Query regarding MIPI CSI camera support
Can someone confirm whether this board supports dual camera via MIPI CSI? If yes, are can these use any MIPI CSI based camera? Because the A64 camera module does not have a holes to screw it to my 3D printed case. So, I was thinking of ordering Raspberry Pi camera module v2.1 which have holes for screws on PCB.
Current prototype RockPro64 have dual MIPI-CSI and one parallel CSI port, and I don't think there are any changes planned regarding production boards. The connectors are not directly compatible to the RPi FFC cable since the MIPI-CSI on the RK3399 supports 4 lanes instead of the 2 on the RPi interface, so it is a 30 pin wide FFC connector, I can see if I can post the pinout that is currently used...
(02-28-2018, 11:03 AM)xalius Wrote: Current prototype RockPro64 have dual MIPI-CSI and one parallel CSI port, and I don't think there are any changes planned regarding production boards. The connectors are not directly compatible to the RPi FFC cable since the MIPI-CSI on the RK3399 supports 4 lanes instead of the 2 on the RPi interface, so it is a 30 pin wide FFC connector, I can see if I can post the pinout that is currently used...
Thanks for replying. Given that RockPro64 and later iteration RockPro64AI are positioned towards AI and computer vision enthusiast, it would be great, if you could include supported reasonably priced "stereo camera" /"single camera" in your accessory store. You can share the pin layout here, but it would be wonderful if you can find and share links of some supported camera available online (maybe on aliexpress)
the 13MPixel stereo camera module currently in design stage and targets to release on April 2018.
(03-01-2018, 12:53 AM)tllim Wrote: the 13MPixel stereo camera module currently in design stage and targets to release on April 2018.
13MPixel is an overkill for image processing application. A stereo camera with dual 5 MPixel with each having 75 degree horizontal field of view will do just fine and also bring down the cost.
Does the MIPI CSI on this board (RockPro64) compatible with Banana PI camera or something like this https://www.aliexpress.com/item/Camera-m...autifyAB=0
Supported Himax 5 Megapixel Camera Module? Undecided
(04-27-2018, 05:31 AM)themyshop Wrote: Supported Himax 5 Megapixel Camera Module? Undecided
The Rockpro64 board has the parallel CSI port that can accommodate PINE A64's camera module. However, the current RK's Android camera library didn't support this model and hopefully can be support soon by community.
Any news when stereo module will be released?
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 212,155 09-25-2023, 12:46 AM
Last Post: ChriChri
  Support says "regulator" on the SBC burned out; how to fix? dmos 0 3,762 06-02-2022, 02:20 AM
Last Post: dmos
  Camera sensor support on MIPI lines abhimanyu_gr 0 3,049 01-22-2021, 09:23 AM
Last Post: abhimanyu_gr
  RockPro 64 MIPI Pinout carbotaniuman 3 8,389 05-21-2020, 03:41 AM
Last Post: dukla2000
  USB Type-C Display cable support (for 2 in 1: Video + Power) Paprika88 0 3,790 02-12-2020, 06:47 AM
Last Post: Paprika88
  rockpro64 support in the rockchip uboot dedoz 0 3,316 01-13-2020, 01:51 PM
Last Post: dedoz
  Vulkan support with rockpro64 rahulsharma 2 7,508 08-21-2019, 10:34 PM
Last Post: rahulsharma
  SPI support in GPIO mr_rabbit 2 6,774 07-21-2019, 11:42 PM
Last Post: Wom the Bat
  Calculate clock frequency for MIPI DPHY using different ref_clock value skumar 1 5,504 06-07-2019, 03:01 PM
Last Post: Nikolay_Po
  Non burst mode in MIPI DSI skumar 0 3,338 06-06-2019, 12:54 AM
Last Post: skumar
