Rock64 Cluster.
One thing to consider to is your storage, for example I too am planning on a 5 node cluster. I'll be giving each one an SSD so if its a 5W SSD at 5V that is 1A so thats 5A just for the storage.
Any of you guys going to cluster storage also?
Been interested in https://lizardfs.com/, http://ceph.com/ & http://www.xtreemfs.org/
I would say ceph may well be viable, I already have some 100Mb USB to eth adaptors so I would probably use the onboard gig for the ceph. I cetainly run small proxmox clusters for small solutions with a single gig interface for the ceph.
clustering HDDs or SSDs..
depends on the use case, and what kind of existing storage infrastructure needs to be integrated/migrated:
on my storage side: 2 x 8TB hdd, one 4tb hdd, and a 128er samsung evo ssd.
the ssd for smaller files, databases, system, aiming to network boot via SPI nor flash.
the main storage mechanism should be able to cache between the three elements optimizing read/write io, evaluating OMV and various setups and add ons.
in a cluster setup i'd rather have one dedicated storage node, one dedicated master/gateway node, keeping 3 (or more) nodes for distributed computing, kubernetes, docker swarm etc..
of course it's great to have ssds (especially for local database applications), but the sweet spot might be rather giving each node a smaller 1tb external 2.5" hdd, selecting one with low idle power. the gigabit connection would cap the possible added throughput when using ssds, while when clustering hdds it will be harder to saturate the network bandwith.
interesting distributed storage solutions:
https://tahoe-lafs.org/trac/tahoe-lafs
https://ipfs.io/
(09-23-2017, 11:45 AM)pitsch Wrote: clustering HDDs or SSDs..
https://ipfs.io/
If have been doing a lot of research on this and was in the ceph IRC group and they actually suggested LizardFS rather than Ceph.
Its in most mainline distro's already and its easier to set up and admin.
Have a look https://lizardfs.com/
  Rock64 v2.0 u-boot SPI issues ju0n 0 884 07-05-2026, 11:02 AM
Last Post: ju0n
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 6,227 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 28,895 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 17,001 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 19,029 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,928 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 10,070 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 11,085 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,458 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,996 11-28-2022, 02:18 PM
Last Post: Macgyver
