Best USB3.0 to SATA bridge
I'm working on a Rock64 NAS project, now I want to know which USB to SATA cable I can use best?
Thx in advance
(09-28-2017, 03:40 AM)mikedhoore Wrote: Hi,
Thx in advance
 JMicron JMS578 think is getting best approval but to be honest USB to Sata is stinky especially with multiple file transfers.
If your going to use a singular drive give it a test on multiple file access.
Then multiple disk... mweh.
I have sort of given up on USB for what I would call traditional multidisk NAS
Thx in advance
thx
i'm looking for a model that can be used on a 3TB WD red (3.5")
 I found this one : EBAY LINK
But i don't really need the enclosure. ?
https://www.everythingusb.com/drive-adapters.html
http://www.ebay.co.uk/itm/like/142451491...735&crdt=0
Inatech is a ASM one but just do some googling and check the chipset. Linux 4.4 doesn't do USB3.1 it was either 4.6 or 4.9 (forgot which).
USB 3.0 I would go for JMicron JMS578 with the  ASM1153E a close 2nd.
The newer ones maybe even better but there are less reviews with the ASM1351 and VIA’s VL716.
https://www.asmedia.com.tw/eng/e_show_pr...e_index=97 ASM1153E (I think that might be UAS blacklisted)
https://www.jmicron.com/product0201.html JMS578
https://www.asmedia.com.tw/eng/e_show_pr...7&item=156  ASM1351
https://www.via-labs.com/product_show.php?id=68 VIA’s VL716
Have a browse of the Armbian and OMV forums and ask a question.
https://www.openmediavault.org/
https://www.armbian.com/
Just get an adapter from ebay or amazon do a bit of reserach so you know the chipset.
Just grab any hardrive and see what you get for a single transfer and then queue up some simultaneous transfers and see how much you lose.
Hii,
I only can find docking stations on Ebay with the JMS578.
I cannot find a simple USB cable to SATA with 12V ??
Anyone a link ? (non of the links from stuartiannaylor works)
(10-02-2017, 06:17 AM)mikedhoore Wrote: Hii,
Amazon just search for usb+3.0+sata+iii+12v "copy and paste that"
Same on ebay.
PS weird about those links on differing sites as they did work. Its like the chip manufactures apart from via are stopping access.
Inateck USB 3.0 to SATA III Hard Drive Adapter
Orico USB 3.0 to SATA III Hard Drive Adapter
Seem to be pretty good and much cheaper than the startech ones.
Same on ebay.
Amazon is not an option to belgium Wink
I found 100.000 on ebay but always for 2.5" or theye dont mention what chip is inside .. ?
  USB3 SATA ReleaseTheGeese 2 4,845 04-04-2021, 12:55 PM
Last Post: ReleaseTheGeese
  USB3 to SATA cable - Firmware Eule 0 3,387 03-03-2020, 01:31 PM
Last Post: Eule
  USB3 enough to power 2,5 external HDD? va88 11 22,234 06-06-2019, 03:40 PM
Last Post: va88
  Does the Pine usb to sata adapter work with hd-parm? FabrizioMaurizio 0 3,056 02-06-2019, 11:37 AM
Last Post: FabrizioMaurizio
  unable to switch usb3 ports on cglhu 6 12,829 05-17-2018, 08:43 AM
Last Post: cglhu
  USB 3 2.5" SATA Case thewonderer 2 5,821 12-13-2017, 06:05 PM
Last Post: thewonderer
Information Rock64 SSD internal PNY CS900 240GB w/Pine usb|sata adapter MarkHaysHarris777 1 5,354 09-30-2017, 06:48 AM
Last Post: dkryder
