android Wlan problem
hello,
i have two dongle with ralink chipset, but dont's works with the last android tv !
it's possible to add drivers please ?
thanks for your help
I actually found one that works out of the box with an Android 7.1.2 TV and regular Android 7.1.2 install, EMMC Flash and Sd install.
Just plug it in and it works.
https://www.amazon.com/gp/product/B008IF...=UTF8&th=1
(10-18-2017, 07:51 AM)Guy the IT Guy Wrote: I actually found one that works out of the box with an Android 7.1.2 TV and regular Android 7.1.2 install, EMMC Flash and Sd install.
thanks,
but the links dont's works  Tongue
I am very disappointed with your article  Angry , I offer to buy a raspery and less problem ....
please is it possible to have a list of compatible wlan?????  Huh Huh Huh Huh
because I have tested many dongle with diffrents chispset and none works
thanks
https://www.pine64.org/?product=usb-wifi...for-rock64
This one works.
Hello I have similar problems with my wifi dongle.
Wifi Dongle:
Edimax EW-7811Un
Realtek RTL8188CUS
Bus 005 Device 002: ID 7392:7811
Sadly I was not able to find an sutable driver for the dongle but the EDIMAX homepage gives a hind to build one. Since i'm quit a noob regarding android and drivers in general here I need a lot of help.
Within the linux driver I found a "readme" with adive how to setup the driver for android but I'm not sure about the architecture of the system. So please could some one gives me an step by step tutorial how to come closer to this WiFi issue?
With kind regards
ED
================================================================================ Realtek Wi-Fi SDK for Android Version 2.1 ================================================================================ This document provides a simple guide to help engineers to apply Realtek Wi-Fi solution onto their Android system. For now, we have supported the following Wi-Fi functionality on Android up to 2.3: 1. Standard STA mode 2. Portable Wi-Fi Hotspot(SoftAP mode) To port Realtek Wi-Fi driver onto Android platform, you can go through the following guide with reference codes within our driver package's realtek_wifi_SDK_for_android_20120618.tar.gz. Because Android's SDK may differ from platform to platform, our reference codes may not be applied on every platform without modifications. You should check if our reference code is suitable for you to use. ================================================================================ 1. Platform Related Files [MUST] ================================================================================ a. BOARD_USES_REALTEK_WIFI := true Ensure "BOARD_USES_REALTEK_WIFI := true" is defined in BoardConfig.mk. This is for some compile-time choices to be applied for our Wi-Fi solution. b. BOARD_WPA_SUPPLICANT_DRIVER := WEXT Our driver implements the wireless extension interface for communication with user space programs. For wpa_supplicant, it's needed to set "BOARD_WPA_SUPPLICANT_DRIVER := WEXT" in BoardConfig.mk to make wpa_supplicant use the interface implemented in driver_wext.c to communicate with our driver. c. WPA_SUPPLICANT_VERSION := VER_0_6_X Android provides both wpa_supplicant and wpa_supplicant_6 inside. We suggest using wpa_supplicant_6. You can set "WPA_SUPPLICANT_VERSION := VER_0_6_X" in the BoardConfig.mk to use wpa_supplicant_6 for your platform. d. Service definitions Make sure the service definitions of wpa_supplicant, dhcpd, hostapd is defined in init.rc or init.xxx.rc for your platform. As following: service wpa_supplicant /system/bin/wpa_supplicant -Dwext -iwlan0 -c/data/misc/wifi/wpa_supplicant.conf disabled oneshot service hostapd /system/bin/hostapd_wps /data/misc/wifi/hostapd.conf disabled oneshot service dhcpcd /system/bin/dhcpcd -ABKL disabled oneshot ¡° The hostapd service is for Porttable Wi-Fi Hotspot. If you don't want to use Porttable Wi-Fi Hotspot for your platfrom, you can ignore it. ================================================================================ 2. libwpa_client [MUST] ================================================================================ The libwpa_client library is linked into libhardware_legacy library for Wi-Fi to communicate with