Compatible WiFi modules for Rock64
I've a ROCK64 4 GB, but didn't order the WiFi adapter from Pine64 website assuming that I'll use my existing WiFi adapter.
I'm using this build android-7.1-rock-64-rock64_atv-v0.3.4-r86-update.zip
I tried using the following, but none of them worked:
  1. Edimax EW-7811UN
  2. Edimax EW-7811UTC
  3. Belkins N150
  4. Netgear A6200
I regret not buying one of the available two WiFi adapters from Pine64. If I have to order now, it will cost another 8 bucks for shipping and about a month for delivery.
Do I need to install some driver to get these working? Or is there a compatible WiFi adapter sold by a US seller?
Please give pid:vid of each of these devices. Please also do `dmesg` from Android when you plug-in the adapter.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
(09-27-2017, 02:27 AM)ayufan Wrote: Please give pid:vid of each of these devices. Please also do `dmesg` from Android when you plug-in the adapter.
Thanks for your response.
  1. Edimax EW-7811UN    VID:7392 PID:7811
  2. Edimax EW-7811UTC  VID:7392 PID:A812
  3. Belkins N150              VID:050D PID:945A
  4. Netgear A6200           VID:0846 PID:9050
I also would like the EW-7811UN to work..
(Im using the Ayufan ATV version)
How do you do dmesg in android? I am having an issue with the wifi adapter that I purchased from the store.
Also struggling with this, support is useless.
I also did not order the USB WiFi when I bought Rock64.
I have 6 USB WiFi and all of them work fine in RaspberryPi.
I thought I could use one of them. But I was wrong Sad.
Since shipping cost to Europe is more than the price of USB WiFi itself, I researched Rock64 compatible chips and came up with two names.
1)  rtl8188eus (caution: similaly named 8188cus does not work)
This is 2.4 GHz only. Works OoB in Linux installation on Rock64, but not in Android installation.
2) rtl8812au
This is 2.4/5 GHz dual band.
2.4 GHz works OoB in Linux as well as Android installation.
You can make 5 GHz connection work in Linux by compiling driver from the source code (see the other thread in the forum regarding rtl8812au).
https://forum.pine64.org/showthread.php?tid=5768
So far, I could not find any way to make 5 GHz work in Android.
I am not so sure if there is 5 GHz support in the current commmunity built version of Android.
As far as I know, there still is no bluetooth support in Android.
Here's the answer to the OP's question.
The identity of the chipsets in your USB WiFi is as follows:
1) Edimax EW-7811UN <-- RTL8188CUS
https://wikidevi.com/wiki/Edimax_EW-7811Un
2) Edimax EW-7811UTC <-- RTL8811AU (can use 8812au driver in Linux)
https://wikidevi.com/wiki/Edimax_EW-7811UTC
3) Belkins N150 (Typo for Belkin N150?) <-- RTL8188SU
https://wikidevi.com/wiki/Belkin_F9L1001
4) Netgear A6200 <-- BCM43526
https://wikidevi.com/wiki/Netgear_A6200
Edimax EW-7811UTC seems to be a good candidate for Rock64.
At least 2.4GHz channel part should work in Linux and Android installation on Rock64.
I've been using a RTL8188EU wireless adapter from Pine64 which gave out in 3 months so I found a replacement adapter which works.
I've browsed the web for a wifi adapter which uses the Realtek RTL8188EU (S) chipset and I decided on ordering the Comfast CDF-WU810N. (this is the only link I found that had them in stock at the time)
It works out of the box on my Rock64 4GB running Armbian Xenial, the only disadvantage is that this adapter does not have an external antenna as the Pine64 one did so the wifi signal will suffer, but maybe it will have a longer life span...
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 4,965 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 23,840 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 14,574 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 15,626 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 3,880 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 8,372 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 9,564 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 8,708 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,182 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 4,265 10-07-2022, 07:50 PM
Last Post: rookie_267
