Announcement: DietPi for PineA64
#51
I have just received this board, but it won't boot the latest DietPi image at all ..... I just see white/red and green LED's light up when I apply power, but nothing on the screen, no flashing LED's ... just dead ... what can I do? Is the board broke?
I have tried both SD and eMMC media.
Please help
(12-04-2017, 06:46 PM)ebike Wrote: Hi,
Please help
Well you're posting in the Pine A64 section and the image is for the Rock64. From what you've wrote I assume you're using the Pine64-LTS (since you mention eMMC)? There isn't a DietPi LTS image for the Pine64-LTS.
Thanks,
I have a Rock64 board and am posting to this thread as the main install page told me to, see DietPi section here: http://wiki.pine64.org/index.php/ROCK64_...re_Release
If this is the wrong forum, then where is the correct thread??
By the way, the only image I managed to get booting was the OpenMediaVault one, and I had to short out the eMMC pins to do that ..... that detail seems to be missing from any install instructions, and there is no link included with the purchase of the board.
(05-16-2016, 02:46 PM)rhkean Wrote: [Image: dietpi-logo_150.png]
DietPi for Pine A64: Give your Pine A64 some lightweight justice.
http://DietPi.com
Known Issues
  • Kodi: Not working at this time
  • LXDE: Requires 16/24 bit to function (use 24bit for both LXDE and Kodi).
  • BlueTooth: the bluetooth portion of the wifi/bluetooth board has not been tested yet.  This is on my ToDo list.
Hey guys, any idea on the KODI fix?
Appreciate the help!
How about the Bluetooth? How to get out from following error:
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2019-01-08 00:36:21 EET; 10h ago
Docs: man:bluetoothd(8)
Main PID: 745 (bluetoothd)
Status: "Running"
CGroup: /system.slice/bluetooth.service
└─745 /usr/lib/bluetooth/bluetoothd
tammi 08 00:36:21 DietPi systemd[1]: Starting Bluetooth service...
tammi 08 00:36:21 DietPi bluetoothd[745]: Bluetooth daemon 5.43
tammi 08 00:36:21 DietPi systemd[1]: Started Bluetooth service.
tammi 08 00:36:21 DietPi bluetoothd[745]: Starting SDP server
tammi 08 00:36:21 DietPi bluetoothd[745]: Bluetooth management interface 1.3 initialized
tammi 08 00:36:21 DietPi bluetoothd[745]: Failed to obtain handles for "Service Changed" characteristic
tammi 08 00:36:21 DietPi bluetoothd[745]: Sap driver initialization failed.
tammi 08 00:36:21 DietPi bluetoothd[745]: sap-server: Operation not permitted (1)
tammi 08 00:36:21 DietPi bluetoothd[745]: hci0 Load Connection Parameters failed: Unknown Command (0x01)
  Installing DietPi to EMMC on Rock64 rrosenheim 0 5,416 05-29-2019, 10:13 PM
Last Post: rrosenheim
  Announcement: OMV (OpenMediaVault) for PINE64 DuDu371 11 44,374 12-07-2018, 09:52 PM
Last Post: flinkazoid
  Cannot install Dstat on Debian Base PineA64 image ywoody 6 13,378 07-11-2016, 07:15 PM
Last Post: dkryder
