Reboot Issue with ROCK64 Linux version 4.4.77-rockchip-ayufan-141
I have a ROCK64 4GB setup and when I reboot I have a lot of trouble getting the unit stable.
Here are the errors that display on the screen:
core: dev_pm_opp_get_voltage: Invalid parameters
mali-utgard ff300000.gpu: Failed to get voltage for frequency 163840000: -34
devfreq ff300000.gpu: Couldn't update frequency transition information.
And then it goes into kernel panic mode.  I have to completely power down the unit,
remove the hdmi, ethernet, and keyboard cable, wait for 30 seconds and then it will boot.
I have tried a different power supply and plugging it in to a different power source.
I have 3 other similar ROCK64's working fine.
same here
(02-13-2018, 02:40 AM)djniio Wrote: same here
True. My restarting issue came up when I swapped over to an SSD through the USB. I have to physically power it on to get it to power up. Although I found my Rock64 very stable as long as I don't reboot it. I'm going on 23 days as a ProdWeb server.
Trust me when I say, it would be nice for the occasional reboot, but it's 10 miles down the road churning along.
─➤  uptime
 09:49:19 up 22 days, 20:22
─➤  uptime
Are you running 0.6.1-141?
If so downgrade to the 0.5.15-136 stable build, although 0.6.15-175 seems to be fine, which I've been running for a while now.
I'm using: 4.4.77-rockchip-ayufan-136
(02-22-2018, 10:04 PM)Rustproof Wrote: I'm using: 4.4.77-rockchip-ayufan-136
The version in the thread title was confusing.
You would need to plug a serial device in to debug things further.
Thanks! That's the plan on my next build. I want to run it without restarting as long as I can.
─➤ uptime
12:12:33 up 23 days, 22:46
Hi all,
I'm getting basically te same error. My rock64 freezes roughly about every nights. My syslog isn't much weird, but my kernlog displays those tree lines before crash :
Jun 18 20:04:32 rock64 kernel: [ 1724.410661] core: dev_pm_opp_get_voltage: Invalid parameters Jun 18 20:04:32 rock64 kernel: [ 1724.411610] mali-utgard ff300000.gpu: Failed to get voltage for frequency 163840000: -34 Jun 18 20:04:32 rock64 kernel: [ 1724.412124] devfreq ff300000.gpu: Couldn't update frequency transition information.
I am on 4.4.77-rockchip-ayufan-136. I have an USB3 hard drive connected (I have read threads where USB3 maybe part of the problem). I'm a bit stuck here, what can I do to investigate further ?
(06-23-2018, 03:54 AM)NablaMetal Wrote: Hi all,
136 is a very old build now, and it's very likely that your issue has been fixed in an updated build since then. As of right now, the latest release build is 239 or if you want to be on the bleeding edge there is 270, but the changes between the two only really pertain to the RockPro64 board.
For anyone reading this in the future -- what I am saying right now is almost definitely out of date! Check the Releases
page!
Hi fire219,
Yep I figured this out too. Because I used Pine64 Windows software installer for flashing my sdcard, I thought it would grab the latest kernel release (I flashed it a month ago).
I saw that 239 was latest stable on Github and installed it. After reboot, no problem so far. I guess i'll wait and see... I will come back here to report in any case.
Thank you
  Rock64 v2.0 u-boot SPI issues ju0n 1 1,549 09-25-2026, 11:19 PM
Last Post: mysy
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 6,391 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 29,505 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 17,278 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 19,508 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 5,036 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 10,260 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 11,289 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,679 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 5,089 11-28-2022, 02:18 PM
Last Post: Macgyver
