USB WiFi/BT dongle
Hi
I have bought a WiFi AC/BT dongle ZAPO
it is based on realtek chip
rock64 is unable to detect it
I'm running from eMMC last release from
root@rock64:~# lsusb Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 0bda:0823 Realtek Semiconductor Corp. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@rock64:~# dmesg [    0.000000] Booting Linux on physical CPU 0x0 [    0.000000] Initializing cgroup subsys cpuset [    0.000000] Initializing cgroup subsys cpu [    0.000000] Initializing cgroup subsys cpuacct [    0.000000] Linux version 4.4.77-rockchip-ayufan-101 (root@00b26df4b136) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) )  #1 SMP Fri Sep 8 14:48:39 UTC 2017 [    0.000000] Boot CPU: AArch64 Processor [410fd034] [    0.000000] earlycon: Early serial console at MMIO32 0xff130000 (options '') [    0.000000] bootconsole [uart0] enabled [    0.000000] On node 0 totalpages: 1043968 [    0.000000]   DMA zone: 16312 pages used for memmap [    0.000000]   DMA zone: 0 pages reserved [    0.000000]   DMA zone: 1043968 pages, LIFO batch:31 [    0.000000] psci: probing for conduit method from DT. [    0.000000] psci: PSCIv1.0 detected in firmware. [    0.000000] psci: Using standard PSCI v0.2 function IDs [    0.000000] psci: MIGRATE_INFO_TYPE not supported. [    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0fef39000 s46504 r8192 d31320 u86016 [    0.000000] pcpu-alloc: s46504 r8192 d31320 u86016 alloc=21*4096 [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [    0.000000] Detected VIPT I-cache on CPU0 [    0.000000] CPU features: enabling workaround for ARM erratum 845719 [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1027656 [    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff130000 rw root=LABEL=linux-root rootwait rootfstype=ext4 init=/sbin/init coheren t_pool=1M ethaddr=56:34:ef:c5:40:65 eth1addr=56:34:ef:c5:40:85 serial=8361233d443da32 [    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [    0.000000] software IO TLB [mem 0xf5c00000-0xf9c00000] (64MB) mapped at [ffffffc0f5c00000-ffffffc0f9bfffff] [    0.000000] Memory: 4010996K/4175872K available (11326K kernel code, 1448K rwdata, 4096K rodata, 1152K init, 745K bss, 164876K reserved, 0K cm a-reserved) [    0.000000] Virtual kernel memory layout:                   modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)                   vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)                     .init : 0xffffff8008fa0000 - 0xffffff80090c0000   (  1152 KB)                     .text : 0xffffff8008080000 - 0xffffff8008b90000   ( 11328 KB)                   .rodata : 0xffffff8008b90000 - 0xffffff8008fa0000   (  4160 KB)                     .data : 0xffffff80090c0000 - 0xffffff800922a008   (  1449 KB)                   vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)                             0xffffffbdc0008000 - 0xffffffbdc3fc0000   (    63 MB actual)                   fixed   : 0xffffffbffe7fd000 - 0xffffffbffec00000   (  4108 KB)                   PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)                   memory  : 0xffffffc000200000 - 0xffffffc0ff000000   (  4078 MB) [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [    0.000000] Hierarchical RCU implementation. [    0.000000]  Build-time adjustment of leaf fanout to 64. [    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4 [    0.000000] NR_IRQS:64 nr_irqs:64 0 [    0.000000] GIC: Using split EOI/Deactivate mode [    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [    0.001564] Console: colour dummy device 80x25 [    0.001975] console [tty0] enabled [    0.002296] bootconsole [uart0] disabled [    0.002692] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000) [    0.002729] pid_max: default: 32768 minimum: 301 [    0.002869] Security Framework initialized [    0.002890] Yama: becoming mindful. [    0.002924] AppArmor: AppArmor disabled by boot time parameter [    0.003007] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [    0.003037] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [    0.003974] Initializing cgroup subsys io [    0.004009] Initializing cgroup subsys memory [    0.004054] Initializing cgroup subsys devices [    0.004081] Initializing cgroup subsys freezer [    0.004106] Initializing cgroup subsys net_cls [    0.004132] Initializing cgroup subsys perf_event [    0.004159] Initializing cgroup subsys pids [    0.004227] ftrace: allocating 42437 entries in 166 pages [    0.117392] sched-energy: CPU device node has no sched-energy-costs [    0.117428] Invalid sched_group_energy for CPU0 [    0.117445] CPU0: update cpu_capacity 1024 [    0.117518] ASID allocator initialised with 65536 entries [    0.122755] Detected VIPT I-cache on CPU1 [    0.122813] Invalid sched_group_energy for CPU1 [    0.122818] CPU1: update cpu_capacity 1024 [    0.122823] CPU1: Booted secondary processor [410fd034] [    0.123624] Detected VIPT I-cache on CPU2 [    0.123671] Invalid sched_group_energy for CPU2 [    0.123676] CPU2: update cpu_capacity 1024 [    0.123681] CPU2: Booted secondary processor [410fd034] [    0.124459] Detected VIPT I-cache on CPU3 [    0.124504] Invalid sched_group_energy for CPU3 [    0.124509] CPU3: update cpu_capacity 1024 [    0.124513] CPU3: Booted secondary processor [410fd034] [    0.124636] Brought up 4 CPUs [    0.124912] SMP: Total of 4 processors activated. [    0.124947] CPU: All CPU(s) started at EL2 [    0.125009] alternatives: patching kernel code [    0.125260] Invalid sched_group_energy for CPU3 [    0.125292] Invalid sched_group_energy for Cluster3 [    0.125321] Invalid sched_group_energy for CPU2 [    0.125348] Invalid sched_group_energy for Cluster2 [    0.125377] Invalid sched_group_energy for CPU1 [    0.125430] Invalid sched_group_energy for Cluster1 [    0.125459] Invalid sched_group_energy for CPU0 [    0.125486] Invalid sched_group_energy for Cluster0 [    0.126209] devtmpfs: initialized [    0.142779] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [    0.142861] futex hash table entries: 1024 (order: 4, 65536 bytes) [    0.143506] xor: measuring software checksum speed [    0.152818]    8regs     :  1080.000 MB/sec [    0.162916]    8regs_prefetch:   968.000 MB/sec [    0.173013]    32regs    :  1352.000 MB/sec [    0.183112]    32regs_prefetch:  1116.000 MB/sec [    0.183144] xor: using function: 32regs (1352.000 MB/sec) [    0.183227] pinctrl core: initialized pinctrl subsystem [    0.183621] regulator-dummy: no parameters [    0.184561] NET: Registered protocol family 16 [    0.189235] cpuidle: using governor ladder [    0.193271] cpuidle: using governor menu [    0.193322] Registered FIQ tty driver [    0.193788] vdso: 2 pages (1 code @ ffffff8008b96000, 1 data @ ffffff80090c4000) [    0.193869] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [    0.194372] DMA: preallocated 1024 KiB pool for atomic allocations [    0.208356] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0 [    0.208498] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1 [    0.208656] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2 [    0.208790] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3 [    0.218278] genirq: Setting trigger mode 8 for irq 176 failed (gic_set_type+0x0/0x68) [    0.276100] console [ttyFIQ0] enabled [    0.276770] Registered fiq debugger ttyFIQ0 [    0.311919] raid6: int64x1  gen()   191 MB/s [    0.329001] raid6: int64x1  xor()   185 MB/s [    0.346212] raid6: int64x2  gen()   296 MB/s [    0.363296] raid6: int64x2  xor()   275 MB/s [    0.380521] raid6: int64x4  gen()   460 MB/s [    0.397746] raid6: int64x4  xor()   332 MB/s [    0.414988] raid6: int64x8  gen()   332 MB/s [    0.432096] raid6: int64x8  xor()   267 MB/s [    0.449285] raid6: neonx1   gen()   363 MB/s [    0.466548] raid6: neonx1   xor()   365 MB/s [    0.483756] raid6: neonx2   gen()   570 MB/s [    0.500911] raid6: neonx2   xor()   492 MB/s [    0.518121] raid6: neonx4   gen()   761 MB/s [    0.535326] raid6: neonx4   xor()   578 MB/s [    0.552549] raid6: neonx8   gen()   777 MB/s [    0.569721] raid6: neonx8   xor()   578 MB/s [    0.570120] raid6: using algorithm neonx8 gen() 777 MB/s [    0.570609] raid6: .... xor() 578 MB/s, rmw enabled [    0.571078] raid6: using intx1 recovery algorithm [    0.572011] mpp venc_srv: mpp_probe enter [    0.572448] mpp venc_srv: init success [    0.573456] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]' [    0.573492] vcc_phy: no parameters [    0.573733] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV [    0.573997] of_get_named_gpiod_flags: parsed 'gpio' property of node '/sdmmc-regulator[0]' - status (0) [    0.574061] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [    0.574084] vcc_sd: unable to resolve supply [    0.574100] vcc_sd: 3300 mV [    0.574322] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [    0.574344] vcc_sd: unable to resolve supply [    0.574360] reg-fixed-voltage sdmmc-regulator: vcc_sd supplying 3300000uV [    0.574477] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-sys[0]' [    0.574516] vcc_sys: 5000 mV [    0.574727] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [    0.574749] vcc_sd: unable to resolve supply [    0.574765] reg-fixed-voltage vcc-sys: vcc_sys supplying 5000000uV [    0.575379] iommu: Adding device ff350000.vpu-service to group 0 [    0.576058] iommu: Adding device ff360000.rkvdec to group 1 [    0.576645] iommu: Adding device ff330000.h265e to group 2 [    0.577251] iommu: Adding device ff340000.vepu to group 3 [    0.577836] iommu: Adding device ff370000.vop to group 4 [    0.579267] rk_iommu ff360480.iommu: can't get aclk [    0.579775] rk_iommu ff360480.iommu: can't get hclk [    0.580393] rk_iommu ff330200.iommu: can't get aclk [    0.580880] rk_iommu ff330200.iommu: can't get hclk [    0.581694] rk_iommu ff373f00.iommu: can't get aclk [    0.582178] rk_iommu ff373f00.iommu: can't get hclk [    0.583267] SCSI subsystem initialized [    0.583945] usbcore: registered new interface driver usbfs [    0.584551] usbcore: registered new interface driver hub [    0.585162] usbcore: registered new device driver usb [    0.585764] media: Linux media interface: v0.10 [    0.586246] Linux video capture interface: v2.00 [    0.586805] pps_core: LinuxPPS API ver. 1 registered [    0.587274] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [    0.588249] PTP clock support registered [    0.590234] Advanced Linux Sound Architecture Driver Initialized. [    0.591681] Bluetooth: Core ver 2.21 [    0.592095] NET: Registered protocol family 31 [    0.592543] Bluetooth: HCI device and connection manager initialized [    0.593136] Bluetooth: HCI socket layer initialized [    0.593620] Bluetooth: L2CAP socket layer initialized [    0.594122] Bluetooth: SCO socket layer initialized [    0.595294] NetLabel: Initializing [    0.595660] NetLabel:  domain hash size = 128 [    0.596072] NetLabel:  protocols = UNLABELED CIPSOv4 [    0.596610] NetLabel:  unlabeled traffic allowed by default [    0.597596] rockchip-cpuinfo cpuinfo: Serial         : 08361233d443da32 [    0.598943] clocksource: Switched to clocksource arch_sys_counter [    0.698472] NET: Registered protocol family 2 [    0.699779] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [    0.700905] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes) [    0.703089] TCP: Hash tables configured (established 32768 bind 32768) [    0.703803] UDP hash table entries: 2048 (order: 5, 196608 bytes) [    0.704654] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes) [    0.705836] NET: Registered protocol family 1 [    0.706829] RPC: Registered named UNIX socket transport module. [    0.707418] RPC: Registered udp transport module. [    0.707865] RPC: Registered tcp transport module. [    0.708328] RPC: Registered tcp NFSv4.1 backchannel transport module. [    0.708958] PCI: CLS 0 bytes, default 64 [    0.709233] Trying to unpack rootfs image as initramfs... [    1.332127] Freeing initrd memory: 7508K (ffffffc0fc7c5000 - ffffffc0fcf1a000) [    1.333661] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [    1.335641] kvm [1]: 8-bit VMID [    1.335995] kvm [1]: Hyp mode initialized successfully [    1.336914] kvm [1]: interrupt-controller@ff814000 IRQ43 [    1.337787] kvm [1]: timer IRQ3 [    1.342368] audit: initializing netlink subsys (disabled) [    1.342952] audit: type=2000 audit(1.247:1): initialized [    1.344070] Initialise system trusted keyring [    1.358338] VFS: Disk quotas dquot_6.6.0 [    1.359056] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [    1.363735] NFS: Registering the id_resolver key type [    1.364286] Key type id_resolver registered [    1.364686] Key type id_legacy registered [    1.365104] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [    1.366831] fuse init (API version 7.23) [    1.368323] JFS: nTxBlock = 8192, nTxLock = 65536 [    1.375852] SGI XFS with ACLs, security attributes, realtime, no debug enabled [    1.385503] NET: Registered protocol family 38 [    1.386016] Key type asymmetric registered [    1.386419] Asymmetric key parser 'x509' registered [    1.387231] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [    1.387954] io scheduler noop registered [    1.388344] io scheduler deadline registered (default) [    1.389095] io scheduler cfq registered [    1.390792] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply from device tree [    1.390813] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/host-port failed [    1.391437] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply from device tree [    1.391458] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/otg-port failed [    1.391872] rockchip-usb2phy ff450000.syscon:usb2-phy@100: GPIO lookup for consumer otg-vbus [    1.391888] rockchip-usb2phy ff450000.syscon:usb2-phy@100: using device tree for GPIO lookup [    1.392109] of_get_named_gpiod_flags: parsed 'otg-vbus-gpios' property of node '/syscon@ff450000/usb2-phy@100[0]' - status (0) [    1.392797] rockchip-u3phy ff470000.usb3-phy: GPIO lookup for consumer vbus-drv [    1.392814] rockchip-u3phy ff470000.usb3-phy: using device tree for GPIO lookup [    1.392846] of_get_named_gpiod_flags: parsed 'vbus-drv-gpios' property of node '/usb3-phy@ff470000[0]' - status (0) [    1.393303] phy phy-ff470000.usb3-phy.2: Looking up phy-supply from device tree [    1.393322] phy phy-ff470000.usb3-phy.2: Looking up phy-supply property in node /usb3-phy@ff470000/utmi@ff470000 failed [    1.393749] phy phy-ff470000.usb3-phy.3: Looking up phy-supply from device tree [    1.393769] phy phy-ff470000.usb3-phy.3: Looking up phy-supply property in node /usb3-phy@ff470000/pipe@ff478000 failed [    1.396175] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully [    1.397428] phy phy-ff430000.hdmiphy.4: Looking up phy-supply from device tree [    1.397447] phy phy-ff430000.hdmiphy.4: Looking up phy-supply property in node /hdmiphy@ff430000 failed [    1.400340] rk-vcodec ff350000.vpu-service: probe device [    1.400882] rk-vcodec ff350000.vpu-service: vpu mmu dec ffffffc0f557ec10 [    1.401859] rk-vcodec ff350000.vpu-service: allocator is drm [    1.402489] rk-vcodec ff350000.vpu-service: checking hw id 0 [    1.403709] rk-vcodec ff350000.vpu-service: init success [    1.405043] rk-vcodec ff360000.rkvdec: probe device [    1.405548] rk-vcodec ff360000.rkvdec: vpu mmu dec ffffffc0f557f410 [    1.406442] rk-vcodec ff360000.rkvdec: allocator is drm [    1.407036] rk-vcodec ff360000.rkvdec: checking hw id 3410 [    1.408231] rk-vcodec ff360000.rkvdec: init success [    1.409152] probe device ff330000.h265e [    1.409973] mpp_dev ff330000.h265e: try to get iommu dev ffffffc0f557fc10 [    1.411038] mpp_dev ff330000.h265e: resource ready, register device [    1.411991] probe device ff340000.vepu [    1.412694] mpp_dev ff340000.vepu: try to get iommu dev ffffffc0f55a4410 [    1.413639] rockchip_mpp_vepu_reset_init:143: No aclk reset resource define [    1.414305] rockchip_mpp_vepu_reset_init:148: No hclk reset resource define [    1.414964] mpp_dev ff340000.vepu: resource ready, register device [    1.418708] dma-pl330 ff1f0000.dmac: Loaded driver for PL330 DMAC-241330 [    1.419365] dma-pl330 ff1f0000.dmac:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [    1.421145] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled [    