LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs
Some emulators do not work yet on arm properly with Kodi's RetroPlayer for instance N64.
Raybuntu: I am encountering a strange issue (not present in leia21). When I stop playback of a file my monitor turns off. I can still SSH into the board but there's no HDMI output.
Video
Log
I just flashed the latest version using Etcher to the eMMC and it doesnt seem to work. It flashed fine but when I start the ROCK64 up no image/os seem to load. Am I doing something wrong?
EDIT: My bad lol, downloaded the wrong image.
@Luke I will have a look although the hw video Decoding is still work in progress.
As for emmc issues. I do not have any emmc so I can not test it therefore I can't support it.
(01-12-2018, 03:43 PM)Luke Wrote: Raybuntu: I am encountering a strange issue (not present in leia21). When I stop playback of a file my monitor turns off. I can still SSH into the board but there's no HDMI output.
Video
Log
I have the same issue using the LibreELEC-ROCK64.arm-rb-leia22 image.
Happened just now on the Twitch addon. Watched a stream, stopped playback with 'X' and my tv says no input.
Is ist possible power on the Rock64 via cec? I tried on different TVs, but power on doesn't seem to work.
Controls and power down work fine. In comparison the Odroid C2 wakes up perfectly (rock64 and C2 are both running rb-leia22 with identical cec settings).
(01-13-2018, 10:51 AM)Dalek Wrote: Is ist possible power on the Rock64 via cec? I tried on different TVs, but power on doesn't seem to work.
No Amlogic devices have a AO (always on) mode. There is no such thing on Rockchip.
 I spoke to early, the problem persist and it doesn't only happen when I play videos or music from the external HDD but also when streaming. So I still need help. I've added the newest crashlogs below.
Crashlog 1: https://pastebin.com/G32E2pGA
Crashlog 2: https://pastebin.com/5fanSJXC
(01-16-2018, 05:57 AM)tattermunge Wrote:  I spoke to early, the problem persist and it doesn't only happen when I play videos or music from the external HDD but also when streaming. So I still need help. I've added the newest crashlogs below.
Which build ?  I had some crashes and random reboots with some of the older builds. So far, leia_21 has been by far the best performing and most stable for me.
I'm using 21 too. I figure that it is a hardware problem rather than software but until someone helps me narrow it down I can't say that for sure.
  How to boot an older, working kernel bits 0 3,119 11-01-2024, 04:43 PM
Last Post: bits
  Libreelec nfs shares nberg@xs4all.nl 0 2,100 11-11-2022, 01:18 PM
Last Post: nberg@xs4all.nl
  Linux 5.15 Kernel - openSuse mark1250 0 3,069 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 14,731 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian kernel stuck at 4.4.167 Enig123 5 10,947 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 22,357 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 7,587 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 12,440 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 8,197 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 3,691 02-05-2020, 10:58 PM
Last Post: dkebler
