LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs
(01-09-2018, 04:46 PM)tattermunge Wrote:
(01-09-2018, 01:53 PM)Luke Wrote: tattermunge, I moved your log to pastebin. Please use pastebin in the future to link logs - the reason you're post got cut off was due to post word limit.
Thanks, is that the one called PHP? Because I don't see any tool called pastebin.
take a look: https://pastebin.com/
(01-05-2018, 04:00 PM)Luke Wrote: A piece of good news, your build boots from SPI from an external HDD just fine Smile - super cool.
Btw., are we anywhere near some end-user friendly boot selection mechanism as provided by GRUB or RPi's NOOBS ?
A bit off-topic but Ill answer; define "anywhere near". It is now possible - the first step, if I understand correctly, is to get HDMI working so that a software for OS selection can be displayed. You'd have to ask ayufan how long he assumes it may take to get to that point. My guess is a few months.
https://github.com/Raybuntu/LibreELEC.tv.../rb-leia22
New experimental support for RockBox.
awesome!
Sorry for the stupid question. I'm using rb-leia22 on Rock64. I install game add-ons (Emulator/PCSX ReARMed) from rb-addons. But after the installation, I do not see any add-ons in the games, and when ROMs start (.bin files on usb HDD), it starts up in a standard video player. Tell me please where I'm wrong, how can I run the PSX Emulator on rb-leia22?
(01-12-2018, 08:54 AM)sham_sr Wrote: Sorry for the stupid question. I'm using rb-leia22 on Rock64. I install game add-ons (Emulator/PCSX ReARMed) from rb-addons. But after the installation, I do not see any add-ons in the games, and when ROMs start (.bin files on usb HDD), it starts up in a standard video player. Tell me please where I'm wrong, how can I run the PSX Emulator on rb-leia22?
Enter the konami code at the main menu. A gamepad icon will appear in the side-bar menu.
Yes, I entered the konami code. The game menu has appeared. But when I open the menu I see the items add-ons and my usb HDD, If you open the list of add-ons is empty there are no Emulator add-ons installed. If I find the ROMs on my HDD and are trying to start they are okay in the standard video player
When you click the rom it will give you an option to load it with one of the installed emulators. You asked about the PSX specifically - that I haven't tested. You sure its in a compatible format with the emulator in question (some do .zip others need to launch the .cue, yet others want and .iso). ?
Thanks for the reply. I tried .bin ROMs I've used in LAKKA, but in the presented add-ons they don't really work, tried other NES, SENS ROMs they run correctly. Is it possible in the future support to rb-leia GameStarte add-ons?
  How to boot an older, working kernel bits 0 3,165 11-01-2024, 04:43 PM
Last Post: bits
  Libreelec nfs shares nberg@xs4all.nl 0 2,118 11-11-2022, 01:18 PM
Last Post: nberg@xs4all.nl
  Linux 5.15 Kernel - openSuse mark1250 0 3,087 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 14,817 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian kernel stuck at 4.4.167 Enig123 5 11,008 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 22,494 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 7,627 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 12,534 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 8,241 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 3,717 02-05-2020, 10:58 PM
Last Post: dkebler