1.424660] [drm:drm_core_init] Initialized drm 1.1.0 20060810 [    1.428380] rockchip-vop ff370000.vop: invalid resource [    1.428890] rockchip-vop ff370000.vop: failed to get vop lut registers [    1.429526] rockchip-vop ff370000.vop: invalid resource [    1.430037] rockchip-vop ff370000.vop: failed to get vop cabc lut registers [    1.430926] rockchip-drm display-subsystem: bound ff370000.vop (ops 0xffffff8008c4ff38) [    1.432081] i2c i2c-4: of_i2c: modalias failure on /hdmi@ff3c0000/ports [    1.432701] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver [    1.433517] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2) [    1.435389] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops 0xffffff8008c4a928) [    1.436190] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013). [    1.436949] [drm:drm_vblank_init] No driver support for vblank timestamp query. [    1.437698] rockchip-drm display-subsystem: failed to parse display resources [    1.438411] rockchip-drm display-subsystem: No connectors reported connected with modes [    1.439235] [drm:drm_fb_helper_single_fb_probe] Cannot find any crtc or sizes - going 1024x768 [    1.465737] Console: switching to colour frame buffer device 128x48 [    1.485856] rockchip-drm display-subsystem: fb0:  frame buffer device [    1.494838] Unable to detect cache hierarchy from DT for CPU 0 [    1.496995] brd: module loaded [    1.506823] loop: module loaded [    1.508376] zram: Added device: zram0 [    1.509202] lkdtm: No crash points registered, enable through debugfs [    1.511689] rockchip-spi ff190000.spi: Failed to request TX DMA channel [    1.512581] rockchip-spi ff190000.spi: Failed to request RX DMA channel [    1.514376] m25p80 spi32766.0: gd25q128 (16384 Kbytes) [    1.515119] 6 ofpart partitions found on MTD device spi32766.0 [    1.515860] Creating 6 MTD partitions on "spi32766.0": [    1.516542] 0x000000000000-0x000000008000 : "system" [    1.517704] 0x000000008000-0x000000400000 : "loader" [    1.518810] 0x000000400000-0x0000007c0000 : "reserved" [    1.519947] 0x0000007c0000-0x000000800000 : "vendor" [    1.521085] 0x000000800000-0x000000c00000 : "uboot" [    1.522175] 0x000000c00000-0x000001000000 : "atf" [    1.525175] rk_gmac-dwmac ff540000.eth: Looking up phy-supply from device tree [    1.525301] rk_gmac-dwmac ff540000.eth: clock input or output? (input). [    1.526186] rk_gmac-dwmac ff540000.eth: TX delay(0x26). [    1.526869] rk_gmac-dwmac ff540000.eth: RX delay(0x11). [    1.527755] rk_gmac-dwmac ff540000.eth: clock input from PHY [    1.528501] rk_gmac-dwmac ff540000.eth: init for RGMII [    1.534362] stmmac - user ID: 0x10, Synopsys ID: 0x35 [    1.542867]  Ring mode enabled [    1.551053]  DMA HW capability register supported [    1.551635]  Normal descriptors [    1.567596]  RX Checksum Offload Engine supported (type 2) [    1.576103]  TX Checksum insertion supported [    1.584448]  Wake-Up On Lan supported [    1.592716]  Enable RX Mitigation via HW Watchdog Timer [    1.601217] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/eth@ff540000[0]' - status (0) [    1.682314] libphy: stmmac: probed [    1.690376] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active [    1.698740] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01) [    1.708079] Rockchip WiFi SYS interface (V1.00) ... [    1.716207] usbcore: registered new interface driver cdc_ether [    1.724338] usbcore: registered new interface driver rndis_host [    1.734032] phy phy-ff470000.usb3-phy.2: u3phy u2 power on [    1.741827] phy phy-ff470000.usb3-phy.3: u3phy u3 power on [    1.750333] dwc2 ff580000.usb: Looking up vusb_d-supply from device tree [    1.750356] dwc2 ff580000.usb: Looking up vusb_d-supply property in node /usb@ff580000 failed [    1.750373] ff580000.usb supply vusb_d not found, using dummy regulator [    1.758028] dwc2 ff580000.usb: Looking up vusb_a-supply from device tree [    1.758047] dwc2 ff580000.usb: Looking up vusb_a-supply property in node /usb@ff580000 failed [    1.758061] ff580000.usb supply vusb_a not found, using dummy regulator [    1.921205] dwc2 ff580000.usb: DWC OTG Controller [    1.928338] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1 [    1.935675] dwc2 ff580000.usb: irq 40, io mem 0x00000000 [    1.943093] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [    1.950336] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    1.957533] usb usb1: Product: DWC OTG Controller [    1.964364] usb usb1: Manufacturer: Linux 4.4.77-rockchip-ayufan-101 dwc2_hsotg [    1.971503] usb usb1: SerialNumber: ff580000.usb [    1.979224] hub 1-0:1.0: USB hub found [    1.985976] hub 1-0:1.0: 1 port detected [    1.993847] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [    2.000896] ehci-pci: EHCI PCI platform driver [    2.007819] ehci-platform: EHCI generic platform driver [    2.017264] ehci-platform ff5c0000.usb: EHCI Host Controller [    2.024439] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2 [    2.031853] ehci-platform ff5c0000.usb: irq 41, io mem 0xff5c0000 [    2.043986] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00 [    2.051298] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [    2.058352] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    2.065437] usb usb2: Product: EHCI Host Controller [    2.072376] usb usb2: Manufacturer: Linux 4.4.77-rockchip-ayufan-101 ehci_hcd [    2.079710] usb usb2: SerialNumber: ff5c0000.usb [    2.087686] hub 2-0:1.0: USB hub found [    2.095105] hub 2-0:1.0: 1 port detected [    2.103027] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [    2.110582] ohci-platform: OHCI generic platform driver [    2.118422] ohci-platform ff5d0000.usb: Generic Platform OHCI controller [    2.126435] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3 [    2.134484] ohci-platform ff5d0000.usb: irq 42, io mem 0xff5d0000 [    2.197260] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [    2.205180] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    2.213136] usb usb3: Product: Generic Platform OHCI controller [    2.220987] usb usb3: Manufacturer: Linux 4.4.77-rockchip-ayufan-101 ohci_hcd [    2.229046] usb usb3: SerialNumber: ff5d0000.usb [    2.238700] hub 3-0:1.0: USB hub found [    2.246489] hub 3-0:1.0: 1 port detected [    2.255422] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller [    2.263667] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 4 [    2.272046] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00210010 [    2.280373] xhci-hcd xhci-hcd.8.auto: irq 180, io mem 0xff600000 [    2.288708] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 [    2.296908] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    2.305125] usb usb4: Product: xHCI Host Controller [    2.313196] usb usb4: Manufacturer: Linux 4.4.77-rockchip-ayufan-101 xhci-hcd [    2.321551] usb usb4: SerialNumber: xhci-hcd.8.auto [    2.330628] hub 4-0:1.0: USB hub found [    2.338769] hub 4-0:1.0: 1 port detected [    2.347462] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller [    2.356289] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 5 [    2.364980] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM. [    2.373854] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003 [    2.382380] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [    2.390947] usb usb5: Product: xHCI Host Controller [    2.399236] usb usb5: Manufacturer: Linux 4.4.77-rockchip-ayufan-101 xhci-hcd [    2.407787] usb usb5: SerialNumber: xhci-hcd.8.auto [    2.416902] hub 5-0:1.0: USB hub found [    2.425160] hub 5-0:1.0: 1 port detected [    2.435751] usbcore: registered new interface driver usbtouchscreen [    2.445015] i2c /dev entries driver [    2.456200] rk808 1-0018: Pmic Chip id: 0x8050 [    2.465563] rk808 1-0018: source: on=0x10, off=0x00 [    2.479136] rk808 1-0018: Looking up vcc1-supply from device tree [    2.479260] DCDC_REG1: supplied by vcc_sys [    2.487442] vcc_sys: could not add device link regulator.4 err -2 [    2.490051] vdd_logic: 712 <--> 1450 mV at 1100 mV [    2.490353] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [    2.490389] vcc_sd: unable to resolve supply [    2.490417] rk808 