Can't boot Android TV
I've been unsuccessful booting the Android TV Images.  I've tried using the pine64 installer as well as using win32 disk imager.  In each case, I see the Pine64 logo, then the android logo, but it doesn't seem to do anything. past that.
The first boot will take 10-15 minutes depending how fast your card is...
(01-13-2018, 04:54 PM)xalius Wrote: The first boot will take 10-15 minutes depending how fast your card is...
I've waited over a half hour with no result.  I'm using a 3A charger, and the card works for Raspberry Pi when I image it, so I don't think the card is damaged.
Which version of ATV is it exactly? Also,. make sure you don't have a peripheral connected to OTG ...
I've been trying android-7.1-rock-64-rock64_atv-v0.3.4-r86-raw.img
please try android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img.gz - I have it running right now so I know it works.
(01-18-2018, 12:58 AM)Luke Wrote: please try android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img.gz - I have it running right now so I know it works.
I've also had fairly good luck with the above build. Though noticed a couple issues.
YouTube 4k30 videos didn't work (fixed in my work branch)
YouTube TV doesn't load any content (haven't started digging into this one yet)
Widevine is reporting hdcp isn't active. Could be related to the above issue (also haven't dug into this one)
HDMI cec isn't fully implemented
Correct on all accounts. Work branch ? - link to git ? Smile
https://github.com/eousphoros/device-rockchip-rk3328
https://github.com/eousphoros/android-kernel
https://github.com/eousphoros/android-7.1
Haven't made it into a clean easy to build thing yet but if you apply the newest commits should get a build out thats close to what I'm running. Thank you to ayufan and everyone else involved for their amazing work.
Quote:Haven't made it into a clean easy to build thing yet
If or when you do, please share.
  Android Images (ROCK64) pineadmin 77 247,061 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,534 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,810 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,985 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,953 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,657 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,813 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,494 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,738 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 9,102 09-18-2020, 07:58 PM
Last Post: BowerR64
