WiFi on Xenial Minimal
Hello all!
I'm hoping I'm missing something simple, but I'm having a hard time setting up WiFi.
I've created a wpa_supplicant.conf and filled it with my network details, and created wlan0 with a similar config to the wlan1 file, and yet couldn't get the WiFi to start.
Also tried a guide for Raspberry Pi 3 (at-least-you-tried.jpg) as well and had no luck there (no wiconfig tool?).
Is there a guide to setting up WiFi on the minimal installs, or are they designed to only be set up using an Ethernet adapter?
Sent from my ONEPLUS A3003 using Tapatalk
[ PHP Developer | Pinebook 1G | About me ]
I haven't used that image specifically, but others had the nmtui (network manager terminal user interface) utility which worked well.
I could use some help with this as well. I downloaded the minimal Pinebook image but without wifi support, it is pretty challenging. I've been troubleshooting this for hours.
This was an issue on AOSC as well.
Success! I followed the instructions here:
https://www.linuxbabe.com/command-line/u...supplicant
I ignored everything prior to step 3 - installing anything wasn't an option, and iwconfig isn't installed. The steps for setting up the wpa_supplicant and dhclient worked for me. Make sure you pay attention to when to use sudo.
  Wifi doesn't work correctly Fredric92 1 8,256 08-10-2021, 08:39 AM
Last Post: Jean-Marc LACROIX
  Flakey WIFI (problems authenticating, etc.) robbiemacg 6 14,605 12-15-2019, 04:31 AM
Last Post: matze79
  Armbian - Xenial Desktop (Pinebook) pineadmin 83 175,306 07-17-2019, 01:22 PM
Last Post: catsmile
  Adding coherent_pool to boot.cmd on Xenial Mate by Ayufan causes boot loop k_mp 0 3,533 06-11-2019, 01:36 PM
Last Post: k_mp
  Wifi I/F on Pinebook 11.6" eblot 2 6,923 05-19-2019, 04:53 PM
Last Post: Shoananas
  Problems putting Ubuntu (Xenial Mate) on my replacement eMMC. frank-zappa 11 24,354 05-01-2019, 12:09 PM
Last Post: frank-zappa
  Xenial Images (Pinebook) 0.6.2-77 pineadmin 11 26,153 09-24-2018, 03:21 AM
Last Post: erchache2000
  Problems to install qemu on Xenial Mate (for EMMC) demian 1 5,469 03-14-2018, 08:43 AM
Last Post: xalius
  Ubuntu Unity 7 on 16.04 Xenial soupbowl 2 7,352 12-03-2017, 01:01 PM
Last Post: soupbowl
  Wifi applet after resume from suspend Luke 13 25,385 10-01-2017, 05:26 AM
Last Post: maya.b