1-0018: Looking up vcc2-supply from device tree [    2.490514] DCDC_REG2: supplied by vcc_sys [    2.498571] vcc_sys: could not add device link regulator.5 err -2 [    2.500663] vdd_arm: 712 <--> 1450 mV at 1100 mV [    2.500978] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [    2.501011] vcc_sd: unable to resolve supply [    2.501040] rk808 1-0018: Looking up vcc3-supply from device tree [    2.501129] DCDC_REG3: supplied by vcc_sys [    2.509101] vcc_sys: could not add device link regulator.6 err -2 [    2.510365] vcc_ddr: at 5000 mV [    2.510643] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [    2.510676] vcc_sd: unable to resolve supply [    2.510704] rk808 1-0018: Looking up vcc4-supply from device tree [    2.510792] DCDC_REG4: supplied by vcc_sys [    2.518599] vcc_sys: could not add device link regulator.7 err -2 [    2.519862] vcc_io: 3300 mV [    2.520179] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [    2.520209] vcc_sd: supplied by vcc_io [    2.528013] rk808 1-0018: Looking up vcc5-supply from device tree [    2.528041] LDO_REG1: supplied by vcc_io [    2.535950] vcc_io: could not add device link regulator.8 err -2 [    2.538332] vcc_18: 1800 mV [    2.538675] rk808 1-0018: Looking up vcc5-supply from device tree [    2.538713] LDO_REG2: supplied by vcc_io [    2.546203] vcc_io: could not add device link regulator.9 err -2 [    2.548578] vcc18_emmc: 1800 mV [    2.548878] rk808 1-0018: Looking up vcc6-supply from device tree [    2.549023] LDO_REG3: supplied by vcc_sys [    2.556372] vcc_sys: could not add device link regulator.10 err -2 [    2.558750] vdd_10: 1000 mV [    2.559069] rk808 1-0018: register rk8050 regulators [    2.566764] gpiochip_find_base: found new base at 510 [    2.566924] gpiochip_add: registered GPIOs 510 to 511 on device: rk8xx-gpio [    2.566962] rk8xx-gpio rk8xx-gpio: register rk8050 gpio successful [    2.576791] input: rk8xx_pwrkey as /devices/platform/ff160000.i2c/i2c-1/1-0018/input/input0 [    2.585457] rk808-rtc rk808-rtc: device is disabled [    2.593265] rk808-rtc: probe of rk808-rtc failed with error -22 [    2.601207] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff8009a2e000 [    2.610678] IR NEC protocol handler initialized [    2.619033] usbcore: registered new interface driver uvcvideo [    2.626955] USB Video Class driver (1.1.1) [    2.635214] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio1-supply from device tree [    2.635378] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio2-supply from device tree [    2.636006] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio3-supply from device tree [    2.636100] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio4-supply from device tree [    2.636675] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio5-supply from device tree [    2.636761] rockchip-iodomain ff100000.syscon:io-domains: Looking up vccio6-supply from device tree [    2.636876] rockchip-iodomain ff100000.syscon:io-domains: Looking up pmuio-supply from device tree [    2.638719] rockchip-thermal ff250000.tsadc: Missing tshut mode property, using default (cru) [    2.647130] rockchip-thermal ff250000.tsadc: Missing tshut-polarity property, using default (low) [    2.657140] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com [    2.665626] Bluetooth: Virtual HCI driver ver 1.5 [    2.673962] Bluetooth: HCI UART driver ver 2.3 [    2.682047] Bluetooth: HCI UART protocol H4 registered [    2.690125] Bluetooth: HCI UART protocol LL registered [    2.698076] Bluetooth: HCI UART protocol ATH3K registered [    2.706084] usbcore: registered new interface driver bfusb [    2.714070] usbcore: registered new interface driver btusb [    2.722123] cpu cpu0: Looking up cpu-supply from device tree [    2.722633] cpu cpu0: Looking up cpu-supply from device tree [    2.722847] cpu cpu0: Looking up cpu-supply from device tree [    2.724817] sdhci: Secure Digital Host Controller Interface driver [    2.732692] sdhci: Copyright(c) Pierre Ossman [    2.740281] Synopsys Designware Multimedia Card Interface Driver [    2.749324] dwmmc_rockchip ff520000.rksdmmc: IDMAC supports 32-bit address mode. [    2.754383] dwmmc_rockchip ff520000.rksdmmc: Using internal DMA controller. [    2.759325] dwmmc_rockchip ff520000.rksdmmc: Version ID is 270a [    2.764211] dwmmc_rockchip ff520000.rksdmmc: DW MMC controller at irq 37,32 bit host data width,256 deep fifo [    2.769643] dwmmc_rockchip ff520000.rksdmmc: Looking up vmmc-supply from device tree [    2.770055] dwmmc_rockchip ff520000.rksdmmc: Looking up vqmmc-supply from device tree [    2.770586] dwmmc_rockchip ff520000.rksdmmc: GPIO lookup for consumer wp [    2.770593] dwmmc_rockchip ff520000.rksdmmc: using device tree for GPIO lookup [    2.770604] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/rksdmmc@ff520000[0]' [    2.770611] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/rksdmmc@ff520000[0]' [    2.770618] dwmmc_rockchip ff520000.rksdmmc: using lookup tables for GPIO lookup [    2.770625] dwmmc_rockchip ff520000.rksdmmc: lookup for GPIO wp failed [    2.780989] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [    2.796018] dwmmc_rockchip ff520000.rksdmmc: 1 slots initialized [    2.800774] dwmmc_rockchip ff500000.rksdmmc: IDMAC supports 32-bit address mode. [    2.805336] dwmmc_rockchip ff500000.rksdmmc: Using internal DMA controller. [    2.809700] dwmmc_rockchip ff500000.rksdmmc: Version ID is 270a [    2.814000] dwmmc_rockchip ff500000.rksdmmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo [    2.818763] dwmmc_rockchip ff500000.rksdmmc: Looking up vmmc-supply from device tree [    2.818903] dwmmc_rockchip ff500000.rksdmmc: Looking up vqmmc-supply from device tree [    2.818992] dwmmc_rockchip ff500000.rksdmmc: GPIO lookup for consumer cd [    2.819005] dwmmc_rockchip ff500000.rksdmmc: using device tree for GPIO lookup [    2.819035] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/rksdmmc@ff500000[0]' - status (0) [    2.819174] dwmmc_rockchip ff500000.rksdmmc: Got CD GPIO [    2.823110] dwmmc_rockchip ff500000.rksdmmc: GPIO lookup for consumer wp [    2.823117] dwmmc_rockchip ff500000.rksdmmc: using device tree for GPIO lookup [    2.823125] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/rksdmmc@ff500000[0]' [    2.823132] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/rksdmmc@ff500000[0]' [    2.823138] dwmmc_rockchip ff500000.rksdmmc: using lookup tables for GPIO lookup [    2.823145] dwmmc_rockchip ff500000.rksdmmc: lookup for GPIO wp failed [    2.833963] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [    2.849277] dwmmc_rockchip ff500000.rksdmmc: 1 slots initialized [    2.853565] sdhci-pltfm: SDHCI platform and OF driver helper [    2.858013] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/standby-led[0]' - status (0) [    2.858607] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/power-led[0]' - status (0) [    2.858759] of_get_named_gpiod_flags: parsed 'gpios' property of node '/switches/usb-switch[0]' - status (0) [    2.858981] hidraw: raw HID events driver (C) Jiri Kosina [    2.863373] usbcore: registered new interface driver usbhid [    2.864236] mmc0: MAN_BKOPS_EN bit is not set [    2.870446] mmc_host mmc0: Bus speed (slot 0) = 200000000Hz (slot req 200000000Hz, actual 200000000HZ div = 0) [    2.883643] usbhid: USB HID core driver [    2.890280] usbcore: registered new interface driver snd-usb-audio [    2.892918] dwmmc_rockchip ff520000.rksdmmc: All phases work, using default phase 0. [    2.893216] mmc0: new HS200 MMC card at address 0001 [    2.893806] mmcblk0: mmc0:0001 NCard  28.9 GiB [    2.894140] mmcblk0boot0: mmc0:0001 NCard  partition 1 4.00 MiB [    2.894368] mmcblk0boot1: mmc0:0001 NCard  partition 2 4.00 MiB [    2.894580] mmcblk0rpmb: mmc0:0001 NCard  partition 3 4.00 MiB [    2.927014] rk3328-codec ff410000.codec: spk_depop_time use default value. [    2.933067] GPT:Primary header thinks Alt. header is not at the end of the disk. [    2.935426] u32 classifier [    2.935435] Netfilter messages via NETLINK v0.30. [    2.935484] ip_set: protocol 6 [    2.935650] Initializing XFRM netlink socket [    2.936235] NET: