LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs
#81
Can you say anything about the stability ? i got Leia16 working on emmc and since it was not easy to get that done i'm afraid to test any new versions ^^
(12-15-2017, 06:47 AM)Lamensis Wrote: Can you say anything about the stability ? i got Leia16 working on emmc and since it was not easy to get that done i'm afraid to test any new versions ^^
If you copy the .tar file in update folder It should update without problem.
And how do i get back if it is not stable?^^ thats more the issue i got
Make a backup. Update with the tar. If it's not stable for you restore the backup.
(12-15-2017, 06:01 AM)Raybuntu Wrote: https://github.com/Raybuntu/LibreELEC.tv.../rb-leia20
New build. Please remember to update your addons. Kodi API changed so some addons may bet disabled by default on first boot. You need to install updates from my repo and re-enable
 those disabled binary addons (inputstream.adaptive).
RetroPlayer works very well now on ROCK64. To enable games menu to you need to input a Konami code at Home Screen:
Up Up Down Down left right left right b a
Video Playback was improved too.
Awesome and thanks Smile
https://github.com/Raybuntu/LibreELEC.tv.../rb-leia21
New build:
-Caretaker Addon preinstalled. It detects malicious repo's or piracy addons and warns the user about it.
 It can be disabled.
-DVB Driver Addons from @CvH.
 You can choose between CrazyCat and Hauppauge (most recent media tree) drivers on Rock64.
  http://cvh.libreelec.tv/LibreELEC/9.0_Le...addons.mp4
I wish everyone happy holidays and a happy new year.
(12-22-2017, 08:15 AM)Raybuntu Wrote: https://github.com/Raybuntu/LibreELEC.tv.../rb-leia21
New build:
 It can be disabled.
Thanks on the new build, wish you have a wonderful holiday season and happy new year.
tried 21 but i get a error
the tried 20 and it worked for few minutes then the device restart and on screen is always the massage waiting for network.
(12-28-2017, 01:23 PM)kmxak Wrote: tried 21 but i get a error
I'm gonna need a little bit more information.
Raybuntu, did you have a chance to look at the RockBox?
edit: not related to my previous inquiry; when you install stand-alone emulators, they do not show up in add-ons. Is there something I am missing?
Also, I love how this is progressing, I check it out now and then ...what a great job.
  How to boot an older, working kernel bits 0 2,997 11-01-2024, 04:43 PM
Last Post: bits
  Libreelec nfs shares nberg@xs4all.nl 0 2,040 11-11-2022, 01:18 PM
Last Post: nberg@xs4all.nl
  Linux 5.15 Kernel - openSuse mark1250 0 2,985 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 14,390 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian kernel stuck at 4.4.167 Enig123 5 10,703 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 21,967 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 7,454 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 12,226 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 8,059 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 3,619 02-05-2020, 10:58 PM
Last Post: dkebler
Users browsing this thread: 13 Guest(s)
