09:52 AM
Last Post: NablaMetal
