New EMMC module not working
I recently ordered 3 EMMC modules from the Pine64 store. Two of the modules work fine, but the third does not work. It is not not recognized by my computer. I am using the official Pine64 EMMC adapter.
How do I go about getting the defective EMMC card replaced?
Thanks!
Sent from my iPad using Tapatalk
(02-02-2018, 08:49 PM)jsfrederick Wrote: I recently ordered 3 EMMC modules from the Pine64 store.  Two of the modules work fine, but the third does not work.  It is not not recognized by my computer.  I am using the official Pine64 EMMC adapter.
Thanks!
I'm also experiencing this issue and am wondering the same about replacing a bad emmc.
I had ordered two pine64 emmc to usb adapters, and two 64gb emmc cards, one flashed fine using etcher, but the other does not. I've tried both adapters with no success. Seems to fail between 5-22% flashing progress, speed decreases until 0 bytes/sec written and then just disconnects the drive. Also tried win32 disk imager with no success.
FWIW - I went through the motions to "clean" the disk with diskpart, and then proceeded to do a Low-Level Format (not quick format) upon which I'm able to see free space on the card again, but the issue with flashing persists.
Thanks!
My issue actually seems like it isn't necessarily a bad emmc card, but both usb adapters I ordered from the Pine64 store had seemingly gone bad. I must have gotten lucky in flashing my first emmc. It's quite possible that yours also went bad, jsfrederick. The quality control on them doesn't seem to be too good if two of mine failed, and I've been reading across this forum that it isn't the first time it's happened to anyone.
I ordered this combination which worked without any issue on my first re-attempt with the card I thought was bad:
https://www.amazon.com/gp/product/B009D79VH4/
https://www.amazon.com/gp/product/B01LHJ2O38/
Just a hint if you do order the above, the emmc card snaps in sticking out/facing away from the emmc adapter module it plugs into.
If you believe to received bad eMMC module or USB adapter for eMMC module, please file a support ticket at http://support.pine64.org
Thank you TL. I will do that.
Heart Wow! So happy to see this site working again! KC9UDX 1 2,607 01-31-2024, 12:39 AM
Last Post: gamelaster
  LTE module for pine64 products stoiqman 1 3,092 10-18-2022, 12:45 PM
Last Post: poVoq
  on pinepower, pinecil stopped working.. sanderboer 1 3,541 09-23-2022, 03:47 AM
  HDMI audio not working with LAKKA applewoz 0 2,088 08-27-2022, 06:00 PM
Last Post: applewoz
  eMMC connector durability. Randomuser 0 1,841 08-20-2022, 05:51 AM
Last Post: Randomuser
  Pine64 Working on RISC-V Hardware! ImmyChan 0 2,497 07-04-2022, 02:32 PM
Last Post: ImmyChan
  PW reset not working motezart 6 9,552 05-24-2021, 05:11 PM
Last Post: pfeerick
  PADI info thread not working? lunacyworks 1 3,921 02-02-2021, 01:07 PM
Question Micro computer module Computer semi-expert 7 14,115 09-29-2020, 04:52 PM
  pine64 usb2 emmc reader with odroid module nivex 1 5,508 03-30-2020, 04:27 PM
Last Post: nivex
