Possible Hardware Fault/Issue
Hi All,
I have 2 brand new rock64's 2GB. they arrived a week ago. Overall very impressed compared to my old raspberry pi.
I have installed and done a basic linux / armhf config using ayufan-rock64 (jessie-omv-armhf). Everything working fine and i'm using brand new SD cards.
I setup the second board exactly the same - again using a brand new SD card. All fine for a while then i noticed occasional issues with the OMV web interface restarting. looked at the syslog and i see the board has done a reboot cycle. there is no load on the board just restart without any user intervention. Happens every few hours but no pattern.
Thought it was an installation issue so started over but same issue.
Now i am using the same SD card and swapping between the 2 boards using same network cable and power supply.  I can can firm the issue only happens on one of the two boards.
Nothing in the logs that I can find but I'm not an expert...
Can anyone help or is this a support issue for Pine 64?
Did you try to swap the power supplies as well?
(11-29-2017, 04:19 PM)xalius Wrote: Did you try to swap the power supplies as well?
Yes. Since I first started seeing this issue I am using the same power, ethernet and SD card. Just swapping out the rock64 board to see if I can reproduce the issue on the good board.
Same thing keeps happening (board restart) without any user intervention. But only on one of my two brand new / identical boards.
Any further thoughts on this? I’m really not clear on what to do to get this resolved
Since you have a test setup where you can only swap the board and reproduce the issue consistently I would say it is really a hardware issue, I would try and get the one board replaced by Pine.
(11-30-2017, 08:07 AM)jata Wrote: Any further thoughts on this? I’m really not clear on what to do to get this resolved
Please file a support ticket at http://support.pine64.org and mentioned about this thread. Support team will review and resolve for you.
Thanks for the link. support ticket raised.
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? klausfelix 0 2,994 07-02-2021, 03:13 PM
Last Post: klausfelix
Question Hardware issues with Rock64 grobbs 10 18,631 04-08-2021, 05:24 AM
Last Post: t4_4t
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? hunderteins 10 24,509 11-17-2020, 08:00 AM
Last Post: Johannes
  HDMI 2.0a CEC compliancy issue? Willem53 1 4,586 04-13-2019, 08:02 AM
Last Post: Willem53
  self-reboot issue pas059 6 12,561 02-11-2019, 05:02 AM
Last Post: pas059
  C++ GPIO seg fault on Rock64 using Pine64-CPP Jeff R 1 5,845 02-06-2019, 07:40 PM
Last Post: Jeff R
  Rock64 scipy, numpy, scikit-image, matplotlib issue with pip3 ictele 0 3,662 02-05-2019, 05:41 PM
Last Post: ictele
  My Rock64 no power or light issue Nolaboy406 3 7,532 07-24-2018, 12:52 AM
Last Post: Luke
  Reboot Issue with ROCK64 Linux version 4.4.77-rockchip-ayufan-141 techyjtmb 9 17,918 06-23-2018, 09:52 AM
Last Post: NablaMetal
  Hardware Acceleration H264 encoding fred-simard 1 5,973 06-07-2018, 04:53 PM
Last Post: evilbunny
