Real-time linux kernel
(03-07-2016, 11:24 AM)umiddelb Wrote: I've re-mediated the rejected hunks and this time the kernel builds and boots up nicely. You can download the the kernel binary tar archive here.
Unpack with:
curl -sSL https://github.com/umiddelb/z2d/blob/master/kernel/linux-3.10.65-2-pine64-rt69+-p64.tar.xz?raw=true | sudo tar --numeric-owner -C / -xpJf -
You may find the kernel sources here.
OK. VERY GOOD! Thanks. But i don't have Pine64 board now. Waiting my board... If you have Pine64 board you can try run test like here: https://rt.wiki.kernel.org/index.php/Cyclictest
Unpack with:
During the next two days I'll try to look at the configuration file for one of the distributions using kernel Linux real-time. Compare them with the configuration file you used when building of our current kernel. Let's try a little bit to optimize it)))
@umiddelb
Hi again Uli!
Try to recompile the kernel with these options:
# RCU Subsystem
CONFIG_TREE_PREEMPT_RCU=y
CONFIG_PREEMPT_RCU=y
# Kernel Features
CONFIG_PREEMPT=y
CONFIG_PREEMPT_RT_BASE=y
CONFIG_HAVE_PREEMPT_LAZY=y
CONFIG_PREEMPT_LAZY=y
CONFIG_PREEMPT_RT_FULL=y
CONFIG_PREEMPT_COUNT=y
CONFIG_HZ_FIXED=0
CONFIG_HZ_100=y
CONFIG_SCHED_HRTICK=y
# Timers subsystem
CONFIG_HIGH_RES_TIMERS=y
# Debug Lockups and Hangs
CONFIG_TIMER_STATS=y
CONFIG_DEBUG_PREEMPT=y
# RCU Debugging
If the kernel build a successful, try to make the tests.
(03-09-2016, 01:44 AM)Artyom Wrote: @umiddelb
Hi again Uli!
# RCU Subsystem
(OK) CONFIG_TREE_PREEMPT_RCU=y
(OK) CONFIG_PREEMPT_RCU=y
# Kernel Features
(OK) CONFIG_PREEMPT=y
(OK) CONFIG_PREEMPT_RT_BASE=y
(Not present) CONFIG_HAVE_PREEMPT_LAZY=y
(Not present) CONFIG_PREEMPT_LAZY=y
(Not present) CONFIG_PREEMPT_RT_FULL=y
(OK) CONFIG_PREEMPT_COUNT=y
(ARMv7 only, 3.12+ only)CONFIG_HZ_FIXED=0
(MIPS only) CONFIG_HZ_100=y
(ARMv7 only) CONFIG_SCHED_HRTICK=y
# Timers subsystem
(ARMv7 only) CONFIG_HIGH_RES_TIMERS=y 1
(OK) CONFIG_TIMER_STATS=y
(OK) CONFIG_DEBUG_PREEMPT=y
# RCU Debugging
Hi Artyom,
the green coloured settings are already enabled, the red coloured settings cannot be enabled due to different reasons:
- they depend on a certain architecture or minimal kernel version
- they depend on additional patches being applied first
Cheers
Uli
Hi again Uli!
# RCU Subsystem
# Kernel Features
# Timers subsystem
# RCU Debugging
Hi Artyom,
Cheers
Uli
You use "make menuconfig" when configuring your kernel? I find some info about (as i undestand minimal kernel configuration):
Required parameters for configuring realtime kernel?
Kernel 2.6.x:
CONFIG_PREEMPT=y
CONFIG_PREEMPT_RT=y
Kernel 3.x:
CONFIG_PREEMPT=y
Optional parameters for configuring realtime kernel, but they affect realtime performance?
More you can find here: https://rt.wiki.kernel.org/index.php/Fre...nel_3.x:_2
As I undestand CONFIG_PREEMPT_RT_FULL must present in our kernel...
Hi again Uli!
# RCU Subsystem
# Kernel Features
# Timers subsystem
# RCU Debugging
Hi Artyom,
Cheers
Uli
Kernel 2.6.x:
CONFIG_PREEMPT=y
CONFIG_PREEMPT_RT=y
Kernel 3.x:
CONFIG_PREEMPT=y
Uli, try to find this in "menuconfig": Preemption Model --> Fully Preemptible Kernel (RT)
(03-10-2016, 05:24 AM)Artyom Wrote: Uli, try to find this in "menuconfig": Preemption Model --> Fully Preemptible Kernel (RT)
only CONFIG_PREEMPT_RT_BASE is offered at this time (and enabled). You may get in touch with chlorisdroid, he managed to build a RT enabled Linux kernel for the ODROID -C2.
Uli, can you post instructions how you reconfigure pine64 rt kernel from github with using menuconfig? And how you compile them...
(03-10-2016, 07:03 AM)Artyom Wrote: Uli, can you post instructions how you reconfigure pine64 rt kernel from github with using menuconfig? And how you compile them...
I've updated the description how to  build a custom kernel on the PINE64 in order to reflect @longsleeps recent changes on U-Boot .
For the RT kernel just take my Github repository instead, so
git clone --depth 1 --single-branch -b pine64-hacks-1.2 https://github.com/umiddelb/linux-pine64-rt.git curl -sSL https://github.com/longsleep/build-pine64-image/raw/master/blobs/pine64.dts > linux-pine64/arch/arm64/boot/dts/sun50i-a64-pine64-plus.dts make sun50iw1p1smp_linux_defconfig make menuconfig make clean make -j 4 Image sun50i-a64-pine64-plus.dtb modules
and so on.
and so on.
Yesterday I wrote chloris droid. Waiting for an answer... I also plan to write RT patch developers. Furthermore Now I recompile the kernel Raspberry Pi 2 to integrate ARM Gator. How to deal with him, we will integrate ARM Gator in Pne64 core.
There did not seem difficult now. You in? )))
#19
and so on.
As it turned out, even on Rpi2 ARM DS5 and ARM Gator work to put it mildly is not very good. Simply put Eclipse on Rpi2.
So I think to abandon the ARM Gator integration into Pine64 kernel.
#20
@umiddelb
Hi Uli. Seems I find solution, why FULL_PREEPT_RT didn't work.
Read this (https://patches.linaro.org/patch/47646/), and tell me what you think?
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 17,435 03-28-2020, 06:20 PM
Last Post: ty1911
  PineA64+: Audio in 5.0 Kernel puzzles 6 16,681 11-13-2019, 09:41 AM
Last Post: roel
  Howto run Linux with resolution other than 1080p longsleep 28 96,132 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 10,283 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,711 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 72,869 01-28-2019, 11:05 PM
Last Post: necrose99
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,925 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 4,385 09-25-2018, 03:39 PM
Last Post: bjbb17
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,488 06-21-2018, 05:45 PM
Last Post: evilbunny
  linux distribution hazerty 3 10,384 04-01-2018, 02:48 PM
Last Post: dkryder