wpa_supplicant. Instead of using the original libwpa_client of wpa_supplicant or wpa_supplicant_6, we use the libwpa_client of hostapd-0.6.9_rtl from us to provide extension functionalities for our Wi-Fi solutions. To apply this: a. Copy necessary files Copy our hostapd-0.6.9_rtl/ folder into external/ folder of your platform. b. Prevent the original libwpa_client to be compiled Modify the external/wpa_supplicant/Android.mk and external/wpa_supplicant_6/Android.mk to prevent the libwpa_client to be compiled from wpa_supplicant and wpa_supplicant_6. For example: ifneq ($(BOARD_USES_REALTEK_WIFI),true) include $(CLEAR_VARS) LOCAL_MODULE = libwpa_client LOCAL_CFLAGS = $(L_CFLAGS) LOCAL_SRC_FILES = wpa_ctrl.c os_unix.c LOCAL_C_INCLUDES = $(INCLUDES) LOCAL_SHARED_LIBRARIES := libcutils LOCAL_COPY_HEADERS_TO := libwpa_client LOCAL_COPY_HEADERS := wpa_ctrl.h include $(BUILD_SHARED_LIBRARY) endif Reference files: external/hostapd-0.6.9_rtl/* external/wpa_supplicant/Android.mk external/wpa_supplicant_6/Android.mk ================================================================================ 3. libhardware_legacy [MUST] ================================================================================ The libhardware_legacy library includes functionality for Wi-Fi to operate. We have made modifications and extensions for our Wi-Fi solution. To apply this: a. Copy necessary files Copy our wifi_realtek.c into hardware/libhardware_legacy/wifi folder of your platform. b. Include wifi_realtek.c into source files Modify hardware/libhardware_legacy/wifi/Android.mk to include wifi_realtek.c instead of wifi.c into LOCAL_SRC_FILES. For example: ifeq ($(BOARD_USES_REALTEK_WIFI),true) LOCAL_SRC_FILES += wifi/wifi_realtek.c else LOCAL_SRC_FILES += wifi/wifi.c endif Reference files: hardware/libhardware_legacy/wifi/Android.mk hardware/libhardware_legacy/wifi/wifi_realtek.c ================================================================================ 4. dhcpcd [SUGGEST] ================================================================================ We have made some modifications for dhcpcd. To apply this: a. Copy necessary files Copy our client_realtek.c and logger_realtek.c into external/dhcpcd folder of your platform. b. Include logger_realtek.c and client_realtek.c into source files Modify external/dhcpcd/Android.mk to include logger_realtek.c and client_realtek.c instead of logger.c and client.c into LOCAL_SRC_FILES. For example: ifeq ($(BOARD_USES_REALTEK_WIFI),true) LOCAL_SRC_FILES += logger_realtek.c client_realtek.c else LOCAL_SRC_FILES += logger.c client.c endif c. Include libhardware_legacy into shared libraries Modify external/dhcpcd/Android.mk to include libhardware_legacy into LOCAL_SHARED_LIBRARIES. For example: ifeq ($(BOARD_USES_REALTEK_WIFI),true) LOCAL_SHARED_LIBRARIES += libhardware_legacy endif Reference files: external/dhcpcd/Android.mk external/dhcpcd/client_realtek.c external/dhcpcd/logger_realtek.c ================================================================================ 5. wpa_supplicant ================================================================================ a. Version of wpa_supplicant We suggest using wpa_supplicant_6 of Android. See 1.c. for reference. b. Prevent the original libwpa_client to be compiled Because we use libwpa_client from hostapd-0.6.9_rtl. We should prevent the original libwpa_client of wpa_supplicant and wpa_supplicant_6 to be compiled. See '2. libwpa_client' for reference. c. wpa_supplicant.conf Following is the reference content of wpa_supplicant.conf: ctrl_interface=DIR=/data/misc/wifi/wpa_supplicant GROUP=wifi update_config=1 ap_scan=1 Reference files: external/wpa_supplicant/Android.mk ================================================================================ 6. netd [MUST for Portable Wi-Fi hotspot] ================================================================================ The Portable Wi-Fi hotspot functionality is controlled by the SoftapController subfunction of netd. We provide our own SoftapController implementation to run our hostapd daemon for softap mode. To apply this: a. Copy necessary files Copy our SoftapController_realtek.cpp into system/netd/ folder of your