Registered protocol family 10 [    2.937107] NET: Registered protocol family 17 [    2.937129] NET: Registered protocol family 15 [    2.937164] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. [    2.937187] Bridge firewalling registered [    2.937309] Bluetooth: RFCOMM socket layer initialized [    2.937337] Bluetooth: RFCOMM ver 1.11 [    2.937352] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [    2.937360] Bluetooth: HIDP socket layer initialized [    2.937412] 8021q: 802.1Q VLAN Support v1.8 [    2.937435] [WLAN_RFKILL]: Enter rfkill_wlan_init [    2.937649] [BT_RFKILL]: Enter rfkill_rk_init [    2.937774] Key type dns_resolver registered [    2.942792] Registered cp15_barrier emulation handler [    2.942799] Registered setend emulation handler [    2.943561] registered taskstats version 1 [    2.943574] Loading compiled-in X.509 certificates [    2.945532] Btrfs loaded, integrity-checker=on [    2.945609] BTRFS: selftest: Running btrfs free space cache tests [    2.945629] BTRFS: selftest: Running extent only tests [    2.945643] BTRFS: selftest: Running bitmap only tests [    2.945659] BTRFS: selftest: Running bitmap and extent tests [    2.945680] BTRFS: selftest: Running space stealing from bitmap to extent [    2.946599] BTRFS: selftest: Free space cache tests finished [    2.946602] BTRFS: selftest: Running extent buffer operation tests [    2.946603] BTRFS: selftest: Running btrfs_split_item tests [    2.946640] BTRFS: selftest: Running find delalloc tests [    3.043627] vendor storage:20160801 ret = 0 [    3.087493] GPT:10749951 != 60620799 [    3.091416] GPT:Alternate GPT header not at the end of the disk. [    3.095602] GPT:10749951 != 60620799 [    3.099490] GPT: Use GNU Parted to correct GPT errors. [    3.103491]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 [    3.179633] BTRFS: selftest: Running btrfs_get_extent tests [    3.183508] BTRFS: selftest: Running hole first btrfs_get_extent test [    3.187242] BTRFS: selftest: Running outstanding_extents tests [    3.190861] BTRFS: selftest: Running qgroup tests [    3.194304] BTRFS: selftest: Qgroup basic add [    3.197728] BTRFS: selftest: Qgroup multiple refs test [    3.212559] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]' [    3.212570] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]' [    3.212967] asoc-simple-card hdmi-sound: i2s-hifi <-> ff000000.i2s mapping ok [    3.217759] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]' [    3.217770] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]' [    3.238188] asoc-simple-card sound: rk3328-hifi <-> ff010000.i2s mapping ok [    3.242273] asoc-simple-card sound: snd-soc-dummy-dai <-> ff010000.i2s mapping ok [    3.247183] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]' [    3.247194] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]' [    3.247539] asoc-simple-card spdif-sound: dit-hifi <-> ff030000.spdif mapping ok [    3.252086] hctosys: unable to open rtc device (rtc0) [    3.264232] vcc_sd: disabling [    3.277616] rockchip-pm-domain ff100000.syscon:power-controller: failed to get ack on domain 'pd_video', val=0x10040 [    3.278983] usb 1-1: new high-speed USB device number 2 using dwc2 [    3.295570] rockchip-pm-domain ff100000.syscon:power-controller: failed to get ack on domain 'pd_vpu', val=0x10040 [    3.299954] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_fro m_arm of this mali_ko is '-08404cd', rk_ko_ver is '5', built at '14:47:58', on 'Sep  8 2017'. [    3.309142] mali-utgard ff300000.gpu: mali_platform_device->num_resources = 9 [    3.313333] mali-utgard ff300000.gpu: resource[0].start = 0x0x00000000ff300000 [    3.317529] mali-utgard ff300000.gpu: resource[1].start = 0x0x00000000ff300000 [    3.321668] mali-utgard ff300000.gpu: resource[2].start = 0x0x0000000000000011 [    3.325789] mali-utgard ff300000.gpu: resource[3].start = 0x0x0000000000000012 [    3.329861] mali-utgard ff300000.gpu: resource[4].start = 0x0x0000000000000013 [    3.333898] mali-utgard ff300000.gpu: resource[5].start = 0x0x0000000000000014 [    3.337880] mali-utgard ff300000.gpu: resource[6].start = 0x0x0000000000000015 [    3.341821] mali-utgard ff300000.gpu: resource[7].start = 0x0x0000000000000016 [    3.345713] mali-utgard ff300000.gpu: resource[8].start = 0x0x0000000000000017 [    3.349560] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 518; [Func] : mali_platform_device_init(); to add platform_sp ecific_data to platform_device_of_mali. [    3.357754] mali-utgard ff300000.gpu: Looking up mali-supply from device tree [    3.359606] Mali: Mali device driver loaded [    3.364384] ALSA device list: [    3.368104]   #0: HDMI [    3.371672]   #1: I2S [    3.375172]   #2: SPDIF [    3.379208] Freeing unused kernel memory: 1152K (ffffff8008fa0000 - ffffff80090c0000) [    3.425067] random: udevadm: uninitialized urandom read (16 bytes read, 16 bits of entropy available) [    3.431477] random: systemd-udevd: uninitialized urandom read (16 bytes read, 16 bits of entropy available) [    3.436299] random: udevadm: uninitialized urandom read (16 bytes read, 16 bits of entropy available) [    3.436406] random: systemd-udevd: uninitialized urandom read (16 bytes read, 16 bits of entropy available) [    3.436451] random: systemd-udevd: uninitialized urandom read (16 bytes read, 16 bits of entropy available) [    3.436498] random: systemd-udevd: uninitialized urandom read (16 bytes read, 16 bits of entropy available) [    3.454861] random: udevadm: uninitialized urandom read (16 bytes read, 16 bits of entropy available) [    3.459592] random: udevadm: uninitialized urandom read (16 bytes read, 16 bits of entropy available) [    3.464482] random: udevadm: uninitialized urandom read (16 bytes read, 16 bits of entropy available) [    3.469109] random: udevadm: uninitialized urandom read (16 bytes read, 16 bits of entropy available) [    3.721840] usb 1-1: New USB device found, idVendor=0bda, idProduct=0823 [    3.726237] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [    3.730679] usb 1-1: Product: 802.11ac WLAN Adapter [    3.734897] usb 1-1: Manufacturer: Realtek [    3.738982] usb 1-1: SerialNumber: 00e04c000001 [    3.746449] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000a lmp_ver=06 lmp_subver=8821 [    3.751070] Bluetooth: hci0: rtl: loading rtl_bt/rtl8821a_fw.bin [    3.755542] bluetooth hci0: Direct firmware load for rtl_bt/rtl8821a_fw.bin failed with error -2 [    3.760266] Bluetooth: hci0: Failed to load rtl_bt/rtl8821a_fw.bin [    3.822355] EXT4-fs (mmcblk0p7): mounted filesystem with writeback data mode. Opts: (null) [    3.950792] systemd[1]: System time before build time, advancing clock. [    3.971175] systemd[1]: Failed to insert module 'autofs4': No such file or directory [    3.991641] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT  +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN) [    4.001978] systemd[1]: Detected architecture arm64. [    4.011661] systemd[1]: Set hostname to <rock64>. [    4.017249] systemd[1]: Initializing machine ID from random generator. [    4.234132] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [    4.239505] systemd[1]: Reached target Encrypted Volumes. [    4.244850] systemd[1]: Listening on Journal Socket. [    4.249652] systemd[1]: Reached target User and Group Name Lookups. [    4.254985] systemd[1]: Created slice System Slice. [    4.261417] systemd[1]: Starting Nameserver information manager... [    4.271241] systemd[1]: Starting Load Kernel Modules... [    4.278056] systemd[1]: Starting Set console keymap... [    4.285627] systemd[1]: Starting Restore / save the current clock... [    4.292836] systemd[1]: Starting Uncomplicated firewall... [    4.298028] systemd[1]: Listening on Syslog Socket. [    4.303199] systemd[1]: Listening on Journal Socket (/dev/log). [    4.308273] systemd[1]: Reached target Swap. [    4.313496] systemd[1]: Created slice User and Session Slice. [    4.318265] systemd[1]: Reached target Slices. [    4.324833] systemd[1]: Started Read required files in advance. [    4.330496] systemd[1]: Created slice system-serial\x2dgetty.slice. [    4.337723] systemd[1]: Starting Create list of required