ROCK64 emmc
Star
I recently purchased and am awaiting both a Pine64-LTS and a ROCK64, both with emmc modules. After purchasing, I realized that I had not purchased the emmc to usb adapter. This is my fault, but I have been looking into my options in the meantime.
Here is the information that I have gathered, though I may have gotten some things wrong(that is the first part of my question, and leads directly to the second.)
1. On the LTS, there are images I can write to SD, and then install to emmc.
2. These installers are not available on the ROCK(if they are, my question basically ends here, as I can install to emmc without needing to wait for the adapter.)
The second part of my question, which assumes #2 above is true, is whether I can put the emmc into the LTS, write a ROCK image, and just put the emmc into the ROCK?
(12-29-2017, 11:49 AM)Diogenes08 Wrote: I recently purchased and am awaiting both a Pine64-LTS and a ROCK64, both with emmc modules. After purchasing, I realized that I had not purchased the emmc to usb adapter. This is my fault, but I have been looking into my options in the meantime.
Since you've got both the R64 and the Pine64 LTS it will be easy. Boot the LTS from SD with the eMMC module mounted. On the LTS download a Rock64 image and flash it to the eMMC. Then place the eMMC into the R64 and it will work.
Flashing images to eMMC on A64 is much easier, its only the R64 that is a bit tricky.
That was pretty much the second part of my question, from what I gathered this was an easy work around, I just didn't want to assume it would work.
May I ask, is there a specific reason it cannot be done the same on the ROCK?
  eMMC empty? bluedemon382 0 2,595 07-19-2023, 06:29 AM
Last Post: bluedemon382
  USB adapter to eMMC module not recognized danril 0 3,308 11-25-2022, 04:16 AM
Last Post: danril
  MRAA Rock64 support jbize 2 5,665 07-09-2022, 04:40 AM
Last Post: igorp
  How to flash Focal Gnome to EMMC cyphr3x 0 3,828 06-05-2020, 02:06 PM
Last Post: cyphr3x
  How to boot from the SD card and install to eMMC? ravanh 2 10,488 03-18-2020, 09:42 AM
  Rock64 with Debian netinst usb Bloris 6 15,123 12-03-2019, 12:37 PM
Last Post: madalin
  The differences between Rock64 and RockPro64 phamoanh 1 7,560 06-12-2019, 10:44 PM
Last Post: evilbunny
  How to check eMMC? ame 5 13,123 01-08-2019, 04:31 PM
Last Post: ame
  Custom Kernel for ROCK64 mayst 2 8,058 01-07-2019, 08:04 AM
Last Post: mayst
Bug Rock64 Login lpninja 1 7,339 10-04-2018, 12:02 AM