platform. b. Include SoftapController_realtek.cpp into source files Modify system/netd/Android.mk to include SoftapController_realtek.cpp instead of SoftapController.cpp into LOCAL_SRC_FILES. For example: ifeq ($(BOARD_USES_REALTEK_WIFI), true)    LOCAL_SRC_FILES += SoftapController_realtek.cpp else    LOCAL_SRC_FILES += SoftapController.cpp endif c. Include libhardware_legacy into shared libraries Modify system/netd/Android.mk to include libhardware_legacy into LOCAL_SHARED_LIBRARIES. For example: ifeq ($(BOARD_USES_REALTEK_WIFI), true)    LOCAL_SHARED_LIBRARIES += libhardware_legacy endif Reference files: system/netd/Android.mk system/netd/SoftapController_realtek.cpp ================================================================================ 7. Opening Portable Wi-Fi Hotspot UI ================================================================================ We should set interface item to the following two resource configurations of your platform to show the UI for Portable Wi-Fi Hotspot. a. config_tether_wifi_regexs The interfaces set here is used as the interfaces for Wi-Fi LAN port. We use 'wlap0' by default when our wifi is set as softap mode. So it needs to set 'wlap0' here for system to recognized 'wlap0' as Wi-Fi LAN port. For example: <string-array translatable="false" name="config_tether_wifi_regexs"> <item>"wlap0"</item> </string-array> b. config_tether_upstream_regexs The interfaces set here are used as the interfaces for WAN port to connect to internet. Usually, 'ppp0' used by 3G, 'eth0' used by ethernet, 'wlan0' used by Wi-Fi can be set here. For example: <string-array translatable="false" name="config_tether_upstream_regexs"> <item>"ppp\\d"</item> <item>"eth\\d"</item> <item>"wlan\\d"</item> </string-array> Android will apply DHCP server function for Wi-Fi LAN port, and setup NAT between Wi-Fi LAN port and WAN port automatically. Reference files: frameworks/base/core/res/res/values/config.xml ================================================================================ 8. Patch for WifiSettings.java ================================================================================ The WifiSettings UI page has bug which doesn't get lastest WiFi information. We provide patch to fix this problem. Add the following 4 line at the beginning of function updateAccessPoints():        mLastInfo = mWifiManager.getConnectionInfo();        mLastState = WifiInfo.getDetailedStateOf(mLastInfo.getSupplicantState());        if(mLastState == DetailedState.OBTAINING_IPADDR && mLastInfo.getIpAddress() != 0)            mLastState = DetailedState.CONNECTED; Reference files: packages\apps\Settings\src\com\android\settings\wifi\WifiSettings.java ================================================================================ 9. Driver Configuration and Compilation ================================================================================ a. MODULE_NAME defined in Makefile For android to rmmod the wifi driver module, the driver module name, which is decided in compilation time as MODULE_NAME defined in Makefile, should be the same as WIFI_DRIVER_MODULE_NAME defined in wifi_realtek.c: #define WIFI_DRIVER_MODULE_NAME "wlan" b. Driver Compilation For driver compilation, please refer to: doument/Quick_Start_Guide_for_Driver_Compilation_and_Installation.pdf c. Where to place wifi driver module If you compile wifi driver as .ko file, you should place wifi driver module to the path defined in wifi_realtek.c with WIFI_DRIVER_MODULE_PATH macro. The default path defined in wifi_realtek.c: #define WIFI_DRIVER_MODULE_PATH "/system/wifi/wlan.ko"
  Android Images (ROCK64) pineadmin 77 247,065 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,535 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,811 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,992 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,953 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,658 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,813 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,494 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,738 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 9,105 09-18-2020, 07:58 PM
Last Post: BowerR64