static device nodes for the current kernel... [    4.345088] systemd[1]: Mounting Debug File System... [    4.350380] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [    4.355586] systemd[1]: Listening on udev Kernel Socket. [    4.360614] systemd[1]: Listening on udev Control Socket. [    4.365428] systemd[1]: Started Trigger resolvconf update for networkd DNS. [    4.372009] systemd[1]: Starting Remount Root and Kernel File Systems... [    4.377041] systemd[1]: Listening on Journal Audit Socket. [    4.383455] systemd[1]: Starting Journal Service... [    4.389961] systemd[1]: Started Braille Device Support. [    4.394893] systemd[1]: Reached target Remote File Systems (Pre). [    4.399734] systemd[1]: Reached target Remote File Systems. [    4.412542] systemd[1]: Mounted Debug File System. [    4.421145] systemd[1]: Started Load Kernel Modules. [    4.427019] systemd[1]: Started Set console keymap. [    4.432326] systemd[1]: Started Restore / save the current clock. [    4.438004] systemd[1]: Started Uncomplicated firewall. [    4.442972] systemd[1]: ureadahead.service: Main process exited, code=exited, status=5/NOTINSTALLED [    4.448624] systemd[1]: ureadahead.service: Unit entered failed state. [    4.453246] systemd[1]: ureadahead.service: Failed with result 'exit-code'. [    4.458390] systemd[1]: Started Create list of required static device nodes for the current kernel. [    4.464605] systemd[1]: Started Remount Root and Kernel File Systems. [    4.472450] systemd[1]: Started Nameserver information manager. [    4.483384] systemd[1]: Time has been changed [    4.535715] systemd[1]: Started Journal Service. [    4.758051] systemd-journald[270]: Received request to flush runtime journal from PID 1 [    5.177893] random: nonblocking pool is initialized [    5.490859] FAT-fs (mmcblk0p6): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [    5.675112] rk_gmac-dwmac ff540000.eth: rk_get_eth_addr: mac address: 56:34:ef:c5:40:65 [    5.679494] eth0: device MAC address 56:34:ef:c5:40:65 [    6.528442] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000a lmp_ver=06 lmp_subver=8821 [    6.528458] Bluetooth: hci0: rtl: loading rtl_bt/rtl8821a_fw.bin [    6.529513] bluetooth hci0: Direct firmware load for rtl_bt/rtl8821a_fw.bin failed with error -2 [    6.529533] Bluetooth: hci0: Failed to load rtl_bt/rtl8821a_fw.bin [    6.946474] cfg80211: World regulatory domain updated: [    6.946491] cfg80211:  DFS Master region: unset [    6.946496] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time) [    6.946504] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [    6.946510] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [    6.946516] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A) [    6.946522] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A) [    6.946529] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s) [    6.946536] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s) [    6.946541] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A) [    6.946547] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A) [    8.040465] devfreq ff300000.gpu: Couldn't update frequency transition information. [    9.740895] rk_gmac-dwmac ff540000.eth eth0: Link is Up - 1Gbps/Full - flow control rx/tx [   16.443826] tty_port_close_start: tty->count = 1 port count = 2. [  268.975631] EXT4-fs (mmcblk0p7): resizing filesystem from 1310720 to 7544827 blocks [  269.397760] EXT4-fs (mmcblk0p7): resized filesystem to 7544827 [  539.940444] usb 1-1: reset high-speed USB device number 2 using dwc2 [  542.396443] Bluetooth: hci0 command 0x1001 tx timeout [  542.823536] Bluetooth: hci0 urb ffffffc0f3f24a80 failed to resubmit (113) [  542.824191] Bluetooth: hci0 urb ffffffc0f3f24cc0 failed to resubmit (113) [  542.824883] Bluetooth: hci0 urb ffffffc0f3f243c0 failed to resubmit (113) [  550.395632] Bluetooth: hci0: HCI_OP_READ_LOCAL_VERSION failed (-110)
root@rock64:~# lsusb -v Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Device Descriptor:  bLength                18  bDescriptorType         1  bcdUSB               3.00  bDeviceClass            9 Hub  bDeviceSubClass         0 Unused  bDeviceProtocol         3  bMaxPacketSize0         9  idVendor           0x1d6b Linux Foundation  idProduct          0x0003 3.0 root hub  bcdDevice            4.04  iManufacturer           3 Linux 4.4.77-rockchip-ayufan-101 xhci-hcd  iProduct                2 xHCI Host Controller  iSerial                 1 xhci-hcd.8.auto  bNumConfigurations      1  Configuration Descriptor:    bLength                 9    bDescriptorType         2    wTotalLength           31    bNumInterfaces          1    bConfigurationValue     1    iConfiguration          0    bmAttributes         0xe0      Self Powered      Remote Wakeup    MaxPower                0mA    Interface Descriptor:      bLength                 9      bDescriptorType         4      bInterfaceNumber        0      bAlternateSetting       0      bNumEndpoints           1      bInterfaceClass         9 Hub      bInterfaceSubClass      0 Unused      bInterfaceProtocol      0 Full speed (or root) hub      iInterface              0      Endpoint Descriptor:        bLength                 7        bDescriptorType         5        bEndpointAddress     0x81  EP 1 IN        bmAttributes            3          Transfer Type            Interrupt          Synch Type               None          Usage Type               Data        wMaxPacketSize     0x0004  1x 4 bytes        bInterval              12        bMaxBurst               0 Hub Descriptor:  bLength              12  bDescriptorType      42  nNbrPorts             1  wHubCharacteristic 0x000a    No power switching (usb 1.0)    Per-port overcurrent protection  bPwrOn2PwrGood       10 * 2 milli seconds  bHubContrCurrent      0 milli Ampere  bHubDecLat          0.0 micro seconds  wHubDelay             0 nano seconds  DeviceRemovable    0x00 Hub Port Status:   Port 1: 0000.02a0 5Gbps power Rx.Detect Binary Object Store Descriptor:  bLength                 5  bDescriptorType        15  wTotalLength           15  bNumDeviceCaps          1  SuperSpeed USB Device Capability:    bLength                10    bDescriptorType        16    bDevCapabilityType      3    bmAttributes         0x02      Latency Tolerance Messages (LTM) Supported    wSpeedsSupported   0x0008      Device can operate at SuperSpeed (5Gbps)    bFunctionalitySupport   3      Lowest fully-functional device speed is SuperSpeed (5Gbps)    bU1DevExitLat           0 micro seconds    bU2DevExitLat           0 micro seconds Device Status:     0x0001  Self Powered Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Device Descriptor:  bLength                18  bDescriptorType         1  bcdUSB               2.00  bDeviceClass            9 Hub  bDeviceSubClass         0 Unused  bDeviceProtocol         1 Single TT  bMaxPacketSize0        64  idVendor           0x1d6b Linux Foundation  idProduct          0x0002 2.0 root hub  bcdDevice            4.04  iManufacturer           3 Linux 4.4.77-rockchip-ayufan-101 xhci-hcd  iProduct                2 xHCI Host Controller  iSerial                 1 xhci-hcd.8.auto  bNumConfigurations      1  Configuration Descriptor:    bLength                 9    bDescriptorType         2    wTotalLength           25    bNumInterfaces          1    bConfigurationValue     1    iConfiguration          0    bmAttributes         0xe0      Self Powered      Remote Wakeup    MaxPower                0mA    Interface Descriptor:      bLength                 9      bDescriptorType         4      bInterfaceNumber        0      bAlternateSetting       0      bNumEndpoints           1      bInterfaceClass         9 Hub      bInterfaceSubClass      0 Unused      bInterfaceProtocol      0 Full speed (or root) hub      iInterface              0      Endpoint Descriptor:        bLength                 7        bDescriptorType         5        bEndpointAddress     0x81  EP 1 IN        bmAttributes            3          Transfer Type            Interrupt          Synch Type               None          Usage Type               Data        wMaxPacketSize     0x0004  1x 4 bytes        bInterval              