Most stable OS for Kodi on Rock64?
Hey guys,
I recently got a Rock64 with hopes of running LibreElec on it but there are too many issues with the build at the moment. I hope to eventually go back to Raybuntu's LibreElec build in the future when it is more stable, but for the time being it would be nice to have something that runs a little smoother. I only plan on using the Rock for Kodi.
I figure that Android is the most stable OS to install for Kodi, but idk how well it runs on Rock chip. As far as I know, in the past there were issues. Are there still issues with rock chip and Kodi on android?
My best guess would be that Android 7.1 would be the most stable, but if the ayufan Android TV build runs smooth for Kodi that might be a better option.
Any input on this would be greatly appreciated  Smile
Edit: I should also add that with Kodi, I only plan on streaming content with 1080p being the max resolution. If any other information is needed, let me know.
(12-03-2017, 12:34 AM)Sauromayne Wrote: Hey guys,
Ayufan's or the Stock Android build will do just fine.
Do you know if issues with the rock chip and Kodi on android still exist? (Such as auto refresh rate not working)
They do to a degree; it does not affect 1080p playback in any way however.
Good to know! Thank you for your help.
I have my rock64 (4gb) running android tv (ayudan) and I installed kodi and vlc and works very well.
Also, I installed Netflix (via apk) and works great.
My main inconvenience is the Bluetooth support.
I have a Bluetooth dongle that works on Linux but doesn't work on Android.
Sent from my Redmi Note 4 using Tapatalk
(12-04-2017, 11:21 AM)cristobalhdez Wrote: I have my rock64 (4gb) running android tv (ayudan) and I installed kodi and vlc and works very well.
So you are playing videos through VLC rather than Kodi? Did you have any issues with Kodi’s media player or do you just prefer VLC?
I have VLC because I installed an app IP TV that use vlc for play de videos (live streaming). I didn't play a lot with kodi, but I am able to see my full HD movies without issues.
Alright sweet thanks for the help!
Curious around Netflix. Do you know which APK you used on the Android TV build? Did you use the tablet mode build, or the ATV Specific one that you get on Sony TV, Nvidia Shield and MiiBox etc? I have had no luck using the ATV version, and am relegated to using the tablet mode version which is not very usable with my remote that I use via FLiRC infrared dongle.
If you  know which version we can hack up to work with ATV and display the proper Netflix icon in leanback UI (versus having to use Sideload launcher) that would be great!
  Rock64 v2.0 u-boot SPI issues ju0n 1 1,553 09-25-2026, 11:19 PM
Last Post: mysy
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 6,397 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 29,525 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 17,292 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 19,519 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 5,042 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 10,274 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 11,294 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,689 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 5,092 11-28-2022, 02:18 PM
Last Post: Macgyver
