eMMC connector durability.
Using my SOQuartz board with a eMMC module for last few weeks has been great performace-wise. However, every time I have to detach the module, flash new OS and reattach I wonder how long is that tiny plastic connector is going to last. I do kernel and driver development so when I use it I re-flash the OS few times per day.
So my question is. How many connect/disconnect cycles are these flat eMMC connectors usually rated for? Had people have them break already in normal use? Should I be doing something special to extend its lifetime (lubricating with plastic spray lubricant) etc?
Also, when they break, is it fairly easy to buy them? I can solder such components no problem, but buying them is another story.
  Will the Pinecil work for repairing iPods, in particular the 30pin port connector? drewdavis 0 1,941 08-27-2024, 08:01 PM
Last Post: drewdavis
  pine64 usb2 emmc reader with odroid module nivex 1 5,692 03-30-2020, 04:27 PM
Last Post: nivex
  eMMC question __alec 1 4,819 03-14-2020, 10:03 AM
Last Post: __alec
  eMMC malware burp 6 11,748 06-13-2019, 07:24 PM
  New EMMC module not working jsfrederick 4 10,469 02-09-2018, 09:57 PM
Last Post: jsfrederick
  eMMC with Pine64 512K burningkrome 4 10,300 01-05-2018, 11:19 AM