12 Hub Descriptor:  bLength               9  bDescriptorType      41  nNbrPorts             1  wHubCharacteristic 0x000a    No power switching (usb 1.0)    Per-port overcurrent protection    TT think time 8 FS bits  bPwrOn2PwrGood       10 * 2 milli seconds  bHubContrCurrent      0 milli Ampere  DeviceRemovable    0x00  PortPwrCtrlMask    0xff Hub Port Status:   Port 1: 0000.0100 power Device Status:     0x0001  Self Powered Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Device Descriptor:  bLength                18  bDescriptorType         1  bcdUSB               1.10  bDeviceClass            9 Hub  bDeviceSubClass         0 Unused  bDeviceProtocol         0 Full speed (or root) hub  bMaxPacketSize0        64  idVendor           0x1d6b Linux Foundation  idProduct          0x0001 1.1 root hub  bcdDevice            4.04  iManufacturer           3 Linux 4.4.77-rockchip-ayufan-101 ohci_hcd  iProduct                2 Generic Platform OHCI controller  iSerial                 1 ff5d0000.usb  bNumConfigurations      1  Configuration Descriptor:    bLength                 9    bDescriptorType         2    wTotalLength           25    bNumInterfaces          1    bConfigurationValue     1    iConfiguration          0    bmAttributes         0xe0      Self Powered      Remote Wakeup    MaxPower                0mA    Interface Descriptor:      bLength                 9      bDescriptorType         4      bInterfaceNumber        0      bAlternateSetting       0      bNumEndpoints           1      bInterfaceClass         9 Hub      bInterfaceSubClass      0 Unused      bInterfaceProtocol      0 Full speed (or root) hub      iInterface              0      Endpoint Descriptor:        bLength                 7        bDescriptorType         5        bEndpointAddress     0x81  EP 1 IN        bmAttributes            3          Transfer Type            Interrupt          Synch Type               None          Usage Type               Data        wMaxPacketSize     0x0002  1x 2 bytes        bInterval             255 Hub Descriptor:  bLength               9  bDescriptorType      41  nNbrPorts             1  wHubCharacteristic 0x0012    No power switching (usb 1.0)    No overcurrent protection  bPwrOn2PwrGood        2 * 2 milli seconds  bHubContrCurrent      0 milli Ampere  DeviceRemovable    0x00  PortPwrCtrlMask    0xff Hub Port Status:   Port 1: 0000.0100 power Device Status:     0x0001  Self Powered Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Device Descriptor:  bLength                18  bDescriptorType         1  bcdUSB               2.00  bDeviceClass            9 Hub  bDeviceSubClass         0 Unused  bDeviceProtocol         0 Full speed (or root) hub  bMaxPacketSize0        64  idVendor           0x1d6b Linux Foundation  idProduct          0x0002 2.0 root hub  bcdDevice            4.04  iManufacturer           3 Linux 4.4.77-rockchip-ayufan-101 ehci_hcd  iProduct                2 EHCI Host Controller  iSerial                 1 ff5c0000.usb  bNumConfigurations      1  Configuration Descriptor:    bLength                 9    bDescriptorType         2    wTotalLength           25    bNumInterfaces          1    bConfigurationValue     1    iConfiguration          0    bmAttributes         0xe0      Self Powered      Remote Wakeup    MaxPower                0mA    Interface Descriptor:      bLength                 9      bDescriptorType         4      bInterfaceNumber        0      bAlternateSetting       0      bNumEndpoints           1      bInterfaceClass         9 Hub      bInterfaceSubClass      0 Unused      bInterfaceProtocol      0 Full speed (or root) hub      iInterface              0      Endpoint Descriptor:        bLength                 7        bDescriptorType         5        bEndpointAddress     0x81  EP 1 IN        bmAttributes            3          Transfer Type            Interrupt          Synch Type               None          Usage Type               Data        wMaxPacketSize     0x0004  1x 4 bytes        bInterval              12 Hub Descriptor:  bLength               9  bDescriptorType      41  nNbrPorts             1  wHubCharacteristic 0x0009    Per-port power switching    Per-port overcurrent protection  bPwrOn2PwrGood       10 * 2 milli seconds  bHubContrCurrent      0 milli Ampere  DeviceRemovable    0x00  PortPwrCtrlMask    0xff Hub Port Status:   Port 1: 0000.0100 power Device Status:     0x0001  Self Powered Bus 001 Device 002: ID 0bda:0823 Realtek Semiconductor Corp. Device Descriptor:  bLength                18  bDescriptorType         1  bcdUSB               2.10  bDeviceClass          239 Miscellaneous Device  bDeviceSubClass         2 ?  bDeviceProtocol         1 Interface Association  bMaxPacketSize0        64  idVendor           0x0bda Realtek Semiconductor Corp.  idProduct          0x0823  bcdDevice            2.00  iManufacturer           1 Realtek  iProduct                2 802.11ac WLAN Adapter  iSerial                 3 00e04c000001  bNumConfigurations      1  Configuration Descriptor:    bLength                 9    bDescriptorType         2    wTotalLength          236    bNumInterfaces          3    bConfigurationValue     1    iConfiguration          0    bmAttributes         0xe0      Self Powered      Remote Wakeup    MaxPower              500mA    Interface Association:      bLength                 8      bDescriptorType        11      bFirstInterface         0      bInterfaceCount         2      bFunctionClass        224 Wireless      bFunctionSubClass       1 Radio Frequency      bFunctionProtocol       1 Bluetooth      iFunction               4 Bluetooth Radio    Interface Descriptor:      bLength                 9      bDescriptorType         4      bInterfaceNumber        0      bAlternateSetting       0      bNumEndpoints           3      bInterfaceClass       224 Wireless      bInterfaceSubClass      1 Radio Frequency      bInterfaceProtocol      1 Bluetooth      iInterface              4 Bluetooth Radio      Endpoint Descriptor:        bLength                 7        bDescriptorType         5        bEndpointAddress     0x81  EP 1 IN        bmAttributes            3          Transfer Type            Interrupt          Synch Type               None          Usage Type               Data        wMaxPacketSize     0x0010  1x 16 bytes        bInterval               4      Endpoint Descriptor:        bLength                 7        bDescriptorType         5        bEndpointAddress     0x02  EP 2 OUT        bmAttributes            2          Transfer Type            Bulk          Synch Type               None          Usage Type               Data        wMaxPacketSize     0x0200  1x 512 bytes        bInterval               0      Endpoint Descriptor:        bLength                 7        bDescriptorType         5        bEndpointAddress     0x82  EP 2 IN        bmAttributes            2          Transfer Type            Bulk          Synch Type               None          Usage Type               Data        wMaxPacketSize     0x0200  1x 512 bytes        bInterval               0    Interface Descriptor:      bLength                 9      bDescriptorType         4      bInterfaceNumber        1      bAlternateSetting       0      bNumEndpoints           2      bInterfaceClass       224 Wireless      bInterfaceSubClass      1 Radio Frequency      bInterfaceProtocol      1 Bluetooth      iInterface              4 Bluetooth Radio      Endpoint Descriptor:        bLength                 7        bDescriptorType         5        bEndpointAddress     0x03  EP 3 OUT        bmAttributes            1          Transfer Type            Isochronous          Synch Type               None          Usage Type               Data        wMaxPacketSize     0x0000  1x 0 bytes        bInterval               4      Endpoint Descriptor:        bLength                 7        bDescriptorType         5        bEndpointAddress     0x83  EP 3 IN        bmAttributes            1          Transfer Type            Isochronous          Synch Type
what is that [bus 1 device 2] device that is listed? it states realtek 802.11ac WLAN Adapter/Bluetooth Radio.
yes it is one dongle USB WiFI AC + BT
no one had such issue ?
I have another Realtek, but no issue, it worked out-of-the-box...
Bus 002 Device 002: ID 0bda:0179 Realtek Semiconductor Corp. RTL8188ETV Wireless LAN 802.11n Network Adapter
Is it shown when doing "ifconfig" ?
Did you tried configure it with "nmtui" ?
(09-16-2017, 10:26 AM)martinayotte Wrote: I have another Realtek, but no issue, it worked out-of-the-box...
I don't see it with ifconfig
looks the one i hqve is not there in the /lib/firmware/rtlbt
[    7.052674] cfg80211: World regulatory domain updated: [    7.052688] cfg80211:  DFS Master region: unset [    7.052692] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time) [    7.052700] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [    7.052707] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [    7.052712] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A) [    7.052719] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A) [    7.052726] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s) [    7.052733] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s) [    7.052739] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A) [    7.052744] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A) [    7.062106] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000a lmp_ver=06 lmp_subver=8821 [    7.062121] Bluetooth: hci0: rtl: loading rtl_bt/rtl8821a_fw.bin [    7.069256] bluetooth hci0: Direct firmware load for rtl_bt/rtl8821a_fw.bin failed with error -2 [    7.069274] Bluetooth: hci0: Failed to load rtl_bt/rtl8821a_fw.bin [    8.427034] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [    9.565626] devfreq ff300000.gpu: Couldn't update frequency transition information.
root@rock64:~# ifconfig -a br-152ea61efe7b Link encap:Ethernet  HWaddr 02:42:35:80:6e:a5          inet addr:172.18.0.1  Bcast:0.0.0.0  Mask:255.255.0.0          UP BROADCAST MULTICAST  MTU:1500  Metric:1          RX packets:0 errors:0 dropped:0 overruns:0 frame:0          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0          collisions:0 txqueuelen:0          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B) docker0   Link encap:Ethernet  HWaddr 02:42:7d:7c:7b:32          inet addr:172.17.0.1  Bcast:0.0.0.0  Mask:255.255.0.0          UP BROADCAST MULTICAST  MTU:1500  Metric:1          RX packets:0 errors:0 dropped:0 overruns:0 frame:0          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0          collisions:0 txqueuelen:0          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B) eth0      Link encap:Ethernet  HWaddr 56:34:ef:c5:40:65          inet addr:192.168.0.11  Bcast:192.168.0.255  Mask:255.255.255.0          inet6 addr: fe80::68e4:9073:94e:39d0/64 Scope:Link          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1          RX packets:879 errors:0 dropped:0 overruns:0 frame:0          TX packets:507 errors:0 dropped:0 overruns:0 carrier:0          collisions:0 txqueuelen:1000          RX bytes:160476 (160.4 KB)  TX bytes:248328 (248.3 KB)          Interrupt:39 lo        Link encap:Local Loopback          inet addr:127.0.0.1  Mask:255.0.0.0          inet6 addr: ::1/128 Scope:Host          UP LOOPBACK RUNNING  MTU:65536  Metric:1          RX packets:23 errors:0 dropped:0 overruns:0 frame:0          TX packets:23 errors:0 dropped:0 overruns:0 carrier:0          collisions:0 txqueuelen:1          RX bytes:1770 (1.7 KB)  TX bytes:1770 (1.7 KB)
Forget to ask is your dongle BT and WiFi
does it has an external antenna ?
Mine is WiFi only with internal antenna ...
Is "dmesg" reporting something special ?
(09-17-2017, 02:09 PM)martinayotte Wrote: Mine is WiFi only with internal antenna ...
today i got more progress
I did the following
add-apt-repository ppa:hanipouspilot/rtlwifi apt-get update apt-get install rtlwifi-new-dkms linux-firmware reboot
now the BLE part works but i still don't see the WiFi
root@rock64:~# hcitool devi Devices:        hci0    8C:88:2B:00:0A:ED root@rock64:~# hciconfig hci0:   Type: BR/EDR  Bus: USB        BD Address: 8C:88:2B:00:0A:ED  ACL MTU: 820:8  SCO MTU: 255:16        UP RUNNING        RX bytes:1099 acl:0 sco:0 events:103 errors:0        TX bytes:18085 acl:0 sco:0 commands:103 errors:0
dmesg i see the FW is being detected now but no WiFi still
[    5.224260] systemd-journald[293]: Received request to flush runtime journal from PID 1 [    5.799961] FAT-fs (mmcblk0p6): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [    6.167792] rk_gmac-dwmac ff540000.eth: rk_get_eth_addr: mac address: 56:34:ef:c5:40:65 [    6.171976] eth0: device MAC address 56:34:ef:c5:40:65 [    6.931844] cfg80211: World regulatory domain updated: [    6.931861] cfg80211:  DFS Master region: unset [    6.931866] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time) [    6.931873] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [    6.931879] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [    6.931885] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A) [    6.931892] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A) [    6.931899] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s) [    6.931906] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s) [    6.931911] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A) [    6.931917] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A) [    7.080343] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000a lmp_ver=06 lmp_subver=8821 [    7.080363] Bluetooth: hci0: rtl: loading rtl_bt/rtl8821a_fw.bin [    7.089039] Bluetooth: hci0: rom_version status=0 version=1 [    8.916614] devfreq ff300000.gpu: Couldn't update frequency transition information. [    9.603078] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [    9.662680] ip_tables: (C) 2000-2006 Netfilter Core Team [   10.007603] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready [   10.272278] IPv6: ADDRCONF(NETDEV_UP): br-152ea61efe7b: link is not ready [   10.339356] rk_gmac-dwmac ff540000.eth eth0: Link is Up - 1Gbps/Full - flow control rx/tx [   12.281551] tty_port_close_start: tty->count = 1 port count = 2.
Make sure that you install firmware-realtek or linux-firmware (depends on Debian or Ubuntu).
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
(09-20-2017, 09:10 AM)ayufan Wrote: Make sure that you install firmware-realtek or linux-firmware (depends on Debian or Ubuntu).
this is what i did i installed the debian images
but still no luck in fact i see BLE but I can do anything with it (it fails when i try to perform a scan or attach)
WiFi it is even not detected
is there a way to know if it is supported this Card somehow ?
thanks
  Wrong resolution and very slow start of wifi. jgpacc 2 6,302 01-11-2022, 03:55 AM
Last Post: alanwake82
  Rock64 running OMV, how to setup RTL8812AU WiFi? electrosam 3 8,336 02-21-2020, 01:49 AM
Last Post: bigtreeman
  Compatible WiFi modules for Rock64 j3eeenet 8 20,088 08-08-2018, 02:06 AM
Last Post: AnythingIsFine
  pineA64 wifi module. Shubhendra 2 6,221 05-06-2018, 09:40 AM
Last Post: S3phi40T
  ROCK64 does not recognize USB Wifi module (WL300NU-G) pine3228 2 6,636 01-03-2018, 03:56 AM
Last Post: pine3228
  Is there anyone who got a compatible bluetooth dongle fbms 7 14,440 10-06-2017, 12:46 PM
Last Post: efreeze